Home » Language IDEs » Java Development Tools (JDT) » ArrayOutOfBounds Exception on FreeBSD
ArrayOutOfBounds Exception on FreeBSD [message #79385] Wed, 23 July 2003 13:25 Go to next message
Originally posted by: warren.roberts.name
I'm running eclipse on a FreeBSD system. Does anyone know what this
excption is or how to get rid of it?
Thanx
Warren
*** Stack trace of contained exception ***
!ENTRY org.eclipse.ui 4 0 Jul 20, 2003 21:14:24.541
!MESSAGE 32
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 32
at org.eclipse.swt.graphics.ImageData.getPixel(ImageData.java:6 26)
at
org.eclipse.jface.resource.CompositeImageDescriptor.drawImag e(CompositeImageDescriptor.java:99)
at
org.eclipse.jdt.ui.JavaElementImageDescriptor.drawCompositeI mage(JavaElementImageDescriptor.java:165)
at
org.eclipse.jface.resource.CompositeImageDescriptor.getImage Data(CompositeImageDescriptor.java:190)
at
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
at
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
at
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
at
org.eclipse.jdt.internal.ui.viewsupport.ImageDescriptorRegis try.get(ImageDescriptorRegistry.java:67)
at
org.eclipse.jdt.ui.ProblemsLabelDecorator.decorateImage(Prob lemsLabelDecorator.java:150)
at
org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getImage(JavaUILabelProvider.java:125)
at
org.eclipse.jdt.internal.ui.javaeditor.JavaEditorErrorTickUp dater.updateEditorImage(JavaEditorErrorTickUpdater.java:75)
at
org.eclipse.jdt.internal.ui.javaeditor.JavaEditorErrorTickUp dater.problemsChanged(JavaEditorErrorTickUpdater.java:63)
at
org.eclipse.jdt.internal.ui.viewsupport.ProblemMarkerManager $1.run(ProblemMarkerManager.java:183)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
at
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1618)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1436)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:136)
at
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:261)
at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:357)
at
org.eclipse.ui.actions.WorkspaceAction.run(WorkspaceAction.j ava:282)
at org.eclipse.ui.actions.BuildAction.run(BuildAction.java:223)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
at
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:187)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
at
org.eclipse.jface.action.ActionContributionItem.access$000(A ctionContributionItem.java:44)
at
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:923)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1641)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1433)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:468)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: ArrayOutOfBounds Exception on FreeBSD [message #79761 is a reply to message #79385] Thu, 24 July 2003 10:28 Go to previous message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Wed, 23 Jul 2003 11:25:24 -0600, Warren Roberts
>Thanx
>Warren
You should post this on eclipse.platform.swt. It looks like a problem
with swt on FreeBSD.
Olivier
Previous Topic:Need your help
Next Topic:JRE detection troubles - patch available for M2
Current Time: Sat Jul 19 01:15:47 EDT 2025
Powered by FUDForum. Page generated in 0.03651 seconds
