Home » Language IDEs » Java Development Tools (JDT) » Parameter Hints do not recognize correct method(in case of overloaded methods)
Parameter Hints do not recognize correct method [message #787529] Tue, 31 January 2012 12:24 Go to next message
	void test(int i){}
	void test(int i, boolean x){}
	void invoke() {
		test(3);
		test(6,true);
When invoking Parameter Hints by pressing ctrl-shift-space inside the parameter list in either of the two invocations of the test() method, a popup choice appears offering both variants.
Is this on purpose?
Why is not the "correct" version chosen automatically?
Especially in longer parameter lists it is a bit hard to manually figure out the correct method.
Is it possible to get a visual hint, which method is matched by the actual code?
David
(Using Indigo Service Release 1)
Re: Parameter Hints do not recognize correct method [message #787904 is a reply to message #787529] Wed, 01 February 2012 00:05 Go to previous messageGo to next message
On 1/31/2012 10:54 PM, David Balažic wrote:
> void test(int i){}
> void invoke() {
> test(3);
> test(6,true);
> Is this on purpose?
Yes this is intentional, because you may want anyone of the overloaded
methods.
> actual code?
You can place the caret on the method name in the method invocation and
press 'F2' to popup a hover containing the javadoc and the method signature.
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Re: Parameter Hints do not recognize correct method [message #787986 is a reply to message #787904] Wed, 01 February 2012 02:54 Go to previous message
Deepak Azad wrote on Wed, 01 February 2012 06:05
> void test(int i){}
> void invoke() {
> test(3);
> test(6,true);
> Is this on purpose?
methods.
> actual code?
Yes, but this does not have the feature of Parameter Hints to highlight the parameter which is under the cursor.
Previous Topic:Importing JDT Package
Next Topic:Old eclipse does not work fine on Windows 7
Current Time: Tue Jun 17 02:53:23 EDT 2025
Powered by FUDForum. Page generated in 0.07170 seconds
