Home » Archived » BIRT » ChartWizardLauncher Example - DND Function(How can I access Category/Value Field in ChartWizard?)
ChartWizardLauncher Example - DND Function [message #786308] Mon, 30 January 2012 03:49 Go to next message
Good Morning,
I try to integrate the BIRT ChartWizard in a standalone Java Application. I used for base the ChartWizardLauncher Example. But in the Example is no Integration of the Drag & Drop Function in the Select Data flag. And if I'm writing manual stuff in the Field they will not write in DataDefinition Knot of the .chart File.
My Question is: How can I access to the Fields to manipulate the properties (to write an own function to write the value back) or how can I include the DND Function or a similar function that work so that the user can chose the Category/Value series from the dataPreviewTable below?
Please forgive me my weak English as it is not my native language.
Edit: I'm using BIRT 3.7
[Updated on: Mon, 30 January 2012 04:00] by Moderator
Re: ChartWizardLauncher Example - DND Function [message #786648 is a reply to message #786308] Mon, 30 January 2012 12:11 Go to previous messageGo to next message
Have you seen these threads:
http://www.eclipse.org/forums/index.php/mv/msg/166072/526733/#msg_526733
and
http://www.eclipse.org/forums/index.php/m/523423/#msg_523423
I have an RCP app that allows drag and drop on the data tab, but I am
not saving the data to the model yet. Still a work in progress.
Jason
On 1/30/2012 3:49 AM, Frog Manhome wrote:
> Good Morning,
Re: ChartWizardLauncher Example - DND Function [message #787197 is a reply to message #786648] Tue, 31 January 2012 04:05 Go to previous messageGo to next message
Hello Jason,
Thanks for your response.
Unfortunately the referent project links in the posted threads are dead.
May be you have an idea in which class I can find the needed information?
In simple words I only need the 'Textfield' in the Data Select View of a ChartWizard and write a String in the .chart XML.
I will not believe that this is so difficult, but I don't find a way to get these 'Textfields'. Which class provides me an access?
PS: Can I see this RCP App? Maybe it will help?
Re: ChartWizardLauncher Example - DND Function [message #787492 is a reply to message #787197] Tue, 31 January 2012 11:38 Go to previous messageGo to next message
I have attached the rcp app example.
Jason
On 1/31/2012 4:06 AM, Frog Manhome wrote:
> Hello Jason,
> information? In simple words I only need the 'Textfield' in the Data
Re: ChartWizardLauncher Example - DND Function [message #809880 is a reply to message #786648] Wed, 29 February 2012 06:47 Go to previous messageGo to next message
Jason Weathersby wrote on Mon, 30 January 2012 12:11
Jason
Hello Jason,
Now my ChartWizardLauncher run as RPC Application. I've my own DragSource Widget and the Drag and Drop writes the Text in the right Textfield.
Next step: Saving the Data in the model.
Have you an example or a suggestion how I can solve this?
ChartUIUtil.getBaseSeriesDefinitions(getChartModel()).get(0).getSeries().get(0).getDataDefinition().get(0).setDefinition(value);
allow me to write a string in the model (that is all what I need), but how (and where) can I decide which Series was the Drop Target?
Thank you.
Re: ChartWizardLauncher Example - DND Function [message #810824 is a reply to message #809880] Thu, 01 March 2012 10:40 Go to previous message
Can you email me your code and I can make it save to the correct place
in the model?
Jason
>> Jason
> Hello Jason,
> Textfield.
> Thank you.
Previous Topic:Error Duplicate aggregation name: COUNT
Next Topic:DataSet SubSet or Group?
Current Time: Sat Jul 26 08:07:06 EDT 2025
Powered by FUDForum. Page generated in 0.07950 seconds
