[QVTo] Disambiguation of black-box operations [message #789953] |
Fri, 03 February 2012 11:01  |
Hi there,
I've been using QVTo black box operations for a while now. It's a great
way to make some operations over models pluggable.
That been said, I faced long time ago the problem of being unable to
disambiguate operations having the same name, and being contributed by
different classes. The editor doesn't seen to allow using black-box name
space.
Is there a way to achieve this, or is it just unimplemented?
Víctor.
Re: [QVTo] Disambiguation of black-box operations [message #798423 is a reply to message #798408] |
Tue, 14 February 2012 12:24   |
Hi Ed,
So shall I assume it is not implemented?
Not sure how to achieve it, but changing the grammar of the language and
modify the editor (assuming thats the solution) doesn't sound like an
simple patch ;) I know you are well trained on that field, for what I've
heard around, so it may be piece of cake for you :P
I sounds cheaper to me to find a workaround instead (trying to remove
the need of disambiguation).
Thanks for your feedback,
Víctor.
Ed Willink escribió:
> Hi Victor
> It looks like you'll have to help yourself. It's probably a relatively
> simple patch.
> Regards
> Ed Willink
> On 14/02/2012 14:51, Víctor Roldán Betancort wrote:
>> ping?
>> Víctor Roldán Betancort escribió:
>>> Hi there,
>>> space.
>>> Thanks,
>>> Víctor.
Re: [QVTo] Disambiguation of black-box operations [message #798447 is a reply to message #798423] |
Tue, 14 February 2012 12:59  |
Hi Victor
Who knows?
Certainly a workaround is quicker.
Hopefully QVTo will start to move again after Juno.
Ed Willink
FUDForum. Page generated in 0.04831 seconds
