Home » Archived » BIRT » birt report java script problem in chrome and firefox
birt report java script problem in chrome and firefox [message #802813] Mon, 20 February 2012 08:44 Go to next message
I have downloaded an example of collapse/expand table rows using java script in birt from devshare . It is attached to this post . But this example is not working in mozilla firefox and chrome its showing error
'document.getElementById(btnstr) is null' in mozilla firefox.
'uncaught TypeError: Cannot set property 'value' of null' in chrome
although it works fine in IE and in eclipse IDE birt viewer.
I want to use this functionality in my report also
Please help
Rahul Deshpande
Re: birt report java script problem in chrome and firefox [message #803684 is a reply to message #802813] Tue, 21 February 2012 11:57 Go to previous messageGo to next message
Can you try the attached?
Jason
> Please help
> Thanks
> Rahul Deshpande
Re: birt report java script problem in chrome and firefox [message #803688 is a reply to message #802813] Tue, 21 February 2012 11:57 Go to previous messageGo to next message
Jason
> Please help
> Thanks
> Rahul Deshpande
Re: birt report java script problem in chrome and firefox [message #803692 is a reply to message #802813] Tue, 21 February 2012 11:57 Go to previous messageGo to next message
Jason
> Please help
> Thanks
> Rahul Deshpande
Re: birt report java script problem in chrome and firefox [message #804301 is a reply to message #803684] Wed, 22 February 2012 07:54 Go to previous messageGo to next message
thanks Jason,
can you please exaplain me why it was not working in chrome or fiorefox?
only first group is appears closed/hidden in chrome/firefox .
Rahul D.
Re: birt report java script problem in chrome and firefox [message #804302 is a reply to message #804301] Wed, 22 February 2012 07:58 Go to previous messageGo to next message
also please explain where did you made changes?
Rahul D.
Re: birt report java script problem in chrome and firefox [message #804402 is a reply to message #804302] Wed, 22 February 2012 10:28 Go to previous messageGo to next message
I believe the issue was that rows where named but did not have an id:
<INPUT Type="BUTTON"
id=<VALUE-OF>"mybutton"+row["ORDERNUMBER"]</VALUE-OF>
name=<VALUE-OF>"mybutton"+row["ORDERNUMBER"]</VALUE-OF> Value="-"
onClick='hidetable( this.form, <VALUE-OF>row["ORDERNUMBER"]</VALUE-OF>,
<VALUE-OF>row["Aggregation"]</VALUE-OF> )'></INPUT>
I added the id= field to the above HTML.
Jason
> Rahul D.
Re: birt report java script problem in chrome and firefox [message #814386 is a reply to message #804402] Tue, 06 March 2012 06:39 Go to previous messageGo to next message
Hi Jason ,
Sorry for let reply here by i am attaching report that is developed by me
please go through it . Its working fine on IE 8 but not on firefox and Chrome
Rahul
Re: birt report java script problem in chrome and firefox [message #814709 is a reply to message #814386] Tue, 06 March 2012 14:51 Go to previous messageGo to next message
I can not run the report. Can you view it in html( not the WebViwer)
just the html (View the Report as HTML from the menu) save and post the
html?
Jason
On 3/6/2012 6:39 AM, rahul rahuldeshpande89@gmail.com wrote:
> Hi Jason ,
> Thanks
> Rahul
Re: birt report java script problem in chrome and firefox [message #815023 is a reply to message #814709] Wed, 07 March 2012 01:08 Go to previous messageGo to next message
as per your suggestion i am posting html.
when we load the page all rows should be hidden.
i am attaching two files .
1.test.html contains only html
2. Call_Report_activity.rptdesign
please use following link to run the report
replace localhost and port number as per your environment.
userid & Uid are parameters i am passing to report. i am using apache tomcat to run the report .
localhost:8888/birt/run?__report=Call_Report_activity.rptdesign&UserId=NmMwY2I5NTUtY2QxZC1kYzg0LTA1MTMtNGU1YjRlZDQ0ZTcw&__overwrite=true&Uid=6c0cb955-
cd1d-dc84-0513-4e5b4ed44e70
If your runing report in IDE then you will be promted for UserId please enter value for it as 'NmMwY2I5NTUtY2QxZC1kYzg0LTA1MTMtNGU1YjRlZDQ0ZTcw'.
Rahul
Re: birt report java script problem in chrome and firefox [message #815526 is a reply to message #815023] Wed, 07 March 2012 14:25 Go to previous messageGo to next message
Ok I believe your issue is that your are using the run mapping instead
of frameset. You are using the script tag to hide a table before it is
actually making it to the browser:
<INPUT Type="BUTTON" name=<VALUE-OF>"mybutton"+row["parent"]</VALUE-OF>
id= <VALUE-OF>"mybutton"+row["parent"]</VALUE-OF> Value="-"
onClick="hidetable(this.form,
'<VALUE-OF>row["parent"]</VALUE-OF>','<VALUE-OF>row["Aggregation_2"]</VALUE-OF>');"></INPUT>
<VALUE-OF>row["Parentname"]</VALUE-OF> :
<VALUE-OF>row["parent_role"]</VALUE-OF>
<script>
hidetable( this.form, '<VALUE-OF>row["parent"]</VALUE-OF>',
'<VALUE-OF>row["Aggregation_2"]</VALUE-OF>' );
</script>
Remove this:
<script>
</script>
and put the following script on the table detail rows onrender
this.getStyle().display = "none";
Put that same script on the onrender for the group header row containing
the "parent" column. Also I changed your input tag to look like:
<form >
onClick='hidetable(this.form,
<VALUE-OF>row["parent"]</VALUE-OF>,<VALUE-OF>row["Aggregation_2"]</VALUE-OF>);'></INPUT>
</form>
I tried to run your report and it timed out on the connection, but I was
able to reproduce the issue with my sample and then fix it. Attached
are your design that I modified and the my modified sample report.
Jason
> userid& Uid are parameters i am passing to report. i am using apache tomcat to run the report .
> Rahul
  • Attachment: Examples.zip
    (Size: 23.93KB, Downloaded 293 times)
icon14.gif  Re: birt report java script problem in chrome and firefox [message #815979 is a reply to message #815526] Thu, 08 March 2012 04:24 Go to previous messageGo to next message
Jason ,
Thanks a lot for your support. Both of your example working fine . all my java script issues are now resolved .
But in my report i am facing row formatting problem . when we click on button to unhide/show the detail rows ,all data is get placed in first column only .
Please see attached image. How ever your collapset.rptdesign report is working fine without any formatting issue.Have you used any special formatting for detail rows?
Rahul
Re: birt report java script problem in chrome and firefox [message #816509 is a reply to message #815979] Thu, 08 March 2012 18:37 Go to previous messageGo to next message
Try setting your display to '' instead of 'block'
Jason
On 3/8/2012 4:24 AM, rahul rahuldeshpande89@gmail.com wrote:
> Jason ,
> Thanks
> Rahul
icon14.gif  Re: birt report java script problem in chrome and firefox [message #816824 is a reply to message #816509] Fri, 09 March 2012 04:56 Go to previous messageGo to next message
Thanks Buddy , Its working fine now
Rahul Smile
Re: birt report java script problem in chrome and firefox [message #818839 is a reply to message #816824] Mon, 12 March 2012 03:15 Go to previous messageGo to next message
When i am trying to export the report in pdf no details are coming in report
(please see attached pdf).
rahul
Re: birt report java script problem in chrome and firefox [message #819186 is a reply to message #818839] Mon, 12 March 2012 11:47 Go to previous message
Change the onRender scripts to:
if( reportContext.getOutputFormat() == "html" ){
Jason
> rahul
Previous Topic:Birt fails on report with strings
Next Topic:Installation Error
Current Time: Wed Jul 23 04:48:17 EDT 2025
Powered by FUDForum. Page generated in 0.12199 seconds
