Home » Modeling » TMF (Xtext) » Running / Interpret the DSL
Running / Interpret the DSL [message #798439] Tue, 14 February 2012 12:48 Go to next message
[new to xtext - so please bare with me]
OK, so now I have a simple defined DSL with all the features that one can
expect from an IDE!
But how can I re-use this generated infrastructure to actually execute / run
/ interpret my langauge files?
Preferably I would like to be able to execute both from within Eclipse and
from a command line set-up.
Any hint trick suggestion greatly appreciated.
Peter
Re: Running / Interpret the DSL [message #798488 is a reply to message #798439] Tue, 14 February 2012 13:59 Go to previous messageGo to next message
welcome to Xtext.
your question is very unspecific so it is hard to give an answer.
here are some options
(1) you can call your processor when saving the model file e.g. using an IXtextBuilderParticipant
(2) you can call your processor explicitely e.g. like it is done for this code generator http://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-generator-from-a-context-menu/
(3) process your models standalone with a mwe2 workflow or via java app as described here: http://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
~Christian
Re: Running / Interpret the DSL [message #798580 is a reply to message #798488] Tue, 14 February 2012 16:27 Go to previous messageGo to next message
Thanks for prompt reply.
Here is want I want to achive:
- when in Eclipse and working in the XText generated editor / environment :
having the abilty to press a Run button to execute the code in the editor
and to get the output in the Eclipse Console
- when in command line mode (comamnd shell): enter java -cp mydsl.jar
mydsl.dsl (where mydsl.dsl is a text file with my 'code'), output to stdout
Pretty much like when you develop java code in Eclipse, you can run it
directly in the IDE, but you can also run the code at command prompt.
I would prefer it I can maintain the generated xtext plug-in structure and
simply do a export of the jar file (to mydsl.jar in my sample above).
Is it possible to achive this with xtext (run from Eclipse, run standalone
with the same plug-ins)? If not how can I make it in another way?
I did have a quick peek into the
article and was
a bit surprised that the model defintion must be loaded. I would have
thought that all symbols etc where compiled into java code. - agian I'm new
to xtext / antlr etc.
//Peter
"Christian Dietrich" <forums-noreply@eclipse.org> skrev i meddelandet
news:jheaue$ts1$1@news.eclipse.org...
> welcome to Xtext.
> IXtextBuilderParticipant (2) you can call your processor explicitely e.g.
> described here:
> ~Christian
Re: Running / Interpret the DSL [message #798593 is a reply to message #798580] Tue, 14 February 2012 16:50 Go to previous messageGo to next message
it is a common pratice in eclipse to split between runtime/standalone and ui.
never the less it should be no problem to achieve this.
your point on the example from the wiki i do not understand.
what do you mean with "model defintion must be loaded"
~Christian
Re: Running / Interpret the DSL [message #798623 is a reply to message #798580] Tue, 14 February 2012 17:47 Go to previous messageGo to next message
I did exactly what you are after in the Eclipse b3 project - I
implemented running/interpreting in several different ways - running the
dirty state in the editor, running from dialogs/wizards (passing in
parameters), and much more.
There is a "run" menu extension IIRC in one of the ui components that
serves as an entry point into the functionality.
- henrik
On 2012-14-02 22:27, Peter S Eden wrote:
> article and was
> //Peter
> "Christian Dietrich"<forums-noreply@eclipse.org> skrev i meddelandet
>> Hi,
>> welcome to Xtext.
>> described here:
>> ~Christian
Re: Running / Interpret the DSL [message #799411 is a reply to message #798593] Wed, 15 February 2012 16:23 Go to previous messageGo to next message
I was just a bit confused, but now I realize that the model is actually the
file with my language statments inside.
Peter
news:jhekv6$h8i$1@news.eclipse.org...
> ui.
> ~Christian
Re: Running / Interpret the DSL [message #811351 is a reply to message #799411] Fri, 02 March 2012 03:24 Go to previous messageGo to next message
Hi Peter
From your question:
Honestly, I didn't understand from this topic - is it possible or not ?
and if it is possible - how to do this?
PS I understand that I can add generated src-gen to project and execute generated java classes as usual. But these action will be executed by DSL end-developer, and it will be great to hide this routine from his.
End-developer who uses DSL hasn't care about java routine (I mean adding src-gen to his own project and execute generated java classes) - He should have deals just with DSL and can execute it.
Sergey
[Updated on: Fri, 02 March 2012 03:33] by Moderator
Re: Running / Interpret the DSL [message #811352 is a reply to message #811351] Fri, 02 March 2012 03:28 Go to previous messageGo to next message
if you divide this into two parts
(1) running a generator/interpreter via button
(2) redirecting log to a eclipse console
it is possible
for (1) have a look at http://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-generator-from-a-context-menu/
for (2) which is not Xtext specific google (or bing or whatever) is your friend.
~Christian
Re: Running / Interpret the DSL [message #813504 is a reply to message #811352] Mon, 05 March 2012 05:49 Go to previous message
Thank you,
I just added JDT part (build and execution for generated code) and my task is resolved.
Previous Topic:[Xtext 1] How to serialize inter-model cross references, or, how to automatically generate input sta
Next Topic:M2M transformation reports
Current Time: Wed Jul 23 23:04:22 EDT 2025
Powered by FUDForum. Page generated in 0.25636 seconds
