Home » Eclipse Projects » Eclipse Platform » Old plugins left behind after upgrade
Old plugins left behind after upgrade [message #80000] Sun, 22 June 2003 05:56 Go to next message
Is this normal? I used the update manager for the first time to upgrade
Eclipse. After doing so, the disk usage for my installation folder went
way up. I checked the plugins folder, and there are old verions of most of
the plugins still there alongside the new versions. Is this supposed to be
the case?
How do I clean this up? Do I have to go through manually removing the old
folders individually?
Re: Old plugins left behind after upgrade [message #80272 is a reply to message #80000] Sun, 22 June 2003 18:28 Go to previous messageGo to next message
It is normal. Currently you have to manually remove the old folders.
Peter
> the case?
Re: Old plugins left behind after upgrade [message #80285 is a reply to message #80272] Sun, 22 June 2003 20:16 Go to previous messageGo to next message
Thanks for the info. Are there any plans to change this? It seems like
this could be a real headache for users. I would think the old plugins
should be removed unless they are part of a saved configuration. No?
> Peter
> > the case?
Re: Old plugins left behind after upgrade [message #80300 is a reply to message #80285] Sun, 22 June 2003 20:43 Go to previous message
I believe 3.0 may have plans for this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37689
Peter
>>Peter
>>>the case?
Previous Topic:XML tree viewer source
Next Topic:package explorer font
Current Time: Sat Jul 26 01:16:55 EDT 2025
Powered by FUDForum. Page generated in 0.05850 seconds
