Home » Archived » BIRT » BIRT vs Business Objects vs Crystal Reports
BIRT vs Business Objects vs Crystal Reports [message #79472] Thu, 06 October 2005 06:31 Go to next message
Originally posted by: nospam.nospam.com
Hi all,
we are working on a BI project for a client. Basically we have to pass
some ETL processes to get a clean non-transactional database. We should
start creating complex reports from it. The goal is to develop a system
that enables a user without any IT skills to create a diverse range of
different reports. The system should display a HTML page (JSP, ASP... it
doesn't matter) with loads of combo boxes where the user can select the
fields to match. The final result would be a combination of charts and
lists. Ideally the user should be able to perform some actions with the
data (ie sending a massive mailing campaign)
Can BIRT be enough for this? Any comparison with Business Objects XI
available? Is Crystal Reports Server more powerful than BIRT?
Keep in mind that licensing wouldn't be a problem. We are looking for the
easiest to use tool.
JoSE
Re: BIRT vs Business Objects vs Crystal Reports [message #79546 is a reply to message #79472] Thu, 06 October 2005 10:25 Go to previous messageGo to next message
Originally posted by: dinesh.kulhari.survik.com
Right now BIRT is not that much strong to compare with BusinessObjects.
Bkz Web Intelligence is much more powerfull then BIRT is right now. In
next release BIRT is going to include WEB REPORT DESIGNER and also support
for any semantic layer like BO universe.
One good project is going on in this integraion please chk www.pentaho.org
Dinesh
Jose wrote:
> Hi all,
> JoSE
Re: BIRT vs Business Objects vs Crystal Reports [message #79874 is a reply to message #79472] Fri, 07 October 2005 14:23 Go to previous messageGo to next message
Originally posted by: m.n.com
I don't know about BO but Crystal cannot report off of Java objects. They
say you can but you can only call a java class the returns a recordset.
AFIAK. I did some digging recently on this and that is what I came up
with.
Re: BIRT vs Business Objects vs Crystal Reports [message #80118 is a reply to message #79546] Mon, 10 October 2005 07:56 Go to previous message
Thank you Dinesh,
very interesting info indeed. I've looked into it and it seems quite
complete. And complex. Not ready for production yet though :/
JoSE
Dinesh wrote:
> Hi
> Dinesh
> Jose wrote:
>> Hi all,
>> JoSE
Previous Topic:BIRT 2.0 Project Draft
Next Topic:charts problem
Current Time: Sat Jul 26 04:34:28 EDT 2025
Powered by FUDForum. Page generated in 0.04583 seconds
