Home » Eclipse Projects » EclipseLink » NPE in registerObjectForMergeCloneIntoWorkingCopy
NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786132] Sun, 29 January 2012 21:41 Go to next message
I'm using GF 3.1.1 which contains EclipseLink 2.3.0.
When I attempt to perform a merge I'm getting a NullPointerException at line 900 in MergeManager.registerObjectForMergeCloneIntoWorkingCopy.
The line in the source is:
Object primaryKey = descriptor.getObjectBuilder().extractPrimaryKeyFromObject(clone, unitOfWork, true);
There is no further line in the stacktrace so I assume that descriptor is null. Descriptor is set on the previous line in the sources as:
ClassDescriptor descriptor = unitOfWork.getDescriptor(clone.getClass());
Is there any way to determine what is causing this? I'm guessing I might be missing an entity class. Is that so?
Geoff
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786516 is a reply to message #786132] Mon, 30 January 2012 09:22 Go to previous messageGo to next message
Can you upload the full stack trace? You should also turn on logging to see if there are any messages that might show what is causing the problem.
Best Regards,
Chris
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786521 is a reply to message #786132] Mon, 30 January 2012 09:22 Go to previous messageGo to next message
Best Regards,
Chris
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786889 is a reply to message #786516] Mon, 30 January 2012 18:18 Go to previous messageGo to next message
The full stack trace is below. The "api.exceptions.ExceptionProxy" class is a wrapper around an EJBException to facilitate transport by Hessian.
SEVERE: null
at com.sun.ejb.containers.BaseContainer.processSystemException(BaseContainer.java:5193)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5091)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4879)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2039)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1990)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:222)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88)
at $Proxy223.persist(Unknown Source)
at server.servlet.DAOServlet.persist(DAOServlet.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkeleton.java:306)
at com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkeleton.java:202)
at com.caucho.hessian.server.HessianServlet.invoke(HessianServlet.java:389)
at com.caucho.hessian.server.HessianServlet.service(HessianServlet.java:369)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1539)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:281)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:330)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:174)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:828)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:725)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1019)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
at java.lang.Thread.run(Thread.java:619)
Caused by: api.exceptions.ExceptionProxy
at org.eclipse.persistence.internal.sessions.MergeManager.registerObjectForMergeCloneIntoWorkingCopy(MergeManager.java:900)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChangesOfCloneIntoWorkingCopy(MergeManager.java:500)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChanges(MergeManager.java:271)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.mergeIntoObject(ObjectReferenceMapping.java:464)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.mergeIntoObject(ObjectBuilder.java:3444)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChangesOfCloneIntoWorkingCopy(MergeManager.java:533)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mergeCloneWithReferences(UnitOfWorkImpl.java:3487)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.mergeCloneWithReferences(RepeatableWriteUnitOfWork.java:376)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mergeCloneWithReferences(UnitOfWorkImpl.java:3447)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.mergeInternal(EntityManagerImpl.java:486)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.merge(EntityManagerImpl.java:463)
at com.sun.enterprise.container.common.impl.EntityManagerWrapper.merge(EntityManagerWrapper.java:286)
at server.ejb.DAOBean.persist(DAOBean.java:185)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5366)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:800)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at sun.reflect.GeneratedMethodAccessor598.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:861)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:370)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5338)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5326)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:214)
... 36 more
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786892 is a reply to message #786516] Mon, 30 January 2012 18:18 Go to previous messageGo to next message
SEVERE: null
... 36 more
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #787067 is a reply to message #786892] Tue, 31 January 2012 00:37 Go to previous message
Seems this is related to a deeper issue to do with passing null values into the system, so can be ignored... Thanks for looking anyhow!
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #787071 is a reply to message #786892] Tue, 31 January 2012 00:37 Go to previous message
Previous Topic:update in new transaction hangs program
Next Topic:EclipseLink weaving fragment require-bundle version
Current Time: Sun Jul 20 23:29:30 EDT 2025
Powered by FUDForum. Page generated in 0.06827 seconds
