Home » Archived » M2M (model-to-model transformation) » Error ATL launch with Ant tasks
Error ATL launch with Ant tasks [message #80113] Mon, 28 April 2008 08:21 Go to next message
Originally posted by: amivi.fagbegnon.gmail.com
I am trying to use ATL 2006 from CVS. To launch my transformation I use
ant tasks and I have errors below :
transform:
[am3.atl] Executing ATL transformation SFD2CAProto.atl
[am3.atl] GRAVE: Fatal error reading .asm file: line 669:3: The
element type "div" must be terminated by the matching end-tag "</div>".
[am3.atl] org.xml.sax.SAXParseException: The element type "div" must
[am3.atl] at
org.eclipse.m2m.atl.engine.vm.ASMXMLReader.fatalError(ASMXML Reader.java:129)
[am3.atl] at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(ErrorHandlerWrapper.java:218)
[am3.atl] at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:386)
[am3.atl] at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:316)
[am3.atl] at
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(XMLScanner.java:1438)
[am3.atl] at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.jav a:1219)
[am3.atl] at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1685)
[am3.atl] at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
[am3.atl] at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
[am3.atl] at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
[am3.atl] at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
[am3.atl] at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
[am3.atl] at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
[am3.atl] at javax.xml.parsers.SAXParser.parse(SAXParser.java:176)
[am3.atl] at
org.eclipse.m2m.atl.engine.vm.ASMXMLReader.read(ASMXMLReader .java:48)
[am3.atl] at
org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:143)
[am3.atl] at
org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
[am3.atl] at
org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
[am3.atl] at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:434)
[am3.atl] at
org.eclipse.gmt.am3.tools.ant.tasks.ATLModelTransformationTa sk.execute(ATLModelTransformationTask.java:150)
[am3.atl] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
[am3.atl] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[am3.atl] at
[am3.atl] at
[am3.atl] at java.lang.reflect.Method.invoke(Method.java:585)
[am3.atl] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
[am3.atl] at org.apache.tools.ant.Task.perform(Task.java:348)
[am3.atl] at org.apache.tools.ant.Target.execute(Target.java:357)
[am3.atl] at
org.apache.tools.ant.Target.performTasks(Target.java:385)
[am3.atl] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
[am3.atl] at
org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
[am3.atl] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[am3.atl] at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
[am3.atl] at
org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
[am3.atl] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
[am3.atl] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
Method)
[am3.atl] at
[am3.atl] at
[am3.atl] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:377)
[am3.atl] at
org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:230)
[am3.atl] at java.lang.Thread.run(Thread.java:595)
[am3.atl] GRAVE: null
[am3.atl] java.lang.NullPointerException
[am3.atl] at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.getExtent(AS MEMFModel.java:442)
[am3.atl] at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.initClassifi ersInAllExtents(ASMEMFModel.java:112)
[am3.atl] at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.getClassifie r(ASMEMFModel.java:90)
[am3.atl] at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.findModelEle ment(ASMEMFModel.java:162)
[am3.atl] at
org.eclipse.m2m.atl.engine.vm.ASMExecEnv.parseTypeInternal(A SMExecEnv.java:152)
[am3.atl] at
org.eclipse.m2m.atl.engine.vm.ASMExecEnv.parseType(ASMExecEn v.java:114)
[am3.atl] at
org.eclipse.m2m.atl.engine.vm.ASMExecEnv.registerOperations( ASMExecEnv.java:81)
[am3.atl] at
org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:156)
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
Method)
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.atl] at
Method)
[am3.atl] at
[am3.atl] at
[am3.atl] at
[am3.saveModel] Saving model CAmodel
Does somebody know what is the problem?
Re: Error ATL launch with Ant tasks [message #80175 is a reply to message #80113] Mon, 28 April 2008 10:50 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Amivi,
Amivi FAGBEGNON a écrit :
> Hello,
> transform:
It seems that your compiled ATL transformation (i.e. your .asm file) is
not correct. Are you sure your transformation has been compiled without
any error?
Hugo
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> Method)
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> Method)
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> Method)
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
> Method)
> [am3.atl] at
> [am3.atl] at
> [am3.atl] at
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: Error ATL launch with Ant tasks [message #80432 is a reply to message #80175] Tue, 29 April 2008 11:07 Go to previous messageGo to next message
Hi Hugo,
It was the first thing I thaught and I took all my rules and helpers into
comments but I get the same Error.
May be it's about the plugins. Indeed I have an error in ATL builder
plugin (RC2 version from CVS). It's in the manifest. The org.antlr.runtime
package in the export-packages list doesn't exist in the plugin.I put
antlr libraries but I still have this error...
Thank you for your help.
Re: Error ATL launch with Ant tasks [message #80497 is a reply to message #80432] Wed, 30 April 2008 03:35 Go to previous message
Now I don't have any problem with plugins. After tests, I find that it's
about the usage of XML library. Here is my ant tasks :
<project name="SFD2CAProto" default="loadModels">
<target name="loadModels">
<am3.loadModel modelHandler="EMF" name="KM3" metamodel="MOF"
nsUri="uri:http://www.eclipse.org/gmt/2005/KM3"/>
<am3.loadModel modelHandler="EMF" name="XML" metamodel="MOF"
path="../Metamodeles/XML.ecore"/>
<am3.loadModel modelHandler="EMF" name="UML2" metamodel="MOF"
nsUri="uri:http://www.eclipse.org/uml2/2.1.0/UML"/>
<!--<am3.loadModel modelHandler="EMF" name="Parameters" metamodel="XML"
path="../Modeles/Parametres/parametresProto-XML.ecore"/>-- >
<am3.loadModel modelHandler="EMF" name="Params" metamodel="XML"
path="../Modeles/Parametres/parametresProto.xml">
<injector name="xml"/>
</am3.loadModel>
<am3.loadModel modelHandler="EMF" name="InModel" metamodel="UML2"
path="../Modeles/Bibliothèque/SpecificationsFonctionnelles.uml "/>
<am3.loadModel modelHandler="EMF" name="ProfileMAP" metamodel="UML2"
path=" ../Metamodeles/Profiles/Conception/ProfileConceptionApplicat iveMAP.uml "/>
<am3.loadModel modelHandler="EMF" name="ProfileMAS" metamodel="UML2"
path=" ../Metamodeles/Profiles/Conception/ProfileConceptionApplicat iveMAS.uml "/>
</target>
<target name="transform" depends="loadModels">
<am3.atl path="SFD2CAProto.atl">
<inModel name="SFD" model="InModel"/>
<inModel name="PROMAS" model="ProfileMAS"/>
<inModel name="PROMAP" model="ProfileMAP"/>
<inModel name="UML2" model="UML2"/>
<inModel name="Parameters" model="Params"/>
<inModel name="XML" model="XML"/>
<library name="XMLHelpers" path="/Librairies/XMLHelpers.asm"/>
<outModel name="CA" model="CAmodel" metamodel="UML2"/>
</am3.atl>
<mkdir dir="../Output-proto/" />
<eclipse.refreshLocal resource="SFD2CA" depth="infinite" />
<am3.saveModel model="CAmodel" path="../Output-proto/CAmodel.uml"/>
</target>
</project>
When I delete "<library name="XMLHelpers"
path="/Librairies/XMLHelpers.asm"/>" I don't have errors...
Previous Topic:Generate UML2 model using api
Next Topic:[ATL] Generating output using two meta-models
Current Time: Fri Jul 18 17:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.04410 seconds
