Home » Modeling » EMF » [CDO] Download sources of version 4.0
[CDO] Download sources of version 4.0 [message #794442] Thu, 09 February 2012 04:46 Go to next message
I was downloading the source code for version 4.0 according to instructions on page http://wiki.eclipse.org/CDO_Source_Installation
Everything works fine untile I reach the step about materialization of the workspace contents.
At this point using the Buckminster MSpec at http://git.eclipse.org/c/cdo/cdo.git/plain/releng/org.eclipse.emf.cdo.releng/local.mspec?h=streams/4.0-maintenance
I get an error:
java.io.FileNotFoundException: File not found: http://git.eclipse.org/c/cdo/cdo.git/plain/releng/org.eclipse.emf.cdo.releng/build.cquery
Looking at path http://git.eclipse.org/c/cdo/cdo.git/plain I can see that there is not a child directory named releng (just .gitignore, features and plugins).
Is no more possible to download sources for version 4.0?
Re: [CDO] Download sources of version 4.0 [message #794498 is a reply to message #794442] Thu, 09 February 2012 06:20 Go to previous messageGo to next message
Am 09.02.2012 10:46, schrieb Federico Tomassetti:
> I get an error: java.io.FileNotFoundException: File not found:
That's likely because of this bug in buckminster: https://bugs.eclipse.org/bugs/show_bug.cgi?id=368573
I can not tell where on their roadmap that is ;-(
Yes, we've moved it to plugins/ after 4.0 GA.
The workaround is to manually clone the git repo and checkout the branch "streams/4.0-maintenance". Then just import the
local.mspec with buckminster.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Download sources of version 4.0 [message #794520 is a reply to message #794498] Thu, 09 February 2012 06:50 Go to previous messageGo to next message
Thanks but I have a problem checking out the source code from git.
I executed:
git clone -b streams/4.0-maintenance http://git.eclipse.org/c/cdo/cdo.git
This is what I get:
Cloning into cdo...
error: The requested URL returned error: 403 (curl_result = 22, http_code = 403, sha1 = 6930e96c95da9ba3dfbc957db9ab3d936196d216)
error: Unable to get pack index http://git.eclipse.org/c/cdo/cdo.git/objects/pack/pack-ce4e763572d2abd05bf81693752c704ddd0ae0d8.idx
error: Unable to get pack index http://git.eclipse.org/c/cdo/cdo.git/objects/pack/pack-544ffb798818c38074eed954a26bcacfc346fa61.idx
error: Unable to find 6930e96c95da9ba3dfbc957db9ab3d936196d216 under http://git.eclipse.org/c/cdo/cdo.git
Cannot obtain needed object 6930e96c95da9ba3dfbc957db9ab3d936196d216
error: Fetch failed.
Re: [CDO] Download sources of version 4.0 [message #794536 is a reply to message #794520] Thu, 09 February 2012 07:07 Go to previous messageGo to next message
Am 09.02.2012 12:50, schrieb Federico Tomassetti:
> I executed:
> This is what I get:
> Cloning into cdo...
I've never seen that before. But I always clone the entire repo and not just a branch (if that's what -b does). Then I
*checkout* a working tree from a specific branch. Would that work for you?
Cheers
/Eike
Re: [CDO] Download sources of version 4.0 [message #794539 is a reply to message #794536] Thu, 09 February 2012 07:15 Go to previous messageGo to next message
Nope...
git clone http://git.eclipse.org/c/cdo/cdo.git
Cloning into cdo...
Apparently I have a certain talent in finding weird ways to spot problems in a system...
ASAP I will try for a different machine, maybe something is wrong with my Git installation.
Re: [CDO] Download sources of version 4.0 [message #794546 is a reply to message #794539] Thu, 09 February 2012 07:26 Go to previous messageGo to next message
Am 09.02.2012 13:15, schrieb Federico Tomassetti:
> Nope...
Only now I realize that you're using the http: URL. I always use git://git.eclipse.org/gitroot/cdo/cdo.git and
eventually escalate to ssh: when I want to push something.
Cheers
/Eike
Re: [CDO] Download sources of version 4.0 [message #794549 is a reply to message #794546] Thu, 09 February 2012 07:30 Go to previous messageGo to next message
I tried also with the git schema. The error changes:
git clone -b streams/4.0-maintenance git://git.eclipse.org/c/cdo/cdo.git
Cloning into cdo...
fatal: The remote end hung up unexpectedly
git clone git://git.eclipse.org/c/cdo/cdo.git
Cloning into cdo...
Re: [CDO] Download sources of version 4.0 [message #794655 is a reply to message #794549] Thu, 09 February 2012 09:38 Go to previous message
Am 09.02.2012 13:30, schrieb Federico Tomassetti:
> Cloning into cdo...
> Cloning into cdo...
I just tried it and here I have no problems. If you're sure that it's not a problem on your end you should ask
webmaster@eclipse.org for advice. I'm sorry that I can not help with this.
Cheers
/Eike
Previous Topic:EMF and Schematron
Next Topic:Research Papers on CDO
Current Time: Sat Jul 26 12:09:46 EDT 2025
Powered by FUDForum. Page generated in 0.04102 seconds
