Home » Eclipse Projects » WindowBuilder » Problems to update org.eclipse.wb.core.lib_1.3.0.r37x20120131...
Problems to update org.eclipse.wb.core.lib_1.3.0.r37x20120131... [message #788367] Wed, 01 February 2012 13:13 Go to next message
my Eclipse tries to update to org.eclipse.wb.core.lib_1.3.0.r37x20120131...
It tries it now for some hours. When I watch the message it seems the the file is downloaded again and again.
Anybody else with this problem?
How can I solve?
Greetings
Rainer
Re: Problems to update org.eclipse.wb.core.lib_1.3.0.r37x20120131... [message #788629 is a reply to message #788367] Wed, 01 February 2012 21:31 Go to previous messageGo to next message
No idea. I tried it and it worked fine for me.
Try restarting Eclipse and trying it again.
Re: Problems to update org.eclipse.wb.core.lib_1.3.0.r37x20120131... [message #807397 is a reply to message #788367] Sun, 26 February 2012 06:42 Go to previous message
I have had the same issue for quite a while now. I thought it might be a temporary server problem but I can safely exclude that option now.
My file is org.eclipse.wb.runtime.lib_1.3.0.r37xxx I have a fresh installation of Eclipse 3.7 for Java. The one where there is already a button for visual classes in the standard tool bar. Only Swing is installed in that package, already. For creating SWT classes, the SWT designer needs to be installed. That's the point where I have this issue.
Rainer, could you solve this by now?
Previous Topic:using WindowBuilder in Eclipse Indigo
Next Topic:How can I get WindowBuilder sources?
Current Time: Wed Jul 23 11:36:37 EDT 2025
Powered by FUDForum. Page generated in 0.07982 seconds
