Home » Archived » BIRT » Problem with New Data Source wizard
Problem with New Data Source wizard [message #798441] Tue, 14 February 2012 12:53 Go to next message
I'm trying to integrate BIRT (Designer and Engine) in a RCP application. Report file generation is working, the Report Editor comes up after clicking twice on the previously created report file and the Report Perspective is also working. But I experience problems with the New Data Source Wizard, if I try to create a JDBC data source. After selecting "JDBC Data Source" in the Data Source Type Dialog and clicking the Next Button the dialog silently hangs (without errors).
As far as I know all needed dependencies (BIRT and DTP) are added to the product definition of our RCP application.
Any help is appreciated.
Many thanks in advance,
Till
Re: Problem with New Data Source wizard [message #798468 is a reply to message #798441] Tue, 14 February 2012 13:25 Go to previous messageGo to next message
Look at the dependencies for the specific build and verify you have them
all. For example on 3.7.1:
http://download.eclipse.org/birt/downloads/build.php?build=R-R1-3_7_1-201109131734
Eclipse Version 3.7.1 SDK
DTP Version 1.9.1
EMF Version 2.7.1 EMF+XSD
GEF Version 3.7.1 runtime
WTP Version 3.3.1
Jason
On 2/14/2012 12:53 PM, Till Fechteler wrote:
> Till
Re: Problem with New Data Source wizard [message #799231 is a reply to message #798468] Wed, 15 February 2012 11:24 Go to previous messageGo to next message
I checked the dependencies in the product definition and did not find a problem (see listing of the product definition at the end of this reply). If I click Validate... I get the following messages:
Plugin org.eclipse.datatools.enablement.oda.ws
Missing Constraint: Require-Bundle: javax.wsdl; bundle-version="[1.5.0,1.6.0)"
Plugin org.eclipse.datatools.enablement.oda.ws.ui
Plugin org.eclipse.datatools.sqltools.result
Missing Constraint: Require-Bundle: org.apache.lucene; bundle-version="[1.9.0,2.0.0)"
I did not understand the problems because all mentioned dependencies are specified correctly in the product definition (see below).
Last I have tried to specify the dependencies according to the product definition of the "org.eclipse.birt.report.designer.ui.rcp" plugin which led to the following NPE:
!ENTRY org.eclipse.datatools.connectivity 4 10001 2012-02-15 16:06:43.160
!MESSAGE Internal Error - org.eclipse.datatools.connectivity
!STACK 0
at org.eclipse.datatools.connectivity.internal.ConnectionProfileMgmt.readCPsFromXML1_0(ConnectionProfileMgmt.java:643)
at org.eclipse.datatools.connectivity.internal.ConnectionProfileMgmt.loadCPs(ConnectionProfileMgmt.java:925)
at org.eclipse.datatools.connectivity.internal.ConnectionProfileMgmt.loadCPs(ConnectionProfileMgmt.java:496)
at org.eclipse.datatools.connectivity.internal.InternalProfileManager.loadProfiles(InternalProfileManager.java:1088)
at org.eclipse.datatools.connectivity.internal.InternalProfileManager.getProfiles(InternalProfileManager.java:150)
at org.eclipse.datatools.connectivity.internal.InternalProfileManager.getProfilesByCategory(InternalProfileManager.java:200)
at org.eclipse.datatools.connectivity.ProfileManager.getProfilesByCategory(ProfileManager.java:88)
at org.eclipse.datatools.connectivity.ui.wizards.NewConnectionProfileWizardPage.createControl(NewConnectionProfileWizardPage.java:158)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
at org.eclipse.datatools.connectivity.ui.wizards.NewConnectionProfileWizard.createPageControls(NewConnectionProfileWizard.java:309)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1183)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1242)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1239)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1228)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1226)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:915)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:428)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.data.ui.actions.NewDataSourceAction.run(NewDataSourceAction.java:126)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at de.rub.fbi.iib.sitesim.editor.gui.intro.Application.start(Application.java:23)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
After the NPE was thrown the wizard silently hangs as described previously. Is a tutorial or description available which shows how to specify the needed dependencies for the integration of BIRT in a RCP application by using a product definition file? This would be very helpful.
Many thanks for your help,
Till
Listing of the product definition of our RCP application:
<?pde version="3.5"?>
<product name="SiteSimEditor" uid="de.rub.fbi.iib.sitesimeditor.deploy.product" id="de.rub.fbi.iib.sitesimeditor.product" application="de.rub.fbi.iib.sitesimeditor.application" version="0.0.1" useFeatures="false" includeLaunchers="false">
   <configIni use="default">
   </configIni>
   <launcherArgs>
      <vmArgs>-Xmx1024m</vmArgs>
      <vmArgsMac>-XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
   </launcherArgs>
   <windowImages i16="/SiteSimEditor/icons/Mefisto_Logo_16.png" i32="/SiteSimEditor/icons/Mefisto_Logo_32.png" i48="/SiteSimEditor/icons/Mefisto_Logo_48.png" i64="/SiteSimEditor/icons/Mefisto_Logo_64.png" i128="/SiteSimEditor/icons/Mefisto_Logo_128.png"/>
   <splash
      location="de.rub.fbi.iib.sitesimeditor" />
   <launcher name="SiteSimEditor">
      <solaris/>
      <win useIco="true">
         <ico path="/SiteSimEditor/icons/mefisto_windows.ico"/>
         <bmp
            winSmallHigh="/SiteSimEditor/icons/Mefisto_Logo_16_32bit.bmp"
            winSmallLow="/SiteSimEditor/icons/Mefisto_Logo_16_8bit.bmp"
            winMediumHigh="/SiteSimEditor/icons/Mefisto_Logo_32_32bit.bmp"
            winMediumLow="/SiteSimEditor/icons/Mefisto_Logo_32_8bit.bmp"
            winLargeHigh="/SiteSimEditor/icons/Mefisto_Logo_48_32bit.bmp"
            winLargeLow="/SiteSimEditor/icons/Mefisto_Logo_48_8bit.bmp"/>
      </win>
   </launcher>
   <intro introId="de.rub.fbi.iib.sitesim.editor.intro"/>
   <vm>
      <linux include="false">org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6</linux>
      <macos include="false">org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6</macos>
      <solaris include="false">org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6</solaris>
      <windows include="false">org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6</windows>
   </vm>
   <plugins>
      <plugin id="com.ibm.icu"/>
      <plugin id="com.lowagie.text"/>
      <plugin id="com.quantum.Quantum"/>
      <plugin id="com.quantum.beanshell"/>
      <plugin id="com.quantum.dbunit"/>
      <plugin id="com.quantum.erd"/>
      <plugin id="com.quantum.flatfiles"/>
      <plugin id="com.quantum.help"/>
      <plugin id="com.quantum.log"/>
      <plugin id="de.rub.bi.inf.sitesim.constraintchecker"/>
      <plugin id="de.rub.bi.inf.sitesim.ganttchart"/>
      <plugin id="de.rub.bi.inf.sitesim.logistics"/>
      <plugin id="de.rub.bi.inf.sitesim.model.services"/>
      <plugin id="de.rub.bi.inf.sitesim.multimodel"/>
      <plugin id="de.rub.fbi.iib.sitesimeditor"/>
      <plugin id="de.simplan.sitesim.data.model"/>
      <plugin id="de.simplan.sitesim.editor.results"/>
      <plugin id="javax.activation"/>
      <plugin id="javax.mail"/>
      <plugin id="javax.persistence"/>
      <plugin id="javax.servlet"/>
      <plugin id="javax.servlet.jsp"/>
      <plugin id="javax.transaction" fragment="true"/>
      <plugin id="javax.wsdl"/>
      <plugin id="javax.xml"/>
      <plugin id="javax.xml.rpc"/>
      <plugin id="javax.xml.soap"/>
      <plugin id="javax.xml.stream"/>
      <plugin id="jfreechart.org"/>
      <plugin id="jgraph.com"/>
      <plugin id="net.sourceforge.lpg.lpgjavaruntime"/>
      <plugin id="openifctools.com"/>
      <plugin id="org.apache.ant"/>
      <plugin id="org.apache.axis"/>
      <plugin id="org.apache.batik.bridge"/>
      <plugin id="org.apache.batik.css"/>
      <plugin id="org.apache.batik.dom"/>
      <plugin id="org.apache.batik.dom.svg"/>
      <plugin id="org.apache.batik.ext.awt"/>
      <plugin id="org.apache.batik.parser"/>
      <plugin id="org.apache.batik.pdf"/>
      <plugin id="org.apache.batik.svggen"/>
      <plugin id="org.apache.batik.transcoder"/>
      <plugin id="org.apache.batik.util"/>
      <plugin id="org.apache.batik.util.gui"/>
      <plugin id="org.apache.batik.xml"/>
      <plugin id="org.apache.commons.codec"/>
      <plugin id="org.apache.commons.discovery"/>
      <plugin id="org.apache.commons.el"/>
      <plugin id="org.apache.commons.logging"/>
      <plugin id="org.apache.derby.core"/>
      <plugin id="org.apache.jasper"/>
      <plugin id="org.apache.lucene"/>
      <plugin id="org.apache.lucene.analysis"/>
      <plugin id="org.apache.lucene.core"/>
      <plugin id="org.apache.lucene.highlighter"/>
      <plugin id="org.apache.lucene.memory"/>
      <plugin id="org.apache.lucene.misc"/>
      <plugin id="org.apache.lucene.queries"/>
      <plugin id="org.apache.lucene.snowball"/>
      <plugin id="org.apache.lucene.spellchecker"/>
      <plugin id="org.apache.xerces"/>
      <plugin id="org.apache.xml.resolver"/>
      <plugin id="org.apache.xml.serializer"/>
      <plugin id="org.eclipse.ant.core"/>
      <plugin id="org.eclipse.ant.launching"/>
      <plugin id="org.eclipse.ant.ui"/>
      <plugin id="org.eclipse.birt"/>
      <plugin id="org.eclipse.birt.chart.cshelp"/>
      <plugin id="org.eclipse.birt.chart.device.extension"/>
      <plugin id="org.eclipse.birt.chart.device.pdf"/>
      <plugin id="org.eclipse.birt.chart.device.svg"/>
      <plugin id="org.eclipse.birt.chart.device.swt"/>
      <plugin id="org.eclipse.birt.chart.engine"/>
      <plugin id="org.eclipse.birt.chart.engine.extension"/>
      <plugin id="org.eclipse.birt.chart.examples"/>
      <plugin id="org.eclipse.birt.chart.examples.core"/>
      <plugin id="org.eclipse.birt.chart.reportitem"/>
      <plugin id="org.eclipse.birt.chart.reportitem.ui"/>
      <plugin id="org.eclipse.birt.chart.ui"/>
      <plugin id="org.eclipse.birt.chart.ui.extension"/>
      <plugin id="org.eclipse.birt.core"/>
      <plugin id="org.eclipse.birt.core.script.function"/>
      <plugin id="org.eclipse.birt.core.ui"/>
      <plugin id="org.eclipse.birt.data"/>
      <plugin id="org.eclipse.birt.data.aggregation"/>
      <plugin id="org.eclipse.birt.doc"/>
      <plugin id="org.eclipse.birt.example"/>
      <plugin id="org.eclipse.birt.report.data.adapter"/>
      <plugin id="org.eclipse.birt.report.data.bidi.utils"/>
      <plugin id="org.eclipse.birt.report.data.bidi.utils.ui"/>
      <plugin id="org.eclipse.birt.report.data.oda.hive"/>
      <plugin id="org.eclipse.birt.report.data.oda.hive.ui"/>
      <plugin id="org.eclipse.birt.report.data.oda.jdbc"/>
      <plugin id="org.eclipse.birt.report.data.oda.jdbc.ui"/>
      <plugin id="org.eclipse.birt.report.data.oda.sampledb"/>
      <plugin id="org.eclipse.birt.report.data.oda.sampledb.ui"/>
      <plugin id="org.eclipse.birt.report.data.oda.xml"/>
      <plugin id="org.eclipse.birt.report.data.oda.xml.ui"/>
      <plugin id="org.eclipse.birt.report.designer.core"/>
      <plugin id="org.eclipse.birt.report.designer.ui"/>
      <plugin id="org.eclipse.birt.report.designer.ui.cubebuilder"/>
      <plugin id="org.eclipse.birt.report.designer.ui.data"/>
      <plugin id="org.eclipse.birt.report.designer.ui.editors"/>
      <plugin id="org.eclipse.birt.report.designer.ui.editors.schematic"/>
      <plugin id="org.eclipse.birt.report.designer.ui.ide"/>
      <plugin id="org.eclipse.birt.report.designer.ui.lib"/>
      <plugin id="org.eclipse.birt.report.designer.ui.lib.explorer"/>
      <plugin id="org.eclipse.birt.report.designer.ui.preview.web"/>
      <plugin id="org.eclipse.birt.report.designer.ui.views"/>
      <plugin id="org.eclipse.birt.report.engine"/>
      <plugin id="org.eclipse.birt.report.engine.dataextraction"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.excel.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.html"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.html.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.odp"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.odp.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.ods"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.ods.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.odt"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.odt.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.pdf"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.pdf.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.postscript"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.postscript.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.ppt"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.ppt.config"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.prototype.excel"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.wpml"/>
      <plugin id="org.eclipse.birt.report.engine.emitter.wpml.config"/>
      <plugin id="org.eclipse.birt.report.engine.fonts"/>
      <plugin id="org.eclipse.birt.report.engine.odf"/>
      <plugin id="org.eclipse.birt.report.item.crosstab.core"/>
      <plugin id="org.eclipse.birt.report.item.crosstab.ui"/>
      <plugin id="org.eclipse.birt.report.model"/>
      <plugin id="org.eclipse.birt.report.model.adapter.oda"/>
      <plugin id="org.eclipse.birt.report.viewer"/>
      <plugin id="org.eclipse.birt.resources"/>
      <plugin id="org.eclipse.compare"/>
      <plugin id="org.eclipse.compare.core"/>
      <plugin id="org.eclipse.core.commands"/>
      <plugin id="org.eclipse.core.contenttype"/>
      <plugin id="org.eclipse.core.databinding"/>
      <plugin id="org.eclipse.core.databinding.beans"/>
      <plugin id="org.eclipse.core.databinding.observable"/>
      <plugin id="org.eclipse.core.databinding.property"/>
      <plugin id="org.eclipse.core.expressions"/>
      <plugin id="org.eclipse.core.externaltools"/>
      <plugin id="org.eclipse.core.filebuffers"/>
      <plugin id="org.eclipse.core.filesystem"/>
      <plugin id="org.eclipse.core.filesystem.win32.x86" fragment="true"/>
      <plugin id="org.eclipse.core.jobs"/>
      <plugin id="org.eclipse.core.net"/>
      <plugin id="org.eclipse.core.net.win32.x86" fragment="true"/>
      <plugin id="org.eclipse.core.resources"/>
      <plugin id="org.eclipse.core.resources.win32.x86" fragment="true"/>
      <plugin id="org.eclipse.core.runtime"/>
      <plugin id="org.eclipse.core.runtime.compatibility"/>
      <plugin id="org.eclipse.core.runtime.compatibility.auth"/>
      <plugin id="org.eclipse.core.runtime.compatibility.registry" fragment="true"/>
      <plugin id="org.eclipse.core.variables"/>
      <plugin id="org.eclipse.datatools.common.doc.user"/>
      <plugin id="org.eclipse.datatools.connectivity"/>
      <plugin id="org.eclipse.datatools.connectivity.db.generic"/>
      <plugin id="org.eclipse.datatools.connectivity.dbdefinition.genericJDBC"/>
      <plugin id="org.eclipse.datatools.connectivity.oda"/>
      <plugin id="org.eclipse.datatools.connectivity.oda.consumer"/>
      <plugin id="org.eclipse.datatools.connectivity.oda.design"/>
      <plugin id="org.eclipse.datatools.connectivity.oda.design.ui"/>
      <plugin id="org.eclipse.datatools.connectivity.oda.flatfile"/>
      <plugin id="org.eclipse.datatools.connectivity.oda.flatfile.ui"/>
      <plugin id="org.eclipse.datatools.connectivity.oda.profile"/>
      <plugin id="org.eclipse.datatools.connectivity.sqm.core"/>
      <plugin id="org.eclipse.datatools.connectivity.sqm.core.ui"/>
      <plugin id="org.eclipse.datatools.connectivity.ui"/>
      <plugin id="org.eclipse.datatools.enablement.oda.ws"/>
      <plugin id="org.eclipse.datatools.enablement.oda.ws.ui"/>
      <plugin id="org.eclipse.datatools.enablement.oda.xml"/>
      <plugin id="org.eclipse.datatools.enablement.oda.xml.ui"/>
      <plugin id="org.eclipse.datatools.help"/>
      <plugin id="org.eclipse.datatools.modelbase.dbdefinition"/>
      <plugin id="org.eclipse.datatools.modelbase.sql"/>
      <plugin id="org.eclipse.datatools.modelbase.sql.query"/>
      <plugin id="org.eclipse.datatools.modelbase.sql.query.edit"/>
      <plugin id="org.eclipse.datatools.modelbase.sql.xml.query"/>
      <plugin id="org.eclipse.datatools.oda.cshelp"/>
      <plugin id="org.eclipse.datatools.sqltools.common.ui"/>
      <plugin id="org.eclipse.datatools.sqltools.editor.core"/>
      <plugin id="org.eclipse.datatools.sqltools.editor.core.ui"/>
      <plugin id="org.eclipse.datatools.sqltools.parsers.sql"/>
      <plugin id="org.eclipse.datatools.sqltools.parsers.sql.lexer"/>
      <plugin id="org.eclipse.datatools.sqltools.parsers.sql.query"/>
      <plugin id="org.eclipse.datatools.sqltools.plan"/>
      <plugin id="org.eclipse.datatools.sqltools.result"/>
      <plugin id="org.eclipse.datatools.sqltools.result.ui"/>
      <plugin id="org.eclipse.datatools.sqltools.sql"/>
      <plugin id="org.eclipse.datatools.sqltools.sql.ui"/>
      <plugin id="org.eclipse.datatools.sqltools.sqlbuilder"/>
      <plugin id="org.eclipse.datatools.sqltools.sqleditor"/>
      <plugin id="org.eclipse.debug.core"/>
      <plugin id="org.eclipse.debug.ui"/>
      <plugin id="org.eclipse.draw2d"/>
      <plugin id="org.eclipse.emf.common"/>
      <plugin id="org.eclipse.emf.common.ui"/>
      <plugin id="org.eclipse.emf.ecore"/>
      <plugin id="org.eclipse.emf.ecore.change"/>
      <plugin id="org.eclipse.emf.ecore.edit"/>
      <plugin id="org.eclipse.emf.ecore.xmi"/>
      <plugin id="org.eclipse.emf.edit"/>
      <plugin id="org.eclipse.emf.edit.ui"/>
      <plugin id="org.eclipse.equinox.app"/>
      <plugin id="org.eclipse.equinox.common"/>
      <plugin id="org.eclipse.equinox.frameworkadmin"/>
      <plugin id="org.eclipse.equinox.frameworkadmin.equinox"/>
      <plugin id="org.eclipse.equinox.http.jetty"/>
      <plugin id="org.eclipse.equinox.http.registry"/>
      <plugin id="org.eclipse.equinox.http.servlet"/>
      <plugin id="org.eclipse.equinox.jsp.jasper"/>
      <plugin id="org.eclipse.equinox.jsp.jasper.registry"/>
      <plugin id="org.eclipse.equinox.p2.artifact.repository"/>
      <plugin id="org.eclipse.equinox.p2.core"/>
      <plugin id="org.eclipse.equinox.p2.director"/>
      <plugin id="org.eclipse.equinox.p2.director.app"/>
      <plugin id="org.eclipse.equinox.p2.engine"/>
      <plugin id="org.eclipse.equinox.p2.garbagecollector"/>
      <plugin id="org.eclipse.equinox.p2.jarprocessor"/>
      <plugin id="org.eclipse.equinox.p2.metadata"/>
      <plugin id="org.eclipse.equinox.p2.metadata.repository"/>
      <plugin id="org.eclipse.equinox.p2.operations"/>
      <plugin id="org.eclipse.equinox.p2.publisher"/>
      <plugin id="org.eclipse.equinox.p2.publisher.eclipse"/>
      <plugin id="org.eclipse.equinox.p2.repository"/>
      <plugin id="org.eclipse.equinox.p2.repository.tools"/>
      <plugin id="org.eclipse.equinox.p2.touchpoint.eclipse"/>
      <plugin id="org.eclipse.equinox.p2.ui"/>
      <plugin id="org.eclipse.equinox.p2.updatesite"/>
      <plugin id="org.eclipse.equinox.preferences"/>
      <plugin id="org.eclipse.equinox.registry"/>
      <plugin id="org.eclipse.equinox.security"/>
      <plugin id="org.eclipse.equinox.security.ui"/>
      <plugin id="org.eclipse.equinox.security.win32.x86" fragment="true"/>
      <plugin id="org.eclipse.equinox.simpleconfigurator"/>
      <plugin id="org.eclipse.equinox.simpleconfigurator.manipulator"/>
      <plugin id="org.eclipse.gef"/>
      <plugin id="org.eclipse.help"/>
      <plugin id="org.eclipse.help.base"/>
      <plugin id="org.eclipse.help.ui"/>
      <plugin id="org.eclipse.jdt.compiler.apt" fragment="true"/>
      <plugin id="org.eclipse.jdt.compiler.tool" fragment="true"/>
      <plugin id="org.eclipse.jdt.core"/>
      <plugin id="org.eclipse.jdt.core.manipulation"/>
      <plugin id="org.eclipse.jdt.debug"/>
      <plugin id="org.eclipse.jdt.debug.ui"/>
      <plugin id="org.eclipse.jdt.junit"/>
      <plugin id="org.eclipse.jdt.junit.core"/>
      <plugin id="org.eclipse.jdt.junit.runtime"/>
      <plugin id="org.eclipse.jdt.launching"/>
      <plugin id="org.eclipse.jdt.ui"/>
      <plugin id="org.eclipse.jem.util"/>
      <plugin id="org.eclipse.jface"/>
      <plugin id="org.eclipse.jface.databinding"/>
      <plugin id="org.eclipse.jface.text"/>
      <plugin id="org.eclipse.ltk.core.refactoring"/>
      <plugin id="org.eclipse.ltk.ui.refactoring"/>
      <plugin id="org.eclipse.net4j.jms.api"/>
      <plugin id="org.eclipse.osgi"/>
      <plugin id="org.eclipse.osgi.services"/>
      <plugin id="org.eclipse.osgi.util"/>
      <plugin id="org.eclipse.pde.build"/>
      <plugin id="org.eclipse.pde.core"/>
      <plugin id="org.eclipse.pde.launching"/>
      <plugin id="org.eclipse.pde.ui"/>
      <plugin id="org.eclipse.pde.ui.templates"/>
      <plugin id="org.eclipse.persistence.antlr"/>
      <plugin id="org.eclipse.persistence.asm"/>
      <plugin id="org.eclipse.persistence.core"/>
      <plugin id="org.eclipse.persistence.jpa"/>
      <plugin id="org.eclipse.persistence.jpa.equinox" fragment="true"/>
      <plugin id="org.eclipse.persistence.jpa.equinox.weaving" fragment="true"/>
      <plugin id="org.eclipse.persistence.jpa.osgi"/>
      <plugin id="org.eclipse.persistence.oracle" fragment="true"/>
      <plugin id="org.eclipse.sdk"/>
      <plugin id="org.eclipse.search"/>
      <plugin id="org.eclipse.swt"/>
      <plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
      <plugin id="org.eclipse.team.core"/>
      <plugin id="org.eclipse.team.ui"/>
      <plugin id="org.eclipse.text"/>
      <plugin id="org.eclipse.ui"/>
      <plugin id="org.eclipse.ui.browser"/>
      <plugin id="org.eclipse.ui.cheatsheets"/>
      <plugin id="org.eclipse.ui.console"/>
      <plugin id="org.eclipse.ui.editors"/>
      <plugin id="org.eclipse.ui.externaltools"/>
      <plugin id="org.eclipse.ui.forms"/>
      <plugin id="org.eclipse.ui.ide"/>
      <plugin id="org.eclipse.ui.ide.application"/>
      <plugin id="org.eclipse.ui.intro"/>
      <plugin id="org.eclipse.ui.navigator"/>
      <plugin id="org.eclipse.ui.navigator.resources"/>
      <plugin id="org.eclipse.ui.views"/>
      <plugin id="org.eclipse.ui.views.log"/>
      <plugin id="org.eclipse.ui.views.properties.tabbed"/>
      <plugin id="org.eclipse.ui.win32" fragment="true"/>
      <plugin id="org.eclipse.ui.workbench"/>
      <plugin id="org.eclipse.ui.workbench.texteditor"/>
      <plugin id="org.eclipse.update.configurator"/>
      <plugin id="org.eclipse.update.core"/>
      <plugin id="org.eclipse.update.core.win32" fragment="true"/>
      <plugin id="org.eclipse.wb.core"/>
      <plugin id="org.eclipse.wb.core.databinding"/>
      <plugin id="org.eclipse.wb.core.lib"/>
      <plugin id="org.eclipse.wb.core.ui"/>
      <plugin id="org.eclipse.wb.jdt.fragment" fragment="true"/>
      <plugin id="org.eclipse.wb.os"/>
      <plugin id="org.eclipse.wb.rcp"/>
      <plugin id="org.eclipse.wb.rcp.databinding"/>
      <plugin id="org.eclipse.wb.rcp.databinding.emf"/>
      <plugin id="org.eclipse.wb.runtime"/>
      <plugin id="org.eclipse.wb.runtime.lib"/>
      <plugin id="org.eclipse.wb.swt"/>
      <plugin id="org.eclipse.wb.swt.widgets.baseline"/>
      <plugin id="org.eclipse.wst.common.core"/>
      <plugin id="org.eclipse.wst.common.emf"/>
      <plugin id="org.eclipse.wst.common.emfworkbench.integration"/>
      <plugin id="org.eclipse.wst.common.environment"/>
      <plugin id="org.eclipse.wst.common.frameworks"/>
      <plugin id="org.eclipse.wst.common.project.facet.core"/>
      <plugin id="org.eclipse.wst.common.ui"/>
      <plugin id="org.eclipse.wst.common.uriresolver"/>
      <plugin id="org.eclipse.wst.sse.core"/>
      <plugin id="org.eclipse.wst.sse.ui"/>
      <plugin id="org.eclipse.wst.validation"/>
      <plugin id="org.eclipse.wst.xml.core"/>
      <plugin id="org.eclipse.wst.xml.ui"/>
      <plugin id="org.eclipse.xsd"/>
      <plugin id="org.eclipse.xsd.edit"/>
      <plugin id="org.hamcrest.core"/>
      <plugin id="org.junit"/>
      <plugin id="org.mortbay.jetty.server"/>
      <plugin id="org.mortbay.jetty.util"/>
      <plugin id="org.mozilla.javascript"/>
      <plugin id="org.sat4j.core"/>
      <plugin id="org.sat4j.pb"/>
      <plugin id="org.w3c.css.sac"/>
      <plugin id="org.w3c.dom.smil"/>
      <plugin id="org.w3c.dom.svg"/>
      <plugin id="org.w3c.sac"/>
   </plugins>
</product>
Re: Problem with New Data Source wizard [message #799293 is a reply to message #799231] Wed, 15 February 2012 12:56 Go to previous message
Till,
I am not aware of any writeup on including the birt designer in an RCP
app, but I know several users have done it. I have a product
configuration posted on birt exchange for including the viewer, but not
the designer.
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1194-eclipse-product-configuration-file-for-webviewer-in-rcp/
The product configuration BIRT.product is a stripped down designer that
does not support all features.
I would suggest downloading the allinone and checking the plugins to see
what is missing. For example this plugin is not in your product file.
org.eclipse.datatools.connectivity.console.profile
If you download the allinone there is an artifacts.xml file that I
believe lists all the plugins.
Jason
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> Till
> </configIni>
> <launcherArgs>
> </launcherArgs>
> <splash
> <solaris/>
> <win useIco="true">
> <bmp
> </win>
> </launcher>
> <vm>
> <linux
> <macos
> <solaris
> <windows
> </vm>
> <plugins>
> fragment="true"/>
> </plugins>
> </product>
Previous Topic:how to arrange data horizontally and vertically
Next Topic:How to show series labels only for the last value
Current Time: Sat Jul 26 11:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.42637 seconds
