[Texo] Best way to add JPA implementor specific annotation to generated entities [message #799749] |
Thu, 16 February 2012 04:14  |
Hi all,
I need to add Hibernate specific content to the code of the generated
entities.
With Texo, to customize the id generation, I can get :
@Id()
@GeneratedValue(generator = "CustomIdGenerator", strategy =
GenerationType.AUTO)
private Long id = null;
What I want is :
@Id()
@GenericGenerator(name = "CustomIdGenerator", strategy =
"com.my.company.entities.CustomIdGenerator")
(GenericGenerator being Hibernate specific)
What is the best solution to achieve this ? Do I have to use
@generatedNOT on my property called id ?
Thank you.
Re: [Texo] Best way to add JPA implementor specific annotation to generated entities [message #799914 is a reply to message #799749] |
Thu, 16 February 2012 08:12   |
Hi Benoit,
Yes generatedNot indeed. Or afaik hibernate allows you to add extra mappings through the orm.xml. So in this case let
Texo generate the code as in your first example and then add the GenericGenerator using a separate manual orm.xml. The
hibernate docs can tell you more if this is possible (I believe so).
gr. Martin
On 02/16/2012 10:14 AM, Benoit Cantin wrote:
> Hi all,
> I need to add Hibernate specific content to the code of the generated entities.
> @Id()
> @GeneratedValue(generator = "CustomIdGenerator", strategy = GenerationType.AUTO)
> What I want is :
> @Id()
> @GenericGenerator(name = "CustomIdGenerator", strategy = "com.my.company.entities.CustomIdGenerator")
> What is the best solution to achieve this ? Do I have to use @generatedNOT on my property called id ?
> Thank you.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Texo] Best way to add JPA implementor specific annotation to generated entities [message #799930 is a reply to message #799914] |
Thu, 16 February 2012 08:26  |
On 02/16/2012 02:12 PM, Martin Taal wrote:
> Hi Benoit,
> mappings through the orm.xml. So in this case let Texo generate the code
> separate manual orm.xml. The hibernate docs can tell you more if this is
Thank you Martin. generatedNOT, will be set on a part of the code that
won't change much in the near future. So I am going to use it here.
Benoit
> gr. Martin
>> Hi all,
>> entities.
>> @Id()
>> What I want is :
>> @Id()
>> Thank you.
FUDForum. Page generated in 0.24917 seconds
