Error adding a part [message #789869] |
Fri, 03 February 2012 09:11  |
Back to the tutorial. I have created ther perspective stack/partsashcontainer/part stack. When I add the part I get the error below.
Is this a bug or is it something strange with the various install and updates I have done to my installation. If it is a bug do I just log it in bugzilla.
It does not stop the app launching but I can't put labels etc on the part as it won't render in the editor.
eclipse.buildId=I20120127-1145
java.version=1.6.0_29
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri Feb 03 14:01:45 GMT 2012
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
java.lang.NoSuchFieldError: APPLICATION_ELEMENT__PERSISTED_STATE
at org.eclipse.e4.tools.emf.ui.internal.common.component.PartEditor.createForm(PartEditor.java:289)
at org.eclipse.e4.tools.emf.ui.internal.common.component.PartEditor.doGetEditor(PartEditor.java:130)
at org.eclipse.e4.tools.emf.ui.common.component.AbstractComponentEditor.getEditor(AbstractComponentEditor.java:120)
at org.eclipse.e4.tools.emf.ui.internal.common.ModelEditor$5$1.run(ModelEditor.java:522)
at org.eclipse.core.databinding.observable.ObservableTracker.runAndCollect(ObservableTracker.java:150)
at org.eclipse.core.databinding.ObservablesManager.runAndCollect(ObservablesManager.java:103)
at org.eclipse.e4.tools.emf.ui.internal.common.ModelEditor$5.selectionChanged(ModelEditor.java:519)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1211)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1241)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:233)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:999)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:893)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:85)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:579)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:534)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:352)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:624)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:579)
at org.eclipse.equinox.launcher.Main.run(Main.java:1433)
FUDForum. Page generated in 0.09330 seconds
