Home » Eclipse Projects » Eclipse Scout » AbstractImageField with scrollbar
AbstractImageField with scrollbar [message #798098] Tue, 14 February 2012 03:51 Go to next message
I have an AbstractImageField and would like to set a scrollbar, if the image is bigger than the window size. Does scout support this requirement?
I've found a solution with the AbstractHtmlField, but then i can't define any menus.
Re: AbstractImageField with scrollbar [message #798125 is a reply to message #798098] Tue, 14 February 2012 04:28 Go to previous messageGo to next message
a scrollbar is not yet in place.
This is due to the current concept of using transformations with zoom and pan.
But this does not basically prevent a scroll bar.
I think it could be done for example using a getConfiguredScrollable that activates pan with scrollbars. It's up to you to make a patch proposal.
Re: AbstractImageField with scrollbar [message #798980 is a reply to message #798098] Wed, 15 February 2012 04:51 Go to previous messageGo to next message
My patch proposal: Bugzilla 371589
Re: AbstractImageField with scrollbar [message #799015 is a reply to message #798980] Wed, 15 February 2012 05:36 Go to previous message
Matthias Fischer wrote on Wed, 15 February 2012 10:51
Link: https://bugs.eclipse.org/bugs/show_bug.cgi?id=371589
Previous Topic:Filter calendar items
Next Topic:Abstract fields, columns etc.
Current Time: Fri Jul 18 07:29:16 EDT 2025
Powered by FUDForum. Page generated in 0.04100 seconds
