Home » Eclipse Projects » Eclipse Platform » DocumentProvider for external opened files
DocumentProvider for external opened files [message #795295] Fri, 10 February 2012 04:49 Go to next message
Hi!
Does anyone know a way to connect own documentproviders with external files in Eclipse?
My plugin.xml looks like
<extension point="org.eclipse.ui.editors.documentProviders">
  <provider
    class="my.path.to.tbpl.documentprovider.TBPLDocumentProvider"
    extensions="tbpl"
    id="my.path.to.tbpl.documentprovider.TBPLDocumentProvider">
  </provider>
</extension>
If I open a file (IFile/ FileEditorInput) located in the workspace all will work fine.
But if I open a file outside the workspace, the default documentprovider (TextFileDocumentProvider) is opened.
The problem is, that the DocumentProviderRegistry computes only the file extension if the input is an IFile. For IFileStore it looks only at the class name of the input.
Therefore I extended my documentprovider extensionpoint to
inputTypes="org.eclipse.ui.IFileEditorInput,org.eclipse.ui.ide.FileStoreEditorInput"
Now it will work.
But now the documentprovider is used for every file located in and outside the workspace. (That means all files, not only *.tbpl would use the documentprovider).
So my question is: is it possible to create an own EditorInput (like an IEditorInputProvider) to connect the documentProvider with? Or does anyone know how to do some stuff like this?
Or is it a bug in eclipse, that the file extensions are only used for "IFile" and not for "IFileStore"
Thanks!
Adreamus
Re: DocumentProvider for external opened files [message #800666 is a reply to message #795295] Fri, 17 February 2012 05:34 Go to previous messageGo to next message
On 10.02.2012 10:49, Adreamus Mising name wrote:
> Hi!
> files in Eclipse?
> <provider
> extensions="tbpl"
> </provider> </extension>
> will work fine.
> Now it will work.
The easiest is to set your document provider inside your editor
constructor by calling
org.eclipse.ui.texteditor.AbstractTextEditor.setDocumentProvider(IDocumentProvider).
Dani
> Thanks!
> Adreamus
Re: DocumentProvider for external opened files [message #800823 is a reply to message #800666] Fri, 17 February 2012 09:55 Go to previous messageGo to next message
but that is not possible, because I use the document provider with given editors (css/html/ text...) and not with an created one.
Re: DocumentProvider for external opened files [message #800881 is a reply to message #800823] Fri, 17 February 2012 11:20 Go to previous message
Well, I guess you should not try to fiddle with the document provider of
existing editors.
Dani
Previous Topic:icon decoration order for content type
Next Topic:Eclipse on small devices
Current Time: Wed Jul 23 05:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.13563 seconds
