Home » Language IDEs » ServerTools (WTP) » eclipse & sts cannot start tomcat: ports already in use(Tomcat startup hangs at 23%)
eclipse & sts cannot start tomcat: ports already in use [message #788750] Thu, 02 February 2012 01:59 Go to next message
Tested eclipse indigo, STS 2.5.2, STS 2.8.0, STS 2.8.5. Tomcat 6, Tomcat 7.
Tomcat startup hangs at 23%(displayed at right bottom side of eclipse windows/screen). This magic number is always the same. After about 20 seconds at hanged state error occurs. Error info is "ports are already in use".
There is no Tomcat already started in system. No ports with specified numbers appear in netstat.
Changing port numbers does not help anything.
Changing/reinstalling eclipse,STS,tomcat, downloading fresh tomcat zip changes nothing. Deleting workspace and C:/Project/.metadata and stuff - all directories used by fresh install of STS, so deleting them does not help too.
And interesting history aspect: i've used STS 2.8.2 for 2 weeks before this error occured. Reinstall won't fix anything. After that i was able to use STS 2.5.2 for a month. And the same error occured for 2.8.2. But i delete all its files and reinstall again does not fix anything.
Reboot does not help.
Have no any other working with tomcat version of eclipse/STS.
Any help is appreciated.
my os is windows 7. In Virtualbox XP everything is fine. And other Windows 7 guys say it works too on their PCs.
stackoverflow.com/questions/9096490/eclipse-sts-cannot-start-tomcat-ports-already-in-use
[Updated on: Thu, 02 February 2012 02:00] by Moderator
Re: eclipse & sts cannot start tomcat: ports already in use [message #792433 is a reply to message #788750] Mon, 06 February 2012 20:41 Go to previous message
> in use".
> help too.
> stackoverflow.com/questions/9...already-in-use
I don't know if you have found a solution, but checking the source code,
anything that causes "new java.net.ServerSocket(port, 0, address)" to
throw an exception results in the "already in use" error. Since it is
more than one port that is in use (there is a singular version of the
error if only one of the ports is in use), something in the OS would
appear to be preventing Eclipse from opening server sockets when testing
for port usage.
There is no logging available to expose the actual exception occurring
in Eclipse, but there are some debugging tricks that can be used. Just
let me know if you need me to supply the specifics.
Larry
Previous Topic:Error on JavaScript File - Unable to Deploy Web Project
Next Topic:Metro Web Service Runtime
Current Time: Thu Jul 24 21:18:20 EDT 2025
Powered by FUDForum. Page generated in 0.04092 seconds
