Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Errors running builder 'Acceleo Builder'
[Acceleo] Errors running builder 'Acceleo Builder' [message #802933] Mon, 20 February 2012 12:32 Go to next message
I am trying to switch from Acceleo 3.0.5 to Acceleo 3.2 and struggle with Errors during building.
I get this Error:
Errors occurred during the build.
Errors running builder 'Acceleo Builder' on project 'org.eclipse.acceleo.module.example.ecore2python'.
com.google.common.collect.ArrayListMultimap.create()Lcom/google/common/collect/ArrayListMultimap;
in detail:
java.lang.NoSuchMethodError: com.google.common.collect.ArrayListMultimap.create()Lcom/google/common/collect/ArrayListMultimap;
	at org.eclipse.acceleo.parser.AcceleoParser.<init>(AcceleoParser.java:100)
This is the Setup I have tested (clean install):
- Eclipse Helios SR2 Modeling Tools Package
- Acceleo 3.2 from the update site
This workspace:
- checked out the 'ecore2python' example project (to make sure the error is not in my code)
- created a Project with an ecore model consisting of a package and a class
I already tried installing guava-osgi (because that should include the needed com.google.common methods), but that didn't help.
If this wiki page is correct, Acceleo 3.2 should work with Helios: wiki.eclipse.org/Acceleo/Compatibility
Is that correct?
[Updated on: Mon, 20 February 2012 12:37] by Moderator
Re: [Acceleo] Errors running builder 'Acceleo Builder' [message #803350 is a reply to message #802933] Tue, 21 February 2012 03:14 Go to previous messageGo to next message
I strongly recommend 3.1.2 rather than 3.2 or 3.3M5, since the bugs in
3.1.2 are much easier to understand and workaround.
Ed Willink
> I am getting this Error:
> in detail:
> at
> This workspace:
> class
> Is that correct?
Re: [Acceleo] Errors running builder 'Acceleo Builder' [message #803453 is a reply to message #802933] Tue, 21 February 2012 06:16 Go to previous messageGo to next message
I tried it with Acceleo 3.1.3 and that works.
But I don't have "Traceability" in my context menu like it is shown in the first screenshot of this blog post:
http://eclipsemde.blogspot.com/2012/01/traceability-test-case-uml-to-java.html
If i read that post correctly, the feature should be available in Acceleo already. Is it present from Version 3.2 onwards or where?
I think that feature is awesome!
If I am not wrong, this error is present in a normal install of Acceleo 3.2 in a clean Eclipse Helios Modeleing Package. Is there a simple constellation in wich Acceleo 3.2 works with Helios? (like http://wiki.eclipse.org/Acceleo/Compatibility implies?)
Thanks in advance for your help.
Re: [Acceleo] Errors running builder 'Acceleo Builder' [message #805940 is a reply to message #803453] Fri, 24 February 2012 05:19 Go to previous message
The "Traceability" available in the context menu in my colleague's blog post is part of a commercial offer named Acceleo Premium built on top of Acceleo that provides advanced mechanism with the traceability information computed by Acceleo. You can find more about this advanced traceability in video here (free registration required).
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Previous Topic:[XPand2] setting local variables
Next Topic:[Acceleo ]ECORE Loop over References
Current Time: Thu Jul 24 23:58:39 EDT 2025
Powered by FUDForum. Page generated in 0.03606 seconds
