Home » Modeling » UML2 » If stereotype B is a generalization of stereotype A, does B inherit the meta-class(In Eclipse UML2 3.1, if stereotype B is a generalization of stereotype A, does B inherit the meta-class extension of A?)
If stereotype B is a generalization of stereotype A, does B inherit the meta-class [message #800892] Fri, 17 February 2012 11:48 Go to next message
Until recently I was using an older version of Eclipse UML2 (2.4) where this worked. After updating to Eclipse UML2 3.1, I receive an IllegalArgumentException when attempting to apply a stereotype generalized from another stereotype to an element of the appropriate extended meta-class. Stepping through the eclipse uml source showed that the attribute "base_Class" was missing in the underlying Ecore model for the stereotype.
Java test code:
    // Init a resource set to load the standard UML profiles
    ResourceSet rset = null;
      rset = new ResourceSetImpl();
      rset.getPackageRegistry().put("...", UMLPackage.eINSTANCE); // Forum filter prevents me from posting this: h_t_t_p_:_/_/www.eclipse.org/uml2/3.0.0/UML
      // Register the UML resource factory
      rset.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
      // Get one of the standard profiles to build a jar path
      final URL url = ClassLoader.getSystemResource("profiles/UML2.profile.uml");
      if(url == null) {
        throw new RuntimeException("Could not load 'profiles/UML2.profile.uml' from class path");
      // Need the jarfile path so chop off the file specific stuff
      final String path = url.toExternalForm().split("!")[0] + "!/";
      // Build a uri for this path
      final URI baseURI = URI.createURI(path);
      // Build mappings from 'pathmap://UML_PROFILES' (or metamodels or libraries) to the point at the jarfile path
      final Map<URI,URI> uriMap = rset.getURIConverter().getURIMap();
      // pathmap://UML_PROFILES
      uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), baseURI.appendSegment("libraries").appendSegment(""));
      // pathmap://UML_LIBRARIES
      uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), baseURI.appendSegment("metamodels").appendSegment(""));
      uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), baseURI.appendSegment("profiles").appendSegment(""));
    // Load the test profile
    Profile test = null;
      final URL url = ClassLoader.getSystemResource("profiles/test.profile.uml");
      if(url == null) {
        throw new RuntimeException("Could not load 'profiles/test.profile.uml' from class path");
      final Resource r = rset.createResource(URI.createURI(url.toExternalForm()));
      r.load(null);
      test = (Profile)EcoreUtil.getObjectByType(r.getContents(), UMLPackage.Literals.PROFILE);
      if(test == null) {
        throw new RuntimeException("Could not load 'profiles/test.profile.uml'");
    Stereotype A = test.getOwnedStereotype("A");
    Stereotype B = test.getOwnedStereotype("B");
    Model m = UMLFactory.eINSTANCE.createModel();
    org.eclipse.uml2.uml.Package pkg = m.createNestedPackage("pkg");
    org.eclipse.uml2.uml.Class c1 = pkg.createOwnedClass("c1", false);
    org.eclipse.uml2.uml.Class c2 = pkg.createOwnedClass("c2", false);
    pkg.applyProfile(test);
    c1.applyStereotype(A);
    c2.applyStereotype(B); // throws IllegalArgumentException
Test profile is attached.
Re: If stereotype B is a generalization of stereotype A, does B inherit the meta-class [message #803776 is a reply to message #800892] Tue, 21 February 2012 14:56 Go to previous message
Hi Lance,
This should work perfectly fine. B does inherit the extension and applying
the stereotypes should work.
> the stereotype.
You can see in your test.profile.uml that the base_Class property is there
in the ecore model.
I ran your example code and only had to adjust the base URI part a bit
because in my setup, the models were not found on the system classpath.
After that, your code worked perfectly for me with Eclipse UML2 3.2.100.
Carsten
Previous Topic:3rd Biannual Eclipse/OMG Workshop on March 25
Next Topic:Sources for current Indigo 3.2.100 version in git
Current Time: Thu Jul 24 16:44:46 EDT 2025
Powered by FUDForum. Page generated in 0.05451 seconds
