Home » Newcomers » Newcomers » Project directory does not expand
Project directory does not expand [message #793246] Tue, 07 February 2012 18:26 Go to next message
I'm using OpenSuse 12.1 and Eclipse Indigo (eclipse-cpp-indigo-SR1-incubation-linux-gtk-x86_64).
Files that I add as projects come from OpenFOAM and are written in C++.
Installation ran ok, without problems. I can launch Eclipse and add projects.
When I add a folder that contains files in it as a project and try to expand it, Eclipse crashes. If the folder has folders in it, I can expand it until the moment there are files in the folder.
The error message I get is attached. This error didn't occur when I was using OpenSuse 11.4.
How can I fix the problem?
Paulo
Re: Project directory does not expand [message #793270 is a reply to message #793246] Tue, 07 February 2012 19:16 Go to previous messageGo to next message
> Paulo
Did you read the sticky posts at the top of this forum? You'll likely
get more help with C/C++ development questions in the Eclipse CDT forum.
Re: Project directory does not expand [message #793507 is a reply to message #793270] Wed, 08 February 2012 03:16 Go to previous messageGo to next message
Yes, I did read it. But I thought this was not a development question, as it relates to a basic problem of opening a project file. But if you think so, I'll post my question there.
Thanks.
Re: Project directory does not expand [message #793729 is a reply to message #793507] Wed, 08 February 2012 08:38 Go to previous message
> Thanks.
It's just that even though this isn't overtly C/C++, it has to do with
problems that may be more recognizable to those using Eclipse CDT. But,
I may be misteering you here. If so, I hope someone else will recognize
this problem and answer.
I shifted from openSuSE right about 11.1 to Ubunut and, though an
ex-Novell engineer, I haven't regretted my switch (until the advent of
Natty/Oneiric and Unity).
Best of luck.
Previous Topic:JVM Problem (Already Tried Recommended)
Next Topic:Manual File Install
Current Time: Sun Jul 27 15:36:41 EDT 2025
Powered by FUDForum. Page generated in 0.06928 seconds
