Home » Eclipse Projects » Eclipse 4 » Problems creating a Part Toolbar
Problems creating a Part Toolbar [message #798221] Tue, 14 February 2012 06:50 Go to next message
I am trying to create a toolbar and a menu for a specific MPart. To do this I enabled "ToolBar" on the Part in the e4xmi of the contibuting plug-in.
<children xsi:type="basic:Part" xmi:id="_fJcM4K7mEeCWdr0cltTDYg" elementId="part.umlauf" contributionURI="bundleclass://de.emsw.gosa.contrib.umlauf/de.emsw.gosa.contrib.umlauf.live.UmlaufLivePart" label="Uml&#xe4;ufe" iconURI="platform:/plugin/de.emsw.gosa.contrib.umlauf/icons/umlauf_live.gif">
	<toolbar xmi:id="_A3Z2kFb_EeGO18KNCa9uXQ">
	  <children xsi:type="menu:HandledToolItem" xmi:id="_Bjs74Fb_EeGO18KNCa9uXQ" label="ZK" iconURI="platform:/plugin/de.emsw.gosa.contrib.umlauf/icons/umlauf_live.gif" tooltip="test" command="_STUIYN3gEeCL86FkGFti1Q"/>
	</toolbar>
</children>
When I start the application I get a NPE.
12:29:52.826 ERROR org.eclipse.equinox.logger - Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@966905 (elementId: null, tags: null, contributorURI: platform:/plugin/de.emsw.gosa.contrib.umlauf) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@21a86a, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null)
java.lang.NullPointerException: null
	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createToolbar(ToolBarManagerRenderer.java:378) ~[na:na]
Am I missing something or is this a bug?
Greetings
Christoph
Re: Problems creating a Part Toolbar [message #798247 is a reply to message #798221] Tue, 14 February 2012 07:25 Go to previous messageGo to next message
What version of Eclipse 4.2?
Tom
Am 14.02.12 12:50, schrieb Christoph Keimel:
> Hello,
> plug-in.
> label="Uml�ufe"
> </toolbar>
> </children>
> rendering:
> at
> ~[na:na]
> Greetings
> Christoph
Re: Problems creating a Part Toolbar [message #798253 is a reply to message #798247] Tue, 14 February 2012 07:38 Go to previous messageGo to next message
In git i see a potential NPE introduced 6 days ago but fixed 5 days ago.
Tom
Am 14.02.12 13:25, schrieb Tom Schindl:
> Tom
>> Hello,
>> plug-in.
>> label="Uml�ufe"
>> </toolbar>
>> </children>
>> rendering:
>> at
>> ~[na:na]
>> Greetings
>> Christoph
Re: Problems creating a Part Toolbar [message #798368 is a reply to message #798247] Tue, 14 February 2012 10:45 Go to previous messageGo to next message
Version: 4.2.0
Build id: I20120208-2200
Re: Problems creating a Part Toolbar [message #798372 is a reply to message #798368] Tue, 14 February 2012 10:50 Go to previous message
If you update to a later one your code should work. It's only this
version that has the regression.
Tom
Am 14.02.12 16:45, schrieb Christoph Keimel:
> Version: 4.2.0
Previous Topic:Problem using StartupMonitor to show a login dialog
Next Topic:Create a modal window
Current Time: Sat Jul 26 06:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.03527 seconds
