Home » Modeling » OCL » CompleteOCLEObjectValidator and UML meta model
CompleteOCLEObjectValidator and UML meta model [message #792104] Mon, 06 February 2012 11:10 Go to next message
I have registered an CompleteOCLEObjectValidator for a sample OCL file with a rule on the UML meta model in the EValidator registry:
OCL file
import 'http[:]//www.eclipse.org/emf/2002/Ecore'
import 'http[:]//www.eclipse.org/emf/2002/GenModel'
import 'http[:]//www.eclipse.org/uml2/3.0.0/UML'
package uml
	context Classifier
	inv NoInheritanceCycles('There is a cycle in the inheritence, one of the parents of class "'+self.name+'" is the class itself.') :
	not self.allParents()->includes(self)
endpackage
plugin.xml
   <extension
         point="org.eclipse.ui.startup">
      <startup
            class="org.eclipse.ocl.validation.pivot.example.ExampleValidatorRegistration">
      </startup>
   </extension>
IStartup implementation
public class ExampleValidatorRegistration implements IStartup {
	private static final URI exampleURI = URI.createURI("platform:/plugin/org.eclipse.ocl.validation.pivot.example/constraints/sample.ocl");
	public void earlyStartup() {
		UMLPackage _package = UMLPackage.eINSTANCE;
		// Register EValidator
		EValidator.Registry.INSTANCE.put(
				_package,
				new CompleteOCLEObjectValidator(_package,exampleURI));
The evaluation of the query fails during validation. An Exception is thrown during evaluation of the query: org.eclipse.ocl.examples.pivot.InvalidEvaluationException: 'Boolean' value required.
I don't get it, the OCL Console doesn't have a problem with the query. Is this a bug in the CompleteOCLEObjectValidator or do I miss something?
P.S. I am not allowed to post links until I have 5 posts in the forum, so I replaced ":" by "[:]" in the URIs
Re: CompleteOCLEObjectValidator and UML meta model [message #792169 is a reply to message #792104] Mon, 06 February 2012 12:39 Go to previous messageGo to next message
Hi Max
Unfortunately the MDT/UML2 project does not provide an initialisation
routine for you comparable to Xtext's doSetup(). MDT/OCL partially
rectifies this in OCL.initializeResourceSet(). The Standalone
Initialisation section in the OCL Documentation (Help Contents) provides
more.
Ed Willink
On 06/02/2012 16:10, Max Bureck wrote:
> Hello,
> OCL file
> package uml
> context Classifier inv NoInheritanceCycles('There is a cycle
> class itself.') : not self.allParents()->includes(self)
> endpackage
> plugin.xml
> <extension
> <startup
> </startup>
> </extension>
> @Override
> _package,
> value required.
Re: CompleteOCLEObjectValidator and UML meta model [message #792612 is a reply to message #792169] Tue, 07 February 2012 02:25 Go to previous messageGo to next message
Hi Ed,
Thanks for your answer.
I don't see how this would help. I am in an Eclipse environment not in a standalone application, so the initialization is already done when the Validator gets registered and later when the validation actually gets invoked.
If you want I can attach the tiny plugin and the UML file to be validated. It's a very small example and I followed the OCL help sites exactly when defining it.
I already registered a validator for an OCL file on an own meta model in a different plugin, which worked. So it looks like it's somehow linked to the UML2 meta model or how it is implemented.
Re: CompleteOCLEObjectValidator and UML meta model [message #792620 is a reply to message #792612] Tue, 07 February 2012 02:37 Go to previous messageGo to next message
> validated.
That would certainly help.
> when defining it.
Sometimes these have bugs in too.
Ed Willink
Re: CompleteOCLEObjectValidator and UML meta model [message #792688 is a reply to message #792620] Tue, 07 February 2012 04:31 Go to previous messageGo to next message
I attached a zip containing the plugin project and a UML file violating the constraint.
  • Attachment: example.zip
    (Size: 4.97KB, Downloaded 294 times)
Re: CompleteOCLEObjectValidator and UML meta model [message #793994 is a reply to message #792688] Wed, 08 February 2012 15:15 Go to previous messageGo to next message
Thanks for the example; it exposed a few bugs for me in the current code.
On Indigo SR1 I could not reproduce your 'Boolean' problem. I get 3 OCL
Validation result ... is invalid. The problem is that thenon-OCL
implementation of allParents() is not accessed
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=371002), but you didn't
need it anyway.
Your invariant is a composition cycle test. You want an inheritance
cycle test:
context Class
inv NoInheritanceCycles('There is a cycle in the inheritance, one
self->closure(superClass)->excludes(self)
Ed Willink
On 07/02/2012 09:31, Max Bureck wrote:
Re: CompleteOCLEObjectValidator and UML meta model [message #794087 is a reply to message #793994] Wed, 08 February 2012 17:42 Go to previous message
Alright, thanks for taking care of this problem! The Exception with the message "'Boolean' value required" is raised inside of the validator, when query.accept(...) is called. To the outside the message "OCL validation result of ''...'' is invalid" will be shown.
Thanks again,
Max
Previous Topic:Problem OCL + Ecore Validation
Next Topic:OCL as query language for UML models?
Current Time: Sat Jul 26 21:23:35 EDT 2025
Powered by FUDForum. Page generated in 0.04845 seconds
