Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Don't understand JPA generation strategy on bidir relation 0..1 to 0..*
[Texo] Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #797519] Mon, 13 February 2012 10:36 Go to next message
Hi all,
Let's consider 2 use cases :
1)
index.php/fa/7130/0/
2)
index.php/fa/7131/0/
In both cases, this is a bidirectional relation, with opposite correctly set. Both relations are set unordered.
But in the use case 1, a joined table is generated. In the use case 2, the mapped-by property is correctly set.
My question is : why is a joined table used in the use case 1 ? Because I don't see a valid modeling reason.
Thanks in advance !
[Updated on: Mon, 13 February 2012 11:27] by Moderator
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #797630 is a reply to message #797519] Mon, 13 February 2012 13:19 Go to previous messageGo to next message
Hi Benoit,
There are properties you can set in the annotation model on epackage level which control if join tables are created for
associations (contained or non-contained). As a default for containment associations no-join table is used and for
non-containment associations a join table is used.
Does this answer your question?
gr. Martin
On 02/13/2012 04:36 PM, Benoit Cantin wrote:
> Hi all,
> 1)
> 2)
> Thanks in advance !
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #798080 is a reply to message #797630] Tue, 14 February 2012 03:17 Go to previous messageGo to next message
Hi Martin,
This sounds like to be the solution. But it is not working. Whether I set "Use join tables for non containment" or not, a join table is generated. I've also tested the option "Use join tables for containment" and this one is working correctly. Sounds like a bug ?
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #798325 is a reply to message #798080] Tue, 14 February 2012 09:37 Go to previous messageGo to next message
Sounds indeed like a bug, can you file a bugzilla?
gr. Martin
On 02/14/2012 09:17 AM, Benoit Cantin wrote:
> Hi Martin,
The Netherlands
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #798388 is a reply to message #798325] Tue, 14 February 2012 11:22 Go to previous messageGo to next message
Yes. Done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=371509
> gr. Martin
>> Hi Martin,
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #815996 is a reply to message #798388] Thu, 08 March 2012 04:41 Go to previous messageGo to next message
Hi Martin,
Are you sure that this correction is available in the latest build ? I
still have the problem.
Same remark with https://bugs.eclipse.org/bugs/show_bug.cgi?id=372239
>> gr. Martin
>>> Hi Martin,
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #816035 is a reply to message #815996] Thu, 08 March 2012 05:40 Go to previous messageGo to next message
On 03/08/2012 10:41 AM, Benoit Cantin wrote:
> Hi Martin,
from what I can see on hudson, the last build (containing those updates)
didn't run.
>>> gr. Martin
>>>> Hi Martin,
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #816056 is a reply to message #816035] Thu, 08 March 2012 06:15 Go to previous messageGo to next message
Ha indeed! I did not abort it, not sure what happened, I kind of was focused on if the small icon was red, and did not
see the difference between grey and blue...
Doing a new build now!
gr. Martin
>> Hi Martin,
> from what I can see on hudson, the last build (containing those updates) didn't run.
>>>> gr. Martin
>>>>> Hi Martin,
The Netherlands
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #816251 is a reply to message #816056] Thu, 08 March 2012 10:56 Go to previous message
Ok, I got the new version, and the bug is corrected.
Thank you !
> focused on if the small icon was red, and did not see the difference
> gr. Martin
>>> Hi Martin,
>>>>> gr. Martin
>>>>>> Hi Martin,
Previous Topic:rolling back a transaction manually
Next Topic:ecorediag missing classes in packages
Current Time: Wed Jul 23 15:01:08 EDT 2025
Powered by FUDForum. Page generated in 0.04821 seconds
