Home » Eclipse Projects » Remote Application Platform (RAP) » Dialog Frozen Behavior
Dialog Frozen Behavior [message #793943] |
Wed, 08 February 2012 14:05  |
the modal dialogs functionality of 1.5M5 is awkward.
when either button of the dialog event is called, the dialog disappears, but the modal nature remains, meaning the UI is frozen.
following is the code snippet which uses the message dialog :
final MessageDialog dialog = new MessageDialog(_toolBar.getShell(),
"Delete Confirmation", null,
"Do you wish to delete this record [y/n] ?",
MessageDialog.QUESTION, new String[] { "Yes", "No", "Cancel" },
2);
final int answer = dialog.open();
switch (answer) {
case -1:
/* no selection provided */
break;
case 0:
/* dialog action - yes */
final boolean status = runAction(ClientsideActionsContributor.ON_BEFORE_DELETE_RECORD_EVENT);
if (status) {
((DatasetController) getDatasetBroadcast())
.setActionState(BusinessObject.ACTION_DELETE);
((DatasetController) getDatasetBroadcast()).performDelete();
refreshRecordAction();
runAction(ClientsideActionsContributor.ON_AFTER_DELETE_RECORD_EVENT);
break;
case 1:
/* dialog action - no */
break;
case 2:
/* dialog action - cancel */
break;
the above code snippet did work as expected in 1.4, but with 1.5M5 the dialog's modal behavior remains, even after closing the dialog.
i also have custom dialogs like "SetupCustomEditorDialog" extends the Dialog, which works as expected with modal behavior in 1.5M5. (after closing the dialog, UI become responsive)
also, if i refresh the page while frozen after the dialog, i get the following errors in console :
osgi> 2012-02-08 23:59:10.446:INFO:oejs.Server:jetty-8.1.0.RC4
2012-02-08 23:59:14.045:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:50140 STARTING
diff - -132
2012-02-09 00:00:55.714:WARN:/:ERROR: Exception while executing dispose-listener.
java.lang.UnsupportedOperationException
at org.eclipse.rwt.internal.lifecycle.FakeContextUtil$RequestInvocationHandler.invoke(FakeContextUtil.java:119)
at $Proxy2.getParameter(Unknown Source)
at org.eclipse.rwt.internal.textsize.MeasurementOperator.requestContainsMeasurementResult(MeasurementOperator.java:154)
at org.eclipse.rwt.internal.textsize.MeasurementOperator.addItemToMeasure(MeasurementOperator.java:87)
at org.eclipse.rwt.internal.textsize.MeasurementUtil.addItemToMeasure(MeasurementUtil.java:68)
at org.eclipse.rwt.internal.textsize.TextSizeUtil.addItemToMeasure(TextSizeUtil.java:125)
at org.eclipse.rwt.internal.textsize.TextSizeUtil.determineTextSize(TextSizeUtil.java:84)
at org.eclipse.rwt.internal.textsize.TextSizeUtil.stringExtent(TextSizeUtil.java:33)
at org.eclipse.rwt.graphics.Graphics.stringExtent(Graphics.java:330)
at org.eclipse.swt.widgets.Button.computeSize(Button.java:392)
at org.eclipse.jface.dialogs.Dialog.setButtonLayoutData(Dialog.java:934)
at org.eclipse.jface.dialogs.Dialog.createButton(Dialog.java:619)
at org.eclipse.jface.dialogs.MessageDialog.createButton(MessageDialog.java:486)
at org.eclipse.jface.dialogs.MessageDialog.createButtonsForButtonBar(MessageDialog.java:231)
at org.eclipse.jface.dialogs.IconAndMessageDialog.createButtonBar(IconAndMessageDialog.java:172)
at org.eclipse.jface.dialogs.IconAndMessageDialog.createDialogAndButtonArea(IconAndMessageDialog.java:219)
at org.eclipse.jface.dialogs.IconAndMessageDialog.createContents(IconAndMessageDialog.java:198)
at org.eclipse.jface.window.Window.create(Window.java:444)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1071)
at org.eclipse.jface.window.Window.open(Window.java:806)
at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.java:334)
at com.wface.entrypoint._rap.ApplicationWorkbenchAdvisor.preShutdown(ApplicationWorkbenchAdvisor.java:47)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1075)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1072)
at org.eclipse.ui.internal.Workbench$22.run(Workbench.java:1338)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1336)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1298)
at org.eclipse.ui.internal.Workbench$ShutdownHandler.handleEvent(Workbench.java:388)
at org.eclipse.swt.widgets.Display.sendDisposeEvent(Display.java:703)
at org.eclipse.swt.widgets.Display.release(Display.java:680)
at org.eclipse.swt.graphics.Device.dispose(Device.java:287)
at org.eclipse.rwt.internal.lifecycle.UIThread.processShutdown(UIThread.java:166)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:297)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:101)
!SESSION 2012-02-08 23:59:08.124 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -dev file:C:/accbldr/ws/.metadata/.plugins/org.eclipse.pde.core/accbldr/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console -data C:\accbldr\ws/.metadata/.plugins/org.eclipse.rap.ui.launch/accbldr
!ENTRY org.eclipse.ui.workbench 4 0 2012-02-09 00:00:55.731
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:175)
at org.eclipse.swt.events.DisposeEvent.dispatchToObserver(DisposeEvent.java:63)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.java:46)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.java:166)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:774)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:830)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:777)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1097)
at org.eclipse.swt.widgets.Display.disposeShells(Display.java:717)
at org.eclipse.swt.widgets.Display.release(Display.java:681)
Is this a bug in 1.5M5 ? Kindly advise me how to resolve.
Sudesh
[Updated on: Wed, 08 February 2012 14:16] by Moderator
Re: Dialog Frozen Behavior [message #793975 is a reply to message #793943] |
Wed, 08 February 2012 14:47   |
Hi Sudesh,
I think that you are running into this bug:
370139: [Dialog] Modal dialog blocks application upon close
https://bugs.eclipse.org/bugs/show_bug.cgi?id=370139
Could you attach your test snippet there? A complete self-running
snippet is welcomed.
Ivan
On 2/8/2012 9:05 PM, Sudesh Bulathsinhala wrote:
> Hello,
> the modal dialogs functionality of 1.5M5 is awkward. when either
> "Cancel" },
> 2);
> switch (answer) {
> case -1:
> break;
> case 0:
> if (status) {
> break;
> case 1:
> break;
> case 2:
> break;
> diff - -132
> dispose-listener.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> Regards,
> Sudesh
Ivan Furnadjiev
Twitter: @EclipseRAP
Current Time: Sat Jul 19 04:12:09 EDT 2025
Powered by FUDForum. Page generated in 0.04546 seconds
