Home » Eclipse Projects » Eclipse 4 » Bug in org.eclipse.e4.core.di?
Bug in org.eclipse.e4.core.di? [message #799464] Wed, 15 February 2012 18:22 Go to next message
I first posted this question in the equinox forum, but now I suspect it may be a bug in e4.
I get the following exception
org.eclipse.e4.core.di.InjectionException: Unable to process "WorkbenchStatusReporter.shellProvider": no actual value was found for the argument "IShellProvider".
The problem can be traced down to the following piece of code
@Inject
private ConfigurationAdmin fConfigAdmin;
that is located in a dialog DBLocationDialog, which is opened through a menu-handler, as given here
public class DBLocationHandler {
	@Execute
	public void execute(IEclipseContext context) {
		DBLocationDialog dialog = ContextInjectionFactory.make(DBLocationDialog.class, context);
		dialog.open();
As written in my post cited above, the problem only occurs, when the configuration admin bundle is started with default startlevel and default auto-start. When that bundle is started with auto-start true, the exception is not thrown, i.e. the injection in the dialog succeeds.
Now I get the same exception with a test component of mine. The code causing the exception is again
@Inject
private ITest fTest;
The interface is implemented through a lazily activating component. At first, the service ITest is not used, as shown in the osgi console
{de.trm.app.ITest}={component.name=de.trm.app.Component, component.id=9, service.id=43}
"Registered by bundle:" de.trm.app_1.0.0.qualifier [53]
"No bundles using service."
The component is not activated yet. When the same dialog is called through the same menu-handler, the same exception occurs, but the component is activated right before:
osgi> $$$ COMPONENT STARTING
The text "$$$ COMPONENT STARTING" is written to System.out in the Activate-method of the test component. Now the osgi console says
  "Bundles using service"
    org.eclipse.e4.ui.workbench_0.10.1.v20120126-1604 [48]
Since e4 is now using this component, why fails the injection of ITest? To me it looks as if it is a bug in e4.
Well, I am using 4.2M5 as Target.
Re: Bug in org.eclipse.e4.core.di? [message #799478 is a reply to message #799464] Wed, 15 February 2012 18:48 Go to previous messageGo to next message
Please file a bug with a reproduceable testcase.
Tom
Am 16.02.12 00:22, schrieb Karl Weber:
> I first posted this http://www.eclipse.org/forums/index.php/t/289108/ in
> @Inject
> @Execute
> dialog.open();
> @Inject
> service.id=43}
> service.id=43}
Re: Bug in org.eclipse.e4.core.di? [message #800082 is a reply to message #799478] Thu, 16 February 2012 12:06 Go to previous messageGo to next message
org.eclipse.e4.core.di.InjectionException: Unable to process "WorkbenchStatusReporter.shellProvider": no actual value was found for the argument "IShellProvider" was an issue in M5 and should be solved with https://bugs.eclipse.org/bugs/show_bug.cgi?id=370214.
I suggest you try the latest I-build.
Best regards, Lars
[Updated on: Thu, 16 February 2012 12:06] by Moderator
Re: Bug in org.eclipse.e4.core.di? [message #800254 is a reply to message #800082] Thu, 16 February 2012 16:36 Go to previous messageGo to next message
Lars Vogel wrote on Thu, 16 February 2012 18:06
Best regards, Lars
Yes, but the bug you cited is not the problem. I tried the same with the platform as target, which is 4.2-I20120209. I got another exception showing explicitly, that the injection failed, see the attached screenshot. So the exception only provides better information now, but we learned nothing we didn't know before.
I will try to create a minimal example to reproduce the error and file a bug.
index.php/fa/7192/0/
[Updated on: Thu, 16 February 2012 16:42] by Moderator
Re: Bug in org.eclipse.e4.core.di? [message #800262 is a reply to message #800254] Thu, 16 February 2012 16:51 Go to previous messageGo to next message
@Karl: yes this error was masking other errors, I thought that was your complained.
From what I can see, the current behavior of Eclipse is correct for your example. The bundle which declares a service must be activated before DI tries to inject it. Otherwise its not yet available and an error message is thrown.
As far as I know bundles which define services must be activated before there injection.
Re: Bug in org.eclipse.e4.core.di? [message #800267 is a reply to message #800254] Thu, 16 February 2012 17:00 Go to previous messageGo to next message
Sorry, I have to correct myself. One should think first and write later... The Configuration Admin does not seem to be part of the platform, so this injection must clearly fail.
However, once I make the injection of the Config Admin @Optional, no further problem occurs, which means, the injection of my test component works. Hence, the bug you cited seems to have indeed been the cause of my problem.
So I need a link to the I20120209 build for my target definition. Could you help me? Currently I am using http://download.eclipse.org/releases/juno
Furthermore I need the delta.pack. Can I use the delta.pack from 3.8M5 with 4.2-I20120209? Otherwise I would need another link...
Re: Bug in org.eclipse.e4.core.di? [message #800268 is a reply to message #800262] Thu, 16 February 2012 17:02 Go to previous messageGo to next message
@Karl: - put this code (enabled="true" immediate="true") in your component description (<scr:component ...), you can try to add servicefactory=true - and you DS bundle started automatically at osgi core start level
Re: Bug in org.eclipse.e4.core.di? [message #800269 is a reply to message #800267] Thu, 16 February 2012 17:03 Go to previous messageGo to next message
Sorry, don't know these links.
Maybe someone else?
Re: Bug in org.eclipse.e4.core.di? [message #800272 is a reply to message #800262] Thu, 16 February 2012 17:06 Go to previous messageGo to next message
Lars Vogel wrote on Thu, 16 February 2012 22:51
I don't think so and this would indeed mean, that all components would have to be activated in advance -- so no lazy loading at all. This would really surprise me. My test component is indeed only registered but not activated, i.e. the Activate-method has not been called. It is activated at the moment I call the dialog, which should be the expected behaviour.
Re: Bug in org.eclipse.e4.core.di? [message #800276 is a reply to message #800268] Thu, 16 February 2012 17:10 Go to previous messageGo to next message
@Karl: With @Optional you are telling the framework that null is ok. In this case the service is not required to be started. Otherwise I think it is.
Re: Bug in org.eclipse.e4.core.di? [message #800605 is a reply to message #800269] Fri, 17 February 2012 04:12 Go to previous messageGo to next message
Lars Vogel wrote on Thu, 16 February 2012 23:03
Just for the record, the link http://download.eclipse.org/eclipse/updates/4.2-I-builds seems to be what I need. It seems I can use this together with the delta.pack from 3.8M5 and the actual version of the config admin. At least I didn't get any problems so far.
Re: Bug in org.eclipse.e4.core.di? [message #801530 is a reply to message #800605] Sat, 18 February 2012 09:57 Go to previous message
Karl Weber wrote on Fri, 17 February 2012 04:12
That's right. You can also get the delta pack (the launchers + SWT) from
http://download.eclipse.org/eclipse/updates/3.8-I-builds
Previous Topic:@Preference(value="data") as value for other Annotation
Next Topic:RCP can not say hello world
Current Time: Sat Jul 26 23:20:14 EDT 2025
Powered by FUDForum. Page generated in 0.35191 seconds
