Home » Archived » BIRT » Birt Viewer Limits Results to 500 records
Birt Viewer Limits Results to 500 records [message #797738] Mon, 13 February 2012 16:21 Go to next message
In my eclipse BIRT designer I have figured out how to show all the records. However, when I deploy the report to our BIRT viewer the results are truncated at 500 records. Is there some setting in the Tomcat Viewer to disable this limitation? I am running 3.7 of the designer and viewer.
Re: Birt Viewer Limits Results to 500 records [message #797785 is a reply to message #797738] Mon, 13 February 2012 17:13 Go to previous messageGo to next message
I figured this one out. The web.xml needed to be changed:
<!-- Preview report rows limit. An empty value means no limit. -->
<context-param>
<param-name>BIRT_VIEWER_MAX_ROWS</param-name>
<param-value>100000</param-value>
</context-param>
Re: Birt Viewer Limits Results to 500 records [message #797788 is a reply to message #797738] Mon, 13 February 2012 17:13 Go to previous messageGo to next message
In the deployed viewer there should be no limit unless you explicitly
set it with the:
<context-param>
<param-value></param-value>
</context-param>
In web.xml
or if you add __maxrows=500 to the url that runs the report.
Jason
> Thanks
Re: Birt Viewer Limits Results to 500 records [message #797789 is a reply to message #797785] Mon, 13 February 2012 17:14 Go to previous messageGo to next message
If you leave this blank the default should be all rows.
> <context-param>
> </context-param>
Re: Birt Viewer Limits Results to 500 records [message #811660 is a reply to message #797738] Fri, 02 March 2012 11:59 Go to previous message
Hi, I am using BIRT Viewer for viewing the reports on JBoss 5.1.
I want to customise the viewer
1. for display name update from "BIRT Report Viewer" to "Report Viewer"
2. add logo of company for which reports are developed in the same panel
I could change the background colour of navigation bar.
I tried to look into jsps; but was not successful.
Is this achievable task?
Any pointers how to achieve it?
Regards,GG
Previous Topic:STS crash when generate report
Next Topic:How to display the toolbar in the Run Pattern
Current Time: Sun Jul 27 14:08:19 EDT 2025
Powered by FUDForum. Page generated in 1.05089 seconds
