Home » Modeling » TMF (Xtext) » testing custom validator - different behaviour for assertWarning() vs assertWarningContains()?
testing custom validator - different behaviour for assertWarning() vs assertWarningContains()? [message #794973] Thu, 09 February 2012 18:16 Go to next message
Writing unit tests for custom validation and confused by behaviour. Would appreciate any suggestions.
Custom validator as follows:
@Check
public void domainShouldStartWithCapital(Domain domain) {
	if (!Character.isUpperCase(domain.getName().charAt(0))) {
		warning("Name should start with a capital",
		domain,
		OoaPackage.Literals.DOMAIN__NAME,
		101);
If I write unit test as follows it works:
public void testDomainShouldStartWithCapital(){
	Domain domain = OoaFactory.eINSTANCE.createDomain();
	domain.setName("domain");
	tester.validator().domainShouldStartWithCapital(domain);
	tester.diagnose().assertWarningContains("Name should start with a capital");
However if I replace the diagnose() call (last line) with the following it fails:
	tester.diagnose().assertWarning(101);
Failure:
java.lang.AssertionError: Predicate (WARNING code=101) does not match Diagnostic WARNING "Name should start with a capital" at Domain'domain'.name=="domain"
	at org.eclipse.xtext.junit.validation.AssertableDiagnostics.fail(AssertableDiagnostics.java:272)
Don't understand why and couldn't figure it out. Any suggestions?
Thanks.
Re: testing custom validator - different behaviour for assertWarning() vs assertWarningContains()? [message #795191 is a reply to message #794973] Fri, 10 February 2012 02:07 Go to previous messageGo to next message
Hi, 101 is not the error code of the warning it is the index in an
mon existing list. Have a look a the other overloaded signatures of
warning in your validator. Regards Christian
Re: testing custom validator - different behaviour for assertWarning() vs assertWarningContains()? [message #795736 is a reply to message #795191] Fri, 10 February 2012 16:40 Go to previous messageGo to next message
Thx Christian.
That explains first question but raises a second.
The method signature for the assertion is
org.eclipse.xtext.junit.validation.AssertableDiagnostics.assertError(int code)
However there's no corresponding signature in the validator that takes an int code. Closest is
org.eclipse.xtext.validation.AbstractDeclarativeValidator.error(String message, EObject source, EStructuralFeature feature, String code, String... issueData)
which takes a string. Do both 'code' params refer to the same conceptual thing - or are they different?
More generally, is there a recommended idiom for checking errors? Is the pragmatic answer just to use assertErrorContains()?
Thanks for your help.
PS: the documentation should probably be updated as the current example and subsequent text suggests the pattern in my OP. Is there somewhere I should raise that as a bug/feature req?
[Updated on: Fri, 10 February 2012 16:49] by Moderator
Re: testing custom validator - different behaviour for assertWarning() vs assertWarningContains()? [message #795763 is a reply to message #795736] Fri, 10 February 2012 17:41 Go to previous messageGo to next message
int code = org.eclipse.emf.common.util.Diagnostic.getCode()
String (issue)Code = org.eclipse.xtext.validation.AbstractValidationDiagnostic.getIssueCode()
the int code is always null (if you use an Xtext Java Validator)
=> simply ignore the int stuff
Re: testing custom validator - different behaviour for assertWarning() vs assertWarningContains()? [message #795788 is a reply to message #795763] Fri, 10 February 2012 18:30 Go to previous messageGo to next message
OK - thx. I'll stick with assertErrorContains().
Re: testing custom validator - different behaviour for assertWarning() vs assertWarningContains()? [message #795797 is a reply to message #795788] Fri, 10 February 2012 18:50 Go to previous message
why not org.eclipse.xtext.validation.AbstractDeclarativeValidator.error(String message, EObject source, EStructuralFeature feature, String code, String... issueData)
+ assertError(String issueCode)?
Previous Topic:Use xtext-based plugin as base for another grammar
Next Topic:xText EPackages generation
Current Time: Fri Jul 18 18:14:29 EDT 2025
Powered by FUDForum. Page generated in 0.04068 seconds
