Home » Modeling » Ecore Tools » UI Acceleo Launcher Project fails(Acceleo ecore eclipse plugin)
UI Acceleo Launcher Project fails [message #760437] Fri, 02 December 2011 06:29 Go to next message
I've followed this simple tutorial wiki.eclipse.org/Acceleo/Getting_Started to create an UI launcher...
but when I finish and I make a click on 'Acceleo Model to Text'>'generate ecore2dataspace' are created the folder 'src-gen' empty!!
On Error Log View are showed this error:
java.io.IOException: '/elt/codegeneration/ecore2dataspace/files/generate.emtl' not found
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:409)
at elt.codegeneration.ecore2dataspace.files.Generate.<init>(Generate.java:90)
at elt.codegeneration.ecore2dataspace.ui.common.GenerateAll.doGenerate(GenerateAll.java:91)
at elt.codegeneration.ecore2dataspace.ui.popupMenus.AcceleoGenerateEcore2dataspaceAction$1.run(AcceleoGenerateEcore2dataspaceAction.java:76)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
It doesn't found the file generate.emtl but in Jar plugin are there.
If I try to start the plup-in by launching a separate Eclipse application (By Maniferst.mf) everything works!!!
I've Acceleo - Text generation from models Version: 3.1.0.
Eclipse Platform Version: 3.7.0
Re: UI Acceleo Launcher Project fails [message #788117 is a reply to message #760437] Wed, 01 February 2012 06:11 Go to previous messageGo to next message
I have exactly the same problem, did you find a solution?
I have the .emtl file in my plugin, but it do not work. I test, with pack on unpack plugin, but the error is the same. I had construct my plugin from Acceleo 3.0.5, but nw it is compiled with 3.1.0.
If I copy the emtl file in the same folder than mtl file it works... And in a runtime application it works too...
Thanks.
Re: UI Acceleo Launcher Project fails [message #788989 is a reply to message #788117] Thu, 02 February 2012 08:21 Go to previous message
I found the problem, acceleo 3.1.0 have a problem generating th build.acceleo file
adding the line :
outputFolder="${target.folder}"
after the line of sourceFolder resolve the error.
Previous Topic:Extension Point Modeling Framework
Next Topic:[ecoretools] Problem creating opposite ERelation through the graphical editor
Current Time: Fri Jul 18 16:59:22 EDT 2025
Powered by FUDForum. Page generated in 0.05390 seconds
