Home » Language IDEs » Java Development Tools (JDT) » InputStream not working in Eclipse for me
InputStream not working in Eclipse for me [message #788573] Wed, 01 February 2012 19:38 Go to next message
I'm not sure if eclipse is doing this but. I'm not able to do inputStreams like I've been trying to. I'm trying to run a simple program. I'm not very fond with Ecplise. I'm not sure if it is the code or the program.
I come up with these errors.
FileInputStream.open(String)line: not available[native method]
FileInputStream.<init>(File)line: not available
Scanner.<init>(File)line: not available
prog201.main(String[])line: 10
import java.util.Scanner;
import java.io.*;
class prog201
  public static void main (String[] args) throws IOException
    File    file = new File("myData.txt");   // create a File object
    Scanner scan = new Scanner( file );      // connect a Scanner to the file
    int num, square;
    num = scan.nextInt();
    square = num * num ;
    System.out.println("The square of " + num + " is " + square);
Re: InputStream not working in Eclipse for me [message #788954 is a reply to message #788573] Thu, 02 February 2012 07:29 Go to previous message
Where is the file myData.txt kept? A full absolute name could be specified or a relative path to the user directory or working directory can be specified. Look for javadoc of java.io.File for more information.
Previous Topic:[Axis2 PlugIn] Output path without src
Next Topic:How to Draw a line inside a Table?
Current Time: Mon Jun 16 19:37:24 EDT 2025
Powered by FUDForum. Page generated in 0.02942 seconds
