StackOverflowError in WindowBuilder [message #787498] |
Tue, 31 January 2012 11:47  |
I got a StackOverflowError while opening a UI in WindowBuilder Design Page:
!ENTRY org.eclipse.wb.core 4 4 2012-01-31 17:28:34.548
!MESSAGE Designer [1.2.0.r36x201109270310.201201311728]: java.lang.StackOverflowError
!STACK 0
at java.lang.Exception.<init>(Exception.java:77)
at java.lang.reflect.InvocationTargetException.<init>(InvocationTargetException.java:54)
at sun.reflect.GeneratedConstructorAccessor79.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.wb.internal.core.utils.reflect.ReflectionUtils$ExceptionThrower.spit(ReflectionUtils.java:1284)
at org.eclipse.wb.internal.core.utils.reflect.ReflectionUtils.propagate(ReflectionUtils.java:1302)
at org.eclipse.wb.internal.core.parser.JavaInfoResolver.getJavaInfo(JavaInfoResolver.java:133)
at org.eclipse.wb.internal.core.parser.JavaInfoResolver.getExposedJavaInfo(JavaInfoResolver.java:306)
at org.eclipse.wb.internal.core.parser.JavaInfoResolver.getJavaInfo0(JavaInfoResolver.java:222)
at org.eclipse.wb.internal.core.parser.JavaInfoResolver.getJavaInfo(JavaInfoResolver.java:131)
at
The Problem is reproducable with that UI, but not with others (others just work fine).
I am using WindowBuilder in MyEclipse 10.
Markus
Re: StackOverflowError in WindowBuilder [message #788199 is a reply to message #787975] |
Wed, 01 February 2012 08:30  |
In that case, why send in a partial bug report and exclude the test case?
If you have a class that exhibits this problem, creating a test case that will reproduce that same problem should not take more than a few minutes.
I'm not sure why you would be disappointed with the level of support, since we are offerring to do just that. In fact, the very same team that worked on and supported WB before it was open sourced still works on and supports it now. I believe that our track record for responding to user questions and fixing bugs has been exceptional. We respond to almost every forum message, and we have closed 94% of bug reports in Bugzilla.
As I said earlier, we are more than willing to look into this, but you have to give us something to work with. Please read Reproducible Test Cases in the WB docs, if you need a further explanation of why this is important.
FUDForum. Page generated in 0.06166 seconds
