Home » Language IDEs » PHP Development Tools (PDT) » PDT - 'An internal error occured during Selection Job titile'
PDT - 'An internal error occured during Selection Job titile' [message #78887] Thu, 21 August 2008 17:00 Go to next message
Originally posted by: cuco2772.gmail.com
I thought everything was working with PDT. I had just installed PDT using
the Update MAnager and my local directory where I downloaded the
integration build.
I opened the PHP perspective and created a new project by rt clicking in
the
PHP explorer. Then I tried to add a new file to the project by rt clicking
on the project and and choosing new PHP file. This is when I got the
following error
message:
An internal error has occured during "Selection Job titile"
org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration. (Lorg/eclipsedltk.ast/declarations/ModuleDeclaration;
I would definitely appreciate any info I can get on what might be causing
this.
Adam Posner
Re: PDT - 'An internal error occured during Selection Job titile' [message #78900 is a reply to message #78887] Thu, 21 August 2008 17:39 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
http://wiki.eclipse.org/PDT/Installation#Known_Problems
Adam Posner wrote:
> Hi, I thought everything was working with PDT. I had just installed PDT
> using the Update Manager and my local directory where I downloaded the
> integration build.
> the PHP explorer. Then I tried to add a new file to the project by rt
> clicking on the project and and choosing new PHP file. This is when I
> got the following error
> message:
Re: PDT - 'An internal error occured during Selection Job titile' [message #78953 is a reply to message #78900] Sat, 23 August 2008 21:00 Go to previous messageGo to next message
THanks for the link. I downloaded this file from there:
dltk-core-sdk-S-1.0M1-200808150915-incubation.zip
and unzipped it as per the directions in the dropins folder.
Unfortunately the problem still persists. Anything else I could try? Thanks
Re: PDT - 'An internal error occured during Selection Job titile' [message #79011 is a reply to message #78953] Mon, 25 August 2008 17:05 Go to previous messageGo to next message
Can somebody give me a link to which build fixes this problem ?
I'm thinking maybe I didn't downLoad the right one.
I downloaded the stable build from here:
http://download.eclipse.org/technology/dltk/downloads/drops/ R1.0/S-1.0M1-200808150915/
I downloaded the 'Core frameworks' 'SDK download' 9.7 mb.
So maybe this was not the right one. Can somebody tell me because it says
this bug was fixed
Re: PDT - 'An internal error occured during Selection Job titile' [message #79019 is a reply to message #79011] Mon, 25 August 2008 19:17 Go to previous messageGo to next message
Maybe you didn't install it correctly, or you didn't remove an earlier
version first which is conflicting.
The install instructions (http://wiki.eclipse.org/PDT/Installation)
worked the last time I tried them.
> says this bug was fixed
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: PDT - 'An internal error occured during Selection Job titile' [message #79041 is a reply to message #79019] Tue, 26 August 2008 08:28 Go to previous messageGo to next message
The PDT integration build is really buggy. Don't use it. Use the nightlies
instead.
Re: PDT - 'An internal error occured during Selection Job titile' [message #79403 is a reply to message #79041] Tue, 02 September 2008 14:51 Go to previous messageGo to next message
Originally posted by: falk.koziol.gmx.de
> nightlies instead.
I ran into this error at first, too.
With these versions I fixed my problem:
PDT: 2.0.0 N20080823
DLT Core: 0.95.0.v20080716
DLT RDS: 0.95.0.v20080623
Re: PDT - 'An internal error occured during Selection Job titile' [message #79520 is a reply to message #79403] Thu, 04 September 2008 04:22 Go to previous message
I fixed this error like this. Downloaded latest integration build of DLTK
Core and DLTK RSE from
And downloaded last nightly build of PDT from
http://download.eclipse.org/tools/pdt/downloads/
Then uninstalled DLTK Core, DLTK RSE and PDT from Eclipse, restarted
Eclipse, added local repository of extracted just downloded archives and
installed them. Everything works.
Files I used:
dltk-core-I-I200809020446-200809020446-incubation.zip
dltk-rse-I-I200809020446-200809020446-incubation.zip
org.eclipse.php_feature-N20080902.zip
Previous Topic:Problems with Eclipse PDT +XDebug
Next Topic:PHP missing since EMF update
Current Time: Thu Nov 27 21:41:13 EST 2025
Powered by FUDForum. Page generated in 0.05628 seconds
