Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] Don't understand JPA generation strategy on bidir relation 0..1 to 0..*
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #797630 is a reply to message #797519] |
Mon, 13 February 2012 13:19   |
Hi Benoit,
There are properties you can set in the annotation model on epackage level which control if join tables are created for
associations (contained or non-contained). As a default for containment associations no-join table is used and for
non-containment associations a join table is used.
Does this answer your question?
gr. Martin
On 02/13/2012 04:36 PM, Benoit Cantin wrote:
> Hi all,
> Let's consider 2 use cases :
> 1)
> 2)
> In both cases, this is a bidirectional relation, with opposite correctly set. Both relations are set unordered.
> But in the use case 1, a joined table is generated. In the use case 2, the mapped-by property is correctly set.
> My question is : why is a joined table used in the use case 1 ? Because I don't see a valid modeling reason.
> Thanks in advance !
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #816035 is a reply to message #815996] |
Thu, 08 March 2012 05:40   |
On 03/08/2012 10:41 AM, Benoit Cantin wrote:
> Hi Martin,
> Are you sure that this correction is available in the latest build ? I
> still have the problem.
> Same remark with https://bugs.eclipse.org/bugs/show_bug.cgi?id=372239
from what I can see on hudson, the last build (containing those updates)
didn't run.
> On 02/14/2012 05:22 PM, Benoit Cantin wrote:
>> On 02/14/2012 03:37 PM, Martin Taal wrote:
>>> Sounds indeed like a bug, can you file a bugzilla?
>> Yes. Done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=371509
>>> gr. Martin
>>> On 02/14/2012 09:17 AM, Benoit Cantin wrote:
>>>> Hi Martin,
>>>> This sounds like to be the solution. But it is not working. Whether I
>>>> set "Use join tables for non containment" or not,
>>>> a join table is generated. I've also tested the option "Use join
>>>> tables for containment" and this one is working
>>>> correctly. Sounds like a bug ?
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #816056 is a reply to message #816035] |
Thu, 08 March 2012 06:15   |
Ha indeed! I did not abort it, not sure what happened, I kind of was focused on if the small icon was red, and did not
see the difference between grey and blue...
Doing a new build now!
gr. Martin
>> Hi Martin,
> from what I can see on hudson, the last build (containing those updates) didn't run.
>>>> gr. Martin
>>>>> Hi Martin,
The Netherlands
Re: [Texo]Don't understand JPA generation strategy on bidir relation 0..1 to 0..* [message #816251 is a reply to message #816056] |
Thu, 08 March 2012 10:56  |
Ok, I got the new version, and the bug is corrected.
Thank you !
> focused on if the small icon was red, and did not see the difference
> gr. Martin
>>> Hi Martin,
>>>>> gr. Martin
>>>>>> Hi Martin,
Current Time: Thu Jul 24 23:16:52 EDT 2025
Powered by FUDForum. Page generated in 0.07987 seconds
