How to access stereotypes of uml elements? [message #789913] |
Fri, 03 February 2012 10:13  |
how can i access stereotypes of uml elements? I load the uml model with the following java code:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI("org.eclipse.uml2.uml.source_3.2.0.v201105231350.jar!/");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
uri.appendSegment("profiles").appendSegment(""));
URI modeluri = URI.createURI("mymodel.uml");
Resource resource = resourceSet.getResource(modeluri,true);
Now i can access all elements of the uml model. But it is not possible to get the stereotypes of some elements in the uml model. Does anybody know how i can access stereotypes which are defined by an uml profile which is linked with the loaded uml model?
Andreas
[Updated on: Fri, 03 February 2012 10:35] by Moderator
Re: How to access stereotypes of uml elements? [message #789950 is a reply to message #789913] |
Fri, 03 February 2012 11:00   |
I think there are some helper functions called something like
getAppliedStereotypes().
Ed Willink
On 03/02/2012 15:13, Andreas Burger wrote:
> Hello,
> URI uri =
> Know i can access all elements of the uml model. But it is not
> Regards,
> Andreas
Re: How to access stereotypes of uml elements? [message #793633 is a reply to message #791848] |
Wed, 08 February 2012 06:22  |
I agree with Peter.
It seems profile were not loaded correctly. Probably the profiles are
referenced using the "platform:/plugin/" or "platform:/resource" URI. In
this case one has to add "platform:/plugin/" or "platform:/resource" to
the URI map.
The easiest way to check if the profile was loaded correctly is to see
if model.getAppliedProfiles() list contains your profile.
Tatiana Fesenko
ModelSolv, Inc.
Model-Oriented Solutions for Service Integration
FUDForum. Page generated in 0.05102 seconds
