Home » Archived » BIRT » Eclipse IDE and Birt is fine but...(how to add birt to target platform)
Eclipse IDE and Birt is fine but... [message #798995] Wed, 15 February 2012 05:09 Go to next message
i am able to run the report designer in my ide.
but when i export my rcp application birt does not get "exported"
although i added all org.eclipse.birt plugins on my target platform
i can still not switch to "org.eclipse.birt.report.designer.ui.ReportPerspective"
tried all on default.
also tried to autostart the core and the report.designer.ui but then i run into exceptions.
installing birt into the rcp ide was easy, exporting my application drives me crazy.
iff there is a document how to do it let me know.
note: the viewer works! its the designer that does not work (yet)
Re: Eclipse IDE and Birt is fine but... [message #799073 is a reply to message #798995] Wed, 15 February 2012 07:12 Go to previous messageGo to next message
iff i open the file in my rcp in the resource explorer
i get the information that the content type is not assigned BUT it opens without any errors in the editor! so the file is correct...
[Updated on: Wed, 15 February 2012 07:19] by Moderator
Re: Eclipse IDE and Birt is fine but... [message #799074 is a reply to message #798995] Wed, 15 February 2012 07:12 Go to previous messageGo to next message
ok finally i got the designer running too, and i am able to switch to the designer perpective programmatically
but when i try to open an rptdesign file (located somewhere outside the workspace in a directory) by code
here is the code to open the editor:
final File file = new File(staticReport);
		SwitchPerspective.to(birtReportPerspective); // switch to the correct perspective
		IWorkbenchPage page = getActivePage();
		IEditorInput input = new IEditorInput() {
			public Object getAdapter(Class adapter) {
				return file;
			public String getToolTipText() {
				return "Generated Template Report " + file.getAbsolutePath();
			public IPersistableElement getPersistable() {
				return null;
			public String getName() {
				return file.getName();
			public ImageDescriptor getImageDescriptor() {
				return null;
			public boolean exists() {
				System.out.println(file.getAbsolutePath() + " exists = "
						+ file.exists());
				return file.exists();
		try {
			page.openEditor(input,
					"org.eclipse.birt.report.designer.ui.editors.ReportEditor");
		} catch (Exception e) {
			e.printStackTrace();
and here the exception:
java.lang.ClassCastException: java.io.File cannot be cast to org.eclipse.core.resources.IFile
at org.eclipse.birt.report.designer.internal.ui.util.UIUtil.getProjectFromInput(UIUtil.java:2506)
at org.eclipse.birt.report.designer.ui.editors.MultiPageReportEditor.init(MultiPageReportEditor.java:346)
at org.eclipse.birt.report.designer.ui.editors.ReportEditorProxy.init(ReportEditorProxy.java:124)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at ...
Re: Eclipse IDE and Birt is fine but... [message #799269 is a reply to message #799074] Wed, 15 February 2012 12:17 Go to previous messageGo to next message
Ludwig,
Take a look at this thread:
http://www.eclipsezone.com/eclipse/forums/m92221730.html
Jason
Re: Eclipse IDE and Birt is fine but... [message #799656 is a reply to message #799269] Thu, 16 February 2012 01:24 Go to previous messageGo to next message
maybe the problem is that the file is out of workspace (i store my reports in user home subdirectory)
when i use the transformation to ifile noted at your link i run into nullpointer
at org.eclipse.birt.report.designer.ui.editors.MultiPageReportEditor.addPages(MultiPageReportEditor.java:377)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEditor.java:138)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.birt.report.designer.ui.editors.ReportEditorProxy.createPartControl(ReportEditorProxy.java:138)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
so after this failed i tried to create a project in my workspace "External Files" and add a link to the external file so i can create an ifile from that by:
public IFile getIFile(String fileName) {
		IWorkspace ws = ResourcesPlugin.getWorkspace();
		IProject project = ws.getRoot().getProject("External Files");
		try {
			if (!project.exists()) {
				project.create(null);
			if (!project.isOpen()) {
				project.open(null);
		} catch (CoreException e) {
		IPath location = new Path(fileName);
		IFile file = project.getFile(location.lastSegment());
		try {
			file.createLink(location, IResource.FILE, null);
		return file;
still resolves to a nullpointer.
any ideas?
[Updated on: Thu, 16 February 2012 01:47] by Moderator
Re: Eclipse IDE and Birt is fine but... [message #800181 is a reply to message #799656] Thu, 16 February 2012 14:46 Go to previous message
can you not put the file in the workspace?
Jason
> nullpointer
> Quote:
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
>> at
>> at
>> at
Previous Topic:How to show series labels only for the last value
Next Topic:Two grouping levels
Current Time: Fri Jul 25 07:27:57 EDT 2025
Powered by FUDForum. Page generated in 0.07614 seconds
