Home » Archived » BIRT » 2nd Y-axis not visible on deployed report(Chart deployement)
icon4.gif  2nd Y-axis not visible on deployed report [message #789416] Thu, 02 February 2012 19:25 Go to next message
Could you please help me with the following problem:
I have a bar-chart with a 2nd Y-axis with lines.
When I set the data type for the values to integer the report is showed correctly in eclipse and on the birt viewer on tomcat 6.
When I change the data type to time the report is showing only correctly in eclipse and the lines are not displayed on the birt viewer on tomcat 6.
I have the same problem in IE and firefox.
Re: 2nd Y-axis not visible on deployed report [message #789961 is a reply to message #789416] Fri, 03 February 2012 11:12 Go to previous messageGo to next message
Can you post the report?
Jason
Re: 2nd Y-axis not visible on deployed report [message #790331 is a reply to message #789416] Fri, 03 February 2012 23:34 Go to previous messageGo to next message
I have attached the report.
Re: 2nd Y-axis not visible on deployed report [message #792331 is a reply to message #790331] Mon, 06 February 2012 17:16 Go to previous message
If you size the chart smaller does it show up? If you are not printing
the chart set a custom size in the master page.
Jason
Previous Topic:Need help to generate PDF Report
Next Topic:How To Add Text To Group Header
Current Time: Sun Jul 27 05:34:09 EDT 2025
Powered by FUDForum. Page generated in 0.07773 seconds
