Home » Eclipse Projects » Rich Client Platform (RCP) » Solutions for fine-grained extensibility in RCP applications?
Solutions for fine-grained extensibility in RCP applications? [message #783412] Wed, 25 January 2012 12:10 Go to next message
What's the best way to provide detailed customization support in a shared RCP-application base without littering all the base plugins with extension points for everything, or forcing the customization code to maintain copies of large chunks of code that are mostly copies of the base?
Our demands for customer-specific behavior are plentiful, hard to anticipate, and highly important to the customers, but also often quite small. Customizations may include: special default selections in certain combo boxes on SWT/JFace master-details form pages, addition or removal of individual elements in layouts, special treatment of certain values in the sorting of tables or other data structures etc.
I have come up with the following 4 approaches to the problem, but I am curious how others are dealing with the balance of granularity and maintainability when it comes to providing extensibility?
1) Provide extension points for every small customization request - makes the customizations well-defined, but litters the base product code with extension points for every detail and demands a lot of code and XML for small changes.
2) Provide few extension points for major chunks, such as a whole form page, and force the customization plugin to implement the whole chunk as it sees fit - most of the customization chunk will be a duplicate of shared base and a lot of the maintainability will be lost.
3) Maintain copies of the customized base plugins - similar maintainability problems as in solution 2 but plugin-versioning and code repository compares may actually make it easier to identify and migrate customized behavior.
4) Use OSGi framework hooks to inject customized classes into the plugins' class loaders to override behaviors - probably the least code to maintain for each customization, but difficult in patch management, and a nightmare for debugging and plugin-versioning.
Re: Solutions for fine-grained extensibility in RCP applications? [message #786727 is a reply to message #783412] Mon, 30 January 2012 14:07 Go to previous messageGo to next message
Other options include providing preferences (sounds like many) that can be tweaked by preference imports or plugin_customization.ini files.
Or maintaining a configuration file of your choice with all the options (we maintain a workbench.xml) that you can modify and store in your plugin state location (down in the workspace/.metadata folder).
PW
Re: Solutions for fine-grained extensibility in RCP applications? [message #794375 is a reply to message #786727] Thu, 09 February 2012 03:02 Go to previous message
Thanks for the reply. Yes, configuration is another interesting an option, but one needs to watch that they don't become too many so they basically replace the Java files and declare the whole GUI/app.
There's also the maintenance issue when work is done one the base plugins, but one can alleviate that by declaring the parameters in extension point interfaces as methods, so one gets compilation errors in the extensions when migrating to newer base plugin versions.
Previous Topic:Is WorkbenchResolutionGenerator description implemented?
Next Topic:Give input to a view
Current Time: Sat Jul 26 21:20:23 EDT 2025
Powered by FUDForum. Page generated in 0.03824 seconds
