Home » Modeling » EMF » [CDO] Programmatically get the DB mapping
[CDO] Programmatically get the DB mapping [message #788790] Thu, 02 February 2012 03:17 Go to next message
Hi everybody,
Is there a way the consult the DB mapping programmatically ?
My needs is to know:
- What is the table name for a given EClass ?
- What is the column name for the given EStructuralFeature ?
Thanks in adavnce.
Re: [CDO] Programmatically get the DB mapping [message #794291 is a reply to message #788790] Thu, 09 February 2012 00:25 Go to previous messageGo to next message
Hi Christophe,
I apologize for the late reply.
Comments below...
Am 02.02.2012 09:17, schrieb Christophe Moine:
> Hi everybody,
Sure, but not on the client. On the CDO server you can ask:
IRepository repository = getRepository();
EClass eClass = getModel1Package().getAddress();
IDBStore store = (IDBStore)repository.getStore();
IMappingStrategy mappingStrategy = store.getMappingStrategy();
IClassMapping classMapping = mappingStrategy.getClassMapping(eClass);
IDBTable table = classMapping.getDBTables().get(0);
System.out.println(eClass.getName() + " --> " + table);
for (ITypeMapping valueMapping : classMapping.getValueMappings())
System.out.println(" " + valueMapping.getFeature().getName() + " --> " + valueMapping.getField());
The output will be:
Address --> model1_Address
name --> name
street --> street
city --> city
------------------------- END -------------------------
All columns (fields), including the cdo system ones, can be listed with:
for (IDBField field : table.getFields())
System.out.println(" " + field);
The output will be:
model1_Address
cdo_id
cdo_version
cdo_created
cdo_revised
cdo_resource
cdo_container
cdo_feature
name
street
city
If you want to use this information at the client-side you need to write your own Net4j mini protocol.
http://www.eclipse.org/cdo/documentation/presentations/DemoCampBerlin_2009/Net4j-Presentation.pdf gives hints on how to
do this.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Programmatically get the DB mapping [message #794650 is a reply to message #794291] Thu, 09 February 2012 09:34 Go to previous messageGo to next message
Hi Christophe,
comments below.
Am 09.02.12 06:25, schrieb Eike Stepper:
> Hi Christophe,
me too :-(
> Comments below...
>> Hi everybody,
Other that the comment of Eike, you can also specify the table names for
EClasses as an EAnnotation.
The following code is from DBAnnotationsTest.java:
private void addTableNameAnnotation(EPackage model1, String value)
EAnnotation annotation = EcoreFactory.eINSTANCE.createEAnnotation();
annotation.setSource("http://www.eclipse.org/CDO/DBStore");
annotation.getDetails().put("tableName", value);
EClass category = (EClass)model1.getEClassifier("Category");
category.getEAnnotations().add(annotation);
private void addColumnNameAnnotation(EPackage model1, String value)
annotation.getDetails().put("columnName", value);
EStructuralFeature element =
category.getEStructuralFeature(Model1Package.CATEGORY__NAME);
element.getEAnnotations().add(annotation);
Stefan
> The output will be:
> name --> name
> street --> street
> city --> city
> The output will be:
> model1_Address
> cdo_id
> cdo_version
> cdo_created
> cdo_revised
> cdo_resource
> cdo_container
> cdo_feature
> name
> street
> city
> gives hints on how to do this.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] Programmatically get the DB mapping [message #794652 is a reply to message #794291] Thu, 09 February 2012 09:39 Go to previous messageGo to next message
Hello Eike and Stefan,
thank you very much for your answers, unfortunatly I would like to know the mapping on the client Sad Stefan I guess your solution is to run your code on the server as well ?
By the way, is there any plans to access the IStore on the client side ? Or this is at the opposite of the CDO architecture ?
Christophe.
[Updated on: Thu, 09 February 2012 09:49] by Moderator
Re: [CDO] Programmatically get the DB mapping [message #794670 is a reply to message #794652] Thu, 09 February 2012 09:58 Go to previous messageGo to next message
Am 09.02.2012 15:39, schrieb Christophe Moine:
> Hello Eike,
> thank you very much for your answer, unfortunatly I would like to know the mapping on the client :(
> architecture ?
You can only access the IStore directly if the repository is embedded into the client. Otherwise you'll need some kind
of remoting technology.
Cheers
/Eike
Re: [CDO] Programmatically get the DB mapping [message #1059612 is a reply to message #794291] Mon, 20 May 2013 15:57 Go to previous messageGo to next message
I apologize for reviving an old thread, but I am having an issue running the suggested code.
When I attempt to run :
I am getting an IllegalStateException:
Caused by: java.lang.IllegalStateException: session == null
	at org.eclipse.emf.cdo.server.StoreThreadLocal.getSession(StoreThreadLocal.java:62)
	at org.eclipse.emf.cdo.server.StoreThreadLocal.getAccessor(StoreThreadLocal.java:87)
	at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMetaID(MetaDataManager.java:88)
	at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getUniqueID(AbstractMappingStrategy.java:410)
	at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getTableName(AbstractMappingStrategy.java:323)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.initTable(AbstractHorizontalClassMapping.java:115)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.<init>(AbstractHorizontalClassMapping.java:105)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditClassMapping.<init>(HorizontalAuditClassMapping.java:95)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditMappingStrategy.doCreateClassMapping(HorizontalAuditMappingStrategy.java:49)
	at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.createClassMapping(AbstractMappingStrategy.java:506)
	at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getClassMapping(AbstractMappingStrategy.java:553)
I am using CDO 4.2.0.v20121114-0954.
My clients are able to connect to the server and retrieve/send data to the database. Any suggestions?
Thanks!
Re: [CDO] Programmatically get the DB mapping [message #1059652 is a reply to message #1059612] Tue, 21 May 2013 02:13 Go to previous messageGo to next message
Am 20.05.2013 21:57, schrieb Kyle B:
Many methods in a repository need an IStoreAccessor that encapsulates backend-specific connection information such as a
java.sql.Connection for relational databases. This store accessor is kept in the StoreThreadLocal class. All code that
is executed in the scope of client requests receives such a store accessor (through an ISession) in CDOServerReadIndication:
protected void execute(BufferInputStream in, BufferOutputStream out) throws Exception
try
InternalSession session = getSession();
StoreThreadLocal.setSession(session);
super.execute(in, out);
finally
StoreThreadLocal.release();
If you call server code without going through a network request you need to register a store accessor yourself. In
Repository.java there's an example:
protected void readPackageUnits()
IStoreAccessor reader = store.getReader(null);
StoreThreadLocal.setAccessor(reader);
try
Collection<InternalCDOPackageUnit> packageUnits = reader.readPackageUnits();
for (InternalCDOPackageUnit packageUnit : packageUnits)
packageRegistry.putPackageUnit(packageUnit);
finally
Does that help?
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks!
Re: [CDO] Programmatically get the DB mapping [message #1059726 is a reply to message #1059652] Tue, 21 May 2013 08:11 Go to previous message
Thank you Sir. Works perfectly now.
Previous Topic:Automatic population of transient attributes
Next Topic:Customized Edit and Editor generated code that suppress some model objects
Current Time: Thu Jul 31 04:48:22 EDT 2025
Powered by FUDForum. Page generated in 0.21979 seconds
