Re: problems with debugging a web page with Xdebug [message #79005 is a reply to message #78999] |
Mon, 25 August 2008 12:25  |
It should do this, what parameters are put into the url field for the browser ?
are you sure your launch configuration specifies xdebug ?
Have you tried configuring PDT to use an external browser to see if that helps ?
(window-->preferences, select general, web browser to configure). Eclipse does seem to have problems
at times with internal browser selection.
Dave Kelsey
Lorenzo Bettini wrote:
> Hi
> I successfully installed xdebug which works correctly (I'm using PDT 2
> and ganymede under Linux);
> however, when I create a debug configuration, although I correctly set
> all the parameters, the internal web browser does not start automatically.
> I can debug a web page only if I manually insert in the web browser the
> same url plus the string ?XDEBUG_SESSION_START=ECLIPSE_DBGP
> why this is not done automatically?
> thanks in advance
> Lorenzo
FUDForum. Page generated in 0.03214 seconds
