Home » Archived » M2M (model-to-model transformation) » [ATL]problems with called rules
[ATL]problems with called rules [message #79677] Mon, 21 April 2008 13:30 Go to next message
Hello all, i have a problem with this ATL code. The scope of this program is
to derive the references from one class to all subclasses.
Where is the problem?
Is possible to generate an target model with a helper?
Where is the guide to use lazy-rules?
Thanks in advance
Migert Kapaj
create OUT : KM3 from IN : KM3;
helper def: relazioni(inp : KM3!Reference) : Set(KM3!Reference) =
thisModule.all_subclasses(inp.owner)->iterate(iter; acc:
Set(KM3!Reference)=Set{} |
acc->union(Set{thisModule.creaRelazione(inp,iter,inp.type)})
rule creaRelazione
from rel: KM3!Reference, owner1: KM3!Class, type1: KM3!Class
to relazione : KM3!Reference(
isContainer <- rel.isContainer,
--opposite <- rel.opposite,
name <- rel.name,--.concat(type.name),
location <- rel.location,
lower <- rel.lower,
upper <- rel.upper,
isOrdered <- rel.isOrdered,
isUnique <- rel.isUnique,
type <- type1,
owner <- owner1
rule CopyReference {
from
s : KM3!Reference(if s.opposite.oclIsUndefined() then
true
else
false
endif
to
t : distinct KM3!Reference foreach(c in
thisModule.relazioni(s))--relazioni(s))
isContainer <- s.isContainer,
--opposite <- c.opposite,
name <- s.name,
location <- s.location,
lower <- s.lower,
upper <- s.upper,
isOrdered <- s.isOrdered,
isUnique <- s.isUnique,
type <- s.type,
owner <- c
.... other rules are OK
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: cannot set feature KM3!Reference.owner to value
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1261ef2 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@1b529d6 (name: Reference)
(instanceClassName: null) (abstract: false, interface: false))
GRAVE: exception:
GRAVE: The value of type 'org.eclipse.emf.ecore.impl.EClassImpl@1b529d6
(name: Reference) (instanceClassName: null) (abstract: false, interface:
false)' must be of type 'org.eclipse.emf.ecore.impl.EClassImpl@7f6155 (name:
Class) (instanceClassName: null) (abstract: false, interface: false)'
java.lang.ClassCastException: The value of type
'org.eclipse.emf.ecore.impl.EClassImpl@1b529d6 (name: Reference)
(instanceClassName: null) (abstract: false, interface: false)' must be of
type 'org.eclipse.emf.ecore.impl.EClassImpl@7f6155 (name: Class)
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleContainer.dynamicSet(EStructuralFeatureIm pl.java:1824)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:1116)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1090)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:264)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:292)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
at
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:155)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
GRAVE: A.main() : ??#24 null
GRAVE: local variables = {self=KM3Pulito : ASMModule}
GRAVE: local stack = []
GRAVE: A.__exec__() : ??#38 null
GRAVE: local variables = {e=TransientLink {rule = 'CopyReference',
sourceElements = {s = IN!literals}, targetElements = {t = Sequence
{OUT!literals}}, variables = {}}, self=KM3Pulito : ASMModule}
GRAVE: A.__applyCopyReference(1 : NTransientLink;) : ??#145 182:8-182:18
GRAVE: local variables = {t=Sequence {OUT!literals}, s=IN!literals,
link=TransientLink {rule = 'CopyReference', sourceElements = {s =
IN!literals}, targetElements = {t = Sequence {OUT!literals}}, variables =
{}}, self=KM3Pulito : ASMModule, c=OUT!literals, collection=Sequence
{OUT!literals, OUT!literals}, counter=1}
GRAVE: local stack = [OUT!literals]
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
GRAVE: cannot set feature KM3!Reference.owner to value
java.lang.RuntimeException: cannot set feature KM3!Reference.owner to value
at
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:267)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.lang.ClassCastException: The value of type
at
at
at
at
at
... 25 more
Re: [ATL]problems with called rules [message #79770 is a reply to message #79677] Tue, 22 April 2008 05:23 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Migert,
> program is to derive the references from one class to all subclasses.
The problem is that you're trying to call a matched rule (which is not
callable) from an helper (which is not possible). Indeed, the goal of an
helper is to navigate the input model(s) in order to retrieve and/or
compute useful information to be used in the rules which build the
output model elements. Thus, you cannot create output model element from
an helper.
You can find from
http://wiki.eclipse.org/ATL_Language_Troubleshooter#ATL_matc hed.2C_called_and_lazy_rules:_differences
more detailed information on lazy rules and on how to call them.
As lazy rules are also declarative ones, it's recommended using them (if
really needed of course).
Hugo
> Thanks in advance
> Migert Kapaj
> rule creaRelazione
> lower <- rel.lower,
> upper <- rel.upper,
> type <- type1,
> owner <- owner1
> from
> true
> else
> false
> endif
> to
> name <- s.name,
> lower <- s.lower,
> upper <- s.upper,
> type <- s.type,
> owner <- c
> GRAVE: exception:
> (name: Class) (instanceClassName: null) (abstract: false, interface:
> false)'
> of type 'org.eclipse.emf.ecore.impl.EClassImpl@7f6155 (name: Class)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> = {}}, self=KM3Pulito : ASMModule, c=OUT!literals, collection=Sequence
> allow continuation after errors).
> value org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1261ef2 (eClass:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 25 more
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL]problems with called rules [message #79890 is a reply to message #79770] Wed, 23 April 2008 10:33 Go to previous message
Hi Hugo, thanks for your answer. The solution of my problem is to use two
foreach statement
foreach( a in thisModule.all_subclasses(source.owner))
for( b in thisModule.all_subclasses(a))
this is possible in atl?
from
true
else
false
endif
to
thisModule.all_subclasses(s.owner))
for(b in thisModule.all_subclasses(s.type))
name <- s.name,
lower <- s.lower,
upper <- s.upper,
type <- b,
owner <- c
Thank you,
Migert
"Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> ha scritto nel messaggio
news:fukaq3$oc0$1@build.eclipse.org...
> Hi Migert,
> compute useful information to be used in the rules which build the output
> model elements. Thus, you cannot create output model element from an
> helper.
> You can find from
> Best regards,
> Hugo
>> Thanks in advance
>> Migert Kapaj
>> rule creaRelazione
>> lower <- rel.lower,
>> upper <- rel.upper,
>> type <- type1,
>> owner <- owner1
>> from
>> true
>> else
>> false
>> endif
>> to
>> name <- s.name,
>> lower <- s.lower,
>> upper <- s.upper,
>> type <- s.type,
>> owner <- c
>> GRAVE: exception:
>> false)'
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 25 more
Previous Topic:[ATL] ATLTransformations
Next Topic:[QVTO]string operations and blackboxes
Current Time: Sat Jul 26 21:03:52 EDT 2025
Powered by FUDForum. Page generated in 0.23127 seconds
