Home » Eclipse Projects » Virgo » class not found, package only(package exported, but class not found)
class not found, package only [message #801221] Fri, 17 February 2012 22:35 Go to next message
I just wrote a hello world bundle project and published to the virgo tomcat web server. But when I browse http://localhost:8080/hello-world/remoting/helloService, I got a HTTP Status 500 with a exception report which indicate the server encountered a Class not found error. Then I call clexport main.HelloWorldImpl in Server Console, the console prints a report saying "class not found, package only".
I am a beginner, please help! The attachment is my project file.
Re: class not found, package only [message #801344 is a reply to message #801221] Sat, 18 February 2012 03:08 Go to previous messageGo to next message
The MANIFEST.MF contains:
Manifest-Version: 1.0
Class-Path:
Bundle-Version: 1.0.0
Can you please change the Class-Path to "Bundle-ClassPath: ." or simply remove this header?
Re: class not found, package only [message #801359 is a reply to message #801344] Sat, 18 February 2012 03:42 Go to previous messageGo to next message
Thanks, but the problem still occurs whether change the header to "Bundle-ClassPath: ." or remove the header.
Re: class not found, package only [message #801362 is a reply to message #801359] Sat, 18 February 2012 03:46 Go to previous messageGo to next message
The exception stack trace:
javax.servlet.ServletException: Servlet.init() for servlet remoting threw exception
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
org.eclipse.virgo.web.tomcat.support.ApplicationNameTrackingValve.invoke(ApplicationNameTrackingValve.java:33)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:405)
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:269)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:515)
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:300)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:662)
root cause
org.springframework.beans.factory.CannotLoadBeanClassException: Cannot find class [main.HelloWorldImpl] for bean with name 'hello' defined in ServletContext resource [/WEB-INF/remoting-servlet.xml]; nested exception is java.lang.ClassNotFoundException: main.HelloWorldImpl
org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1250)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.predictBeanType(AbstractAutowireCapableBeanFactory.java:576)
org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:1319)
org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:885)
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:562)
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:425)
org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:442)
org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:458)
org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:339)
org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:306)
org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:127)
javax.servlet.GenericServlet.init(GenericServlet.java:244)
root cause
org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:306)
java.lang.ClassLoader.loadClass(ClassLoader.java:247)
org.springframework.util.ClassUtils.forName(ClassUtils.java:257)
org.springframework.beans.factory.support.AbstractBeanDefinition.resolveBeanClass(AbstractBeanDefinition.java:408)
org.springframework.beans.factory.support.AbstractBeanFactory.doResolveBeanClass(AbstractBeanFactory.java:1271)
org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1242)
Re: class not found, package only [message #803801 is a reply to message #801362] Tue, 21 February 2012 15:53 Go to previous messageGo to next message
Can you try to switch the property "WABHeaders" to "defaulted".
It is located in <Virgo-Home>/repository/ext/org.eclipse.virgo.web.properties file.
Restart Virgo and redeploy the application.
Let me know whether this helps.
Re: class not found, package only [message #804137 is a reply to message #803801] Wed, 22 February 2012 03:42 Go to previous messageGo to next message
I just tried to change to property value to "defaulted", but this time, the other class not found exception threw:
exception
root cause
org.springframework.beans.factory.BeanCreationException: Error creating bean with name '/helloService' defined in ServletContext resource [/WEB-INF/remoting-servlet.xml]: Instantiation of bean failed; nested exception is java.lang.NoClassDefFoundError: com/caucho/hessian/io/HessianDebugInputStream
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:965)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:911)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:580)
root cause
java.lang.Class.getDeclaredConstructors0(Native Method)
java.lang.Class.privateGetDeclaredConstructors(Class.java:2389)
java.lang.Class.getConstructor0(Class.java:2699)
java.lang.Class.getDeclaredConstructor(Class.java:1985)
org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:65)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:958)
root cause
org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.caucho.hessian.io.HessianDebugInputStream in KernelBundleClassLoader: [bundle=org.springframework.web_3.0.5.RELEASE]
org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:138)
root cause
java.lang.ClassNotFoundException: com.caucho.hessian.io.HessianDebugInputStream
org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:134)
Re: class not found, package only [message #804353 is a reply to message #804137] Wed, 22 February 2012 09:27 Go to previous messageGo to next message
Do you have in your Web-inf/lib folder, a jar file that provides "com.caucho.hessian.io"?
You have to have such jar file locally (in Web-inf/lib), or you have to have such bundle installed on the system and also an import package in the web application's manifest for the necessary package.
[Updated on: Wed, 22 February 2012 09:31] by Moderator
Re: class not found, package only [message #804920 is a reply to message #804353] Thu, 23 February 2012 01:27 Go to previous messageGo to next message
I have downloaded a hession-4.0.7.jar and placed it to the WEB-INF/lib folder in my project, redeploy it and restart virgo, but the problem still exists.
Re: class not found, package only [message #804952 is a reply to message #804920] Thu, 23 February 2012 02:17 Go to previous messageGo to next message
Can you tell us what is the output of the "clload" command - more information for command usage you can find here: http://wiki.eclipse.org/Virgo/FAQ#How_can_I_diagnose_class_loading_problems.3F
Re: class not found, package only [message #804989 is a reply to message #804952] Thu, 23 February 2012 03:10 Go to previous messageGo to next message
The output is:
no bundle exports class [com.caucho.hessian.io.HessianDebugInputStream]
Re: class not found, package only [message #805001 is a reply to message #804989] Thu, 23 February 2012 03:23 Go to previous messageGo to next message
did you execute "clload" or "clexport"?
Re: class not found, package only [message #805021 is a reply to message #804989] Thu, 23 February 2012 03:56 Go to previous messageGo to next message
I am sorry, the output of clload is:
Successfully loaded [com.caucho.hessian.HessianDebugInputStream] from:
108 hello-world
Re: class not found, package only [message #805842 is a reply to message #805021] Fri, 24 February 2012 02:58 Go to previous messageGo to next message
Can you give me a sample example for further investigation or I can use the attached one?
Re: class not found, package only [message #806483 is a reply to message #805842] Fri, 24 February 2012 21:17 Go to previous messageGo to next message
According to your opinions, I have added an hessian jar into the WEB-INF/lib folder in the project, the project has been re-exported as the following attachment for future investigation.
Re: class not found, package only [message #952283 is a reply to message #806483] Sun, 21 October 2012 06:14 Go to previous message
I have tried with recent virgo 3.5.0 release, but the problem still exists.
Previous Topic:Virgo as Windows Service
Next Topic:OSGi manifests for Spring 3.2 (Java 7 users please note)
Current Time: Sat Jul 26 10:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.15618 seconds
