Home » Archived » EGL Development Tools » Help Requested(Cannot Launch Debugger)
Help Requested [message #786299] Mon, 30 January 2012 03:39 Go to next message
Hello - I am a complete newbie with EGL having just downloaded the workbench. I started by looking at the 'Getting Started' tutorial. Everything seemed ok but when I select Debug As > EGL Rich UI Application, the browser (IE9) opens blank window and nothing happens, except it looks as though the window is still loading something.
The operating system in Windows 7 64 bit.
Can anyone please suggest what might be wrong and how to fix it?
Kind Regards
Re: Help Requested [message #786315 is a reply to message #786299] Mon, 30 January 2012 04:00 Go to previous messageGo to next message
Does the application work in Preview and Design mode? IE9 is expected to work, but not fully covered in testing according to http://wiki.eclipse.org/EDT:Supported_Platforms If it always happens, you may want to open a bug https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EDT
[Updated on: Mon, 30 January 2012 04:01] by Moderator
Re: Help Requested [message #786322 is a reply to message #786315] Mon, 30 January 2012 04:12 Go to previous messageGo to next message
Hello Tony - yes the designer and preview seem ok. I will be interested in hearing if other people are having trouble with IE9. If that is indeed the case, I'll feel confident to do as you say and report a bug.
Kind Regards
Re: Help Requested [message #786501 is a reply to message #786322] Mon, 30 January 2012 09:02 Go to previous message
Hi Ron,
IE9 is not supported by the Rich UI debugger, due to IE9 preventing the use of synchronous XMLHttpRequests which the debugger is reliant upon. Here's a technote for Rational Business Developer about this, which applies to EDT as well: https://www-304.ibm.com/support/docview.wss?uid=swg21569917
You'll need to set some other browser as your external browser, as described in the technote.
-Justin
Previous Topic:Problem with running CVS sources
Next Topic:When can we expect 0.8 M1?
Current Time: Wed Jul 23 15:24:58 EDT 2025
Powered by FUDForum. Page generated in 1.04475 seconds
