Home » Eclipse Projects » Virgo » Virgo, Jetty 8 and WebSockets
Virgo, Jetty 8 and WebSockets [message #792012] Mon, 06 February 2012 09:05 Go to next message
Any early releases of virgo with Jetty 8?
Our bundle uses WebSockets which needs Jetty 8.
I am currently attempting merging Jetty 8 manually into Virgo because a co-worker suggested Virgo and Jetty are very loosely coupled, and a move from 7.4 to 8 shouldn't be too hard.
Suggestions?
Schedule on the upgrade to Jetty 8?
Thanks.
Joel
Re: Virgo, Jetty 8 and WebSockets [message #792041 is a reply to message #792012] Mon, 06 February 2012 09:42 Go to previous messageGo to next message
Jetty 8 will be a part of the Virgo 3.5 release which is scheduled for the Eclipse release train in June. The actual work required for this is actually happening very soon so you can have a play with snapshot builds. I expect the work required to upgrade to Jetty (8.1 actually) to be very straight forward, simply replace the jars using new ones from Maven central and then update the Jetty Web Plan file to point at the new versions, look in repository/ext for the plan file. That should be it but I will be able to tell you more once I've done the actual work here.
FYI, we will be upgrading the 3.0.x line to Jetty 7.6 as well.
Chris.
Re: Virgo, Jetty 8 and WebSockets [message #792068 is a reply to message #792041] Mon, 06 February 2012 10:17 Go to previous messageGo to next message
Cool. It will be great if Tomcat supports WebSocket as well.
The major problem I belive, is the incomplet specification of this protocol. What a shame. Sad.
Re: Virgo, Jetty 8 and WebSockets [message #792261 is a reply to message #792041] Mon, 06 February 2012 15:12 Go to previous messageGo to next message
Ok i tried that...must be missing something small. It's close.
I see references to 7.4.2.v20110526 in poms, but nowhere else I can find.
* Changed:
<artifact type="bundle" name="org.eclipse.jetty.osgi.boot" version="[7.3, 8)"/>
to
<artifact type="bundle" name="org.eclipse.jetty.osgi.boot" version="[7.3, 8.1)"/>
* copied Jetty 8.1.0 Jars verbatim in .. similar to jetty-ajp-8.1.0.v20120127.jar.
Exception:
[2012-02-06 14:35:52.375] system-artifacts <ME0003I> Dump 'servicea
ility\dump\2012-02-06-14-35-999' generated
[2012-02-06 14:35:52.379] system-artifacts <DE0002E> Installation o
plan 'org.eclipse.virgo.jetty.web' version '3.0.0' failed. java.lang.IllegalAr
umentException: Supplied file 'C:\virgo-jetty-server-3.5.0.M02Original\reposito
y\ext\jetty-osgi-boot-7.4.2.v20110526.jar' must exist
at org.eclipse.virgo.util.common.Assert.isTrue(Assert.java:43)
at org.eclipse.virgo.util.io.ZipUtils.unzipTo(ZipUtils.java:62)
at org.eclipse.virgo.util.io.JarUtils.unpackTo(JarUtils.java:41)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactS
orage.synchronize(StandardArtifactStorage.java:86)
orage.synchronize(StandardArtifactStorage.java:59)
orage.<init>(StandardArtifactStorage.java:54)
orageFactory.create(StandardArtifactStorageFactory.java:54)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardInstallAr
ifactGraphInclosure.createInstallGraph(StandardInstallArtifactGraphInclosure.ja
a:110)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.createI
stallArtifactGraph(PlanResolver.java:112)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate
PlanResolver.java:70)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.access$
(PlanResolver.java:62)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver$1.visit
PlanResolver.java:56)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visitInternal(Thre
dSafeGraphNode.java:193)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visit(ThreadSafeGr
phNode.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.transfo
m(PlanResolver.java:53)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.T
ansformationStage.doProcessGraph(TransformationStage.java:54)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStag
.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.
oProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipel
ne.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplication
eployer.driveInstallPipeline(PipelinedApplicationDeployer.java:286)
eployer.doInstall(PipelinedApplicationDeployer.java:165)
eployer.install(PipelinedApplicationDeployer.java:137)
eployer.deploy(PipelinedApplicationDeployer.java:204)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer
ArtifactDeployingRunnable.deployArtifacts(InitialArtifactDeployer.java:156)
ArtifactDeployingRunnable.run(InitialArtifactDeployer.java:146)
at java.lang.Thread.run(Thread.java:662)
[2012-02-06 14:35:52.405] system-artifacts <DE0003E> Install failed
for plan 'org.eclipse.virgo.jetty.web' version '3.0.0'.
Re: Virgo, Jetty 8 and WebSockets [message #792281 is a reply to message #792068] Mon, 06 February 2012 15:45 Go to previous message
There is already a work in this direction - https://issues.apache.org/bugzilla/show_bug.cgi?id=51181
Once it is available in some Tomcat 7.0.x version, Virgo Tomcat Server can adapt it.
Previous Topic:Running Virgo with the security manager
Next Topic:Virgo and STS 2.7.2
Current Time: Sat Jul 26 02:40:53 EDT 2025
Powered by FUDForum. Page generated in 0.19437 seconds
