Home » Language IDEs » C / C++ IDE (CDT) » compilation error - mission header files
compilation error - mission header files [message #78849] Fri, 22 August 2003 08:58 Go to next message
Originally posted by: rb200m.doc.ic.ac.uk
using MinGW, the compiler compains that the header files <sys/socket.h>
and <netinet/in.h> cannot be found. I've had a look and indeed they are
missing from the /include directory.
So i installed Cygwin instead and the file are readily available but there
is no make.exe or gcc.exe under the Cygwin/bin directory.
Any ideas
Cheers :-)
Re: compilation error - mission header files [message #78864 is a reply to message #78849] Fri, 22 August 2003 12:07 Go to previous messageGo to next message
These header files are specific to UNIX and _not_ Windows. Windows uses
a little different APIs where Inet is going through Winsock.
> Any ideas
> Cheers :-)
Did you check the make and gcc within the setup.exe program?
Re: compilation error - mission header files [message #79002 is a reply to message #78864] Tue, 26 August 2003 05:09 Go to previous messageGo to next message
Yes, indeed. It is a UNIX project, which i've imported into Eclipse's CDT,
and there are differences in the socket programming API between Win and
UNIX, but i was thinking the project would still compile under CDT because
we're using CYGWIN which is a UNIX environment for windows.
Are u saying that i should rewrite specific parts of the project to
conform with winsock API??
Thanx for the help :-)
> > Any ideas
> > Cheers :-)
I installed most packages, except a couple i think. Now i can find
"make.exe" but still not gcc or g++?? I'll try installing the whole
thing-ahhh, this is gonna take ages. Good luck me!
Re: compilation error - mission header files [message #79026 is a reply to message #79002] Tue, 26 August 2003 21:09 Go to previous messageGo to next message
Well, this depends on your program requirements. If you want to compile
by using the cygwin headers and libs, you have to supply the cygwin.dll
with your program. If this is no option, you should separate the
low-level socket access. The MinGW toolchain is gcc/g++ based but its
using the winapi. I do not know of an extra library simulating the UNIX
socket API yet.
>>>Any ideas
>>>Cheers :-)
Maybe you missed the package. In the setup program gcc/g++ is available
under the Developing tree.
Re: compilation error - mission header files [message #79090 is a reply to message #79026] Wed, 27 August 2003 09:21 Go to previous messageGo to next message
> socket API yet.
> >>>Any ideas
> >>>Cheers :-)
The compiler now doesnt complain about missing header file but i get a
link error saying:
/usr/lib/gcc-lib/i686-pc-cygwin/3.2/../../../libcygwin.a(lib cmain.o)(.text+0x7c):
undefined reference to `_WinMain@16'
collect2: ld returned 1 exit status
Any ideas what this means?
thanx -:)
Re: compilation error - mission header files [message #79140 is a reply to message #79090] Wed, 27 August 2003 14:54 Go to previous messageGo to next message
>>socket API yet.
>>>>>Any ideas
>>>>>Cheers :-)
> link error saying:
> thanx -:)
This seems to be an error in your linker flags.
This depends on how you link.
Put this in an example Makefile for an example project and play with
it to find out, how different it works
CC = gcc
LINKER = ld
OBJECTS = main.o
#USE_TO_LINK = CC
USE_TO_LINK = LINKER
ifeq ($(USE_TO_LINK),LINKER)
# LDFLAGS for using ld
# ld does not know of the Path (-L) and lib-name (-l) of the C-library
# so you need to give this to the linker!
LD = $(LINKER)
LDFLAGS = -L<path_to_libc> -lc
# you could also give the c-library as a fully-qualified name
#LDFLAGS = <path_to_libc>/libc.a
else
# LDFLAGS for using gcc
# Path (-L) and lib-name (-l) of the C-library is already
# "hard-coded" into gcc
LD = $(CC)
LDFLAGS =
endif
myapp.exe: $(OBJECTS)
$(LD) -o $@ $^ $(LDFLAGS)
Hope this will help to get an understanding of how the linking works
with the different tools. Btw., gcc and g++ work the same, but g++ has
also "hard-coded" path and lib for stdc++ lib.
Re: compilation error - mission header files [message #79240 is a reply to message #79140] Thu, 28 August 2003 08:11 Go to previous message
kesselhaus wrote:
> > link error saying:
> > thanx -:)
> CC = gcc
> LINKER = ld
> OBJECTS = main.o
> #USE_TO_LINK = CC
> LD = $(LINKER)
> else
> LD = $(CC)
> LDFLAGS =
> endif
Thank you so much for your time. I appreciate it :-)
ali
Previous Topic:Problem with CDT installation - "plugin reference cannot be resolved"
Next Topic:Debugging arm-elf
Current Time: Fri Nov 07 20:44:43 EST 2025
Powered by FUDForum. Page generated in 0.04462 seconds
