Project directory does not expand [message #793246] |
Tue, 07 February 2012 18:26  |
I'm using OpenSuse 12.1 and Eclipse Indigo (eclipse-cpp-indigo-SR1-incubation-linux-gtk-x86_64).
Files that I add as projects come from OpenFOAM and are written in C++.
Installation ran ok, without problems. I can launch Eclipse and add projects.
When I add a folder that contains files in it as a project and try to expand it, Eclipse crashes. If the folder has folders in it, I can expand it until the moment there are files in the folder.
The error message I get is attached. This error didn't occur when I was using OpenSuse 11.4.
How can I fix the problem?
Paulo
Re: Project directory does not expand [message #793729 is a reply to message #793507] |
Wed, 08 February 2012 08:38  |
On 2012.02.08 1:16, Paulo Bufacchi wrote:
> Yes, I did read it. But I thought this was not a development question,
> as it relates to a basic problem of opening a project file. But if you
> think so, I'll post my question there.
> Thanks.
It's just that even though this isn't overtly C/C++, it has to do with
problems that may be more recognizable to those using Eclipse CDT. But,
I may be misteering you here. If so, I hope someone else will recognize
this problem and answer.
I shifted from openSuSE right about 11.1 to Ubunut and, though an
ex-Novell engineer, I haven't regretted my switch (until the advent of
Natty/Oneiric and Unity).
Best of luck.
FUDForum. Page generated in 0.21439 seconds
