Parameter Hints do not recognize correct method [message #787529] |
Tue, 31 January 2012 12:24  |
void test(int i){}
void test(int i, boolean x){}
void invoke() {
test(3);
test(6,true);
When invoking Parameter Hints by pressing ctrl-shift-space inside the parameter list in either of the two invocations of the test() method, a popup choice appears offering both variants.
Is this on purpose?
Why is not the "correct" version chosen automatically?
Especially in longer parameter lists it is a bit hard to manually figure out the correct method.
Is it possible to get a visual hint, which method is matched by the actual code?
David
(Using Indigo Service Release 1)
Re: Parameter Hints do not recognize correct method [message #787986 is a reply to message #787904] |
Wed, 01 February 2012 02:54  |
Deepak Azad wrote on Wed, 01 February 2012 06:05On 1/31/2012 10:54 PM, David Balažic wrote:
> void test(int i){}
> void invoke() {
> test(3);
> test(6,true);
> Is this on purpose?
Yes this is intentional, because you may want anyone of the overloaded
methods.
> actual code?
You can place the caret on the method name in the method invocation and
press 'F2' to popup a hover containing the javadoc and the method signature.
Yes, but this does not have the feature of Parameter Hints to highlight the parameter which is under the cursor.
FUDForum. Page generated in 0.03319 seconds
