@ObjectTypeConverter + RCP = Error [message #792276] |
Mon, 06 February 2012 15:36  |
hi all!
i have a simple rcp + gemini
mapping works at all fine, but if i try to convert enum to string with @ObjectTypeConverter, i get an error. but with @Enumerated(EnumType.ORDINAL) is everything ok! do i something wrong, or is it bug from eclipselink or gemini? may be i forgot some bundle to activate before org.eclipse.gemini.jpa ?
mapping:
@ObjectTypeConverter(name = "stateEnumToString", dataType = String.class, objectType = State.class,
conversionValues = {
@ConversionValue(dataValue = "INITIAL", objectValue = "INITIAL"),
@ConversionValue(dataValue = "ACTIVE", objectValue = "ACTIVE"),
@ConversionValue(dataValue = "DELETED", objectValue = "DELETED"),
@ConversionValue(dataValue = "UNKNOWN", objectValue = "UNKNOWN"),
@ConversionValue(dataValue = "INACTIVE", objectValue = "INACTIVE")}
, defaultObjectValue = "UNKNOWN")
error:
javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [puTestData] failed.
Internal Exception: Exception [EclipseLink-7156] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Unable to find the class named [java.lang.String]. Ensure the class name/path is correct and available to the classloader.
Internal Exception: java.lang.ClassNotFoundException: java/lang/String
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1385)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:98)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.initPersistenceUnits(JPAInitializer.java:306)
at org.eclipse.gemini.jpa.provider.GeminiOSGiInitializer.initializeFromBundle(GeminiOSGiInitializer.java:119)
at org.eclipse.gemini.jpa.provider.EclipseLinkOSGiProvider.assignPersistenceUnitsInBundle(EclipseLinkOSGiProvider.java:191)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.tryAssigningPersistenceUnitsInBundle(PersistenceBundleExtender.java:172)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.bundleChanged(PersistenceBundleExtender.java:314)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1523)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1459)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1454)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.processDelta(PackageAdminImpl.java:487)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.doResolveBundles(PackageAdminImpl.java:253)
at org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1.run(PackageAdminImpl.java:173)
at java.lang.Thread.run(Thread.java:680)
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:221)
... 17 more
Caused by: Exception [EclipseLink-7156] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.ValidationException
at org.eclipse.persistence.exceptions.ValidationException.unableToLoadClass(ValidationException.java:1949)
at org.eclipse.persistence.internal.jpa.metadata.MetadataHelper.getClassForName(MetadataHelper.java:111)
at org.eclipse.persistence.internal.jpa.metadata.ORMetadata.getJavaClass(ORMetadata.java:273)
at org.eclipse.persistence.internal.jpa.metadata.converters.ObjectTypeConverterMetadata.process(ObjectTypeConverterMetadata.java:206)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processConvert(MappingAccessor.java:1352)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingConverter(MappingAccessor.java:1533)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingValueConverter(MappingAccessor.java:1562)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.BasicAccessor.process(BasicAccessor.java:383)
at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.processMappingAccessors(MetadataDescriptor.java:1435)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processMappingAccessors(ClassAccessor.java:1482)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processMappingAccessors(EntityAccessor.java:1053)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.process(EntityAccessor.java:619)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage2(MetadataProject.java:1627)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:518)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:526)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1320)
... 16 more
Caused by: java.lang.ClassNotFoundException: java/lang/String
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getClassForName(PrivilegedAccessHelper.java:119)
at org.eclipse.persistence.internal.jpa.metadata.MetadataHelper.getClassForName(MetadataHelper.java:97)
... 30 more
bundle start levels (rcp itself and bundle with data starts at default start level)
<configurations>
<plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.gemini.jpa" autoStart="true" startLevel="3" />
<plugin id="org.eclipse.osgi" autoStart="true" startLevel="-1" />
<plugin id="org.eclipse.persistence.jpa" autoStart="true" startLevel="0" />
</configurations>
FUDForum. Page generated in 0.05558 seconds
