Home » Modeling » OCL » OCLInEcore recursive operations
OCLInEcore recursive operations [message #786086] Sun, 29 January 2012 19:55 Go to next message
Hello
I'm trying to make an recursive operation with OCLInEcore, but it's thrown an error that the operation was not found. Is there any solution to this problem? Does OCLInEcore does not support recursive functions? I'm doing something like this:
operation rec(n: Type1): Type2
body: if self = n then 0
else n.childs->iterate(e: Type3; acc:Integer=0 | if e.rev() > acc then e.DIT() else acc endif) endif;
Re: OCLInEcore recursive operations [message #786230 is a reply to message #786086] Mon, 30 January 2012 01:23 Go to previous messageGo to next message
Yes. OCL and OCLinEcore support recursive functions. My recollection is
that there was a bug in the name lookup of iterators, so you might try
creating a dummy let variable. This is fixed in the Juno release, though
the fix is not obviously in the N&N. Perhaps it was fixed for Indigo.
What version are you using.
Ed Willink
On 30/01/2012 00:55, Patricia Espada wrote:
> Hello
> body: if self = n then 0 else n.childs->iterate(e:
> endif;
Re: OCLInEcore recursive operations [message #786296 is a reply to message #786086] Mon, 30 January 2012 03:35 Go to previous messageGo to next message
Patricia,
just a quick observation: maybe it's a typo, but you're calling e.rev() and you are declaring an operation called "rec". Also, you're calling rev() with no arguments while rec is declared to take an argument of type Type1. So from your example I cannot see where any recursion happens. Can you clarify?
Best,
-- Axel
Patricia Espada wrote on Sun, 29 January 2012 19:55
Hello
Re: OCLInEcore recursive operations [message #786566 is a reply to message #786296] Mon, 30 January 2012 10:34 Go to previous messageGo to next message
I'm using Eclipse Modeling Tools Version: Indigo Service Release 1 Build id: 20110916-0149.
That was a simple example I came with at the moment. My problem is in a larger scale. Anyway where it is, maybe you can see any error that I'm not seeing right.
package KAOSStandard : kaos = 'kaos'
	class KAOS
		property hasCompartmentNode : CompartmentNode[*] { ordered composes };
		property hasNodes : Nodes[*] { ordered composes };
		property hasLinks : Links[*] { ordered composes };
		property root : Goal[1] { ordered };
		operation modelDepth() : ecore::EIntegerObject[1]
			body:
				self.goalsDistanceToRoot(self.root, Set{0}, 0)->iterate(i : Integer ; m : Integer = - 1 | if m = - 1 then i else m.max(i) endif);
		operation goalsDistanceToRoot(n : Nodes[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
			body:
				if n.oclIsKindOf(Goal) then
					self.depthOfGoal(n.oclAsType(Goal), dist, last)
				else
					if n.oclIsKindOf(Obstacle) then
						self.depthOfObstacle(n.oclAsType(Obstacle), dist, last)
					else
						dist
					endif
				endif;
		operation depthOfGoal(g : Goal[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
			body:
				if g.isLeafGoal() then
					self.depthOfLeafGoal(g, dist, last)
				else
					self.union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | self.goalsDistanceToRoot(n, dist->including(last + 1), last + 1))->asSet()
				endif;
		operation union(s1 : Goal[*], s2 : Nodes[*]) : Nodes[*]
			body: let s : Set(Nodes) = Set{} in s->union(s1)->union(s2);
		operation depthOfLeafGoal(g : Goal[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
			body:
				let s : Sequence(Obstacle) = g.goalHasObstacle->collect(obstacle) in
					if s->notEmpty() then
						s->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
					else
						dist
					endif;
		operation depthOfObstacle(o : Obstacle[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
			body:
				if self.isLeafObstacle(o) then
					self.depthOfLeafObstacle(o, dist, last)
				else
					self.obstacleRefinement(o)->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
				endif;
		operation obstacleRefinement(o : Obstacle[1]) : Obstacle[*]
			body:
				self.hasLinks->select(l : Links | l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = o)->collect(oclAsType(ObstacleRefinement))->collect(obstRefToObst);
		operation depthOfLeafObstacle(o : Obstacle[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
			body:
				let s : Sequence(Goal) = o.solution->collect(obstacleHasSolution) in
						s->collect(g : Goal | self.goalsDistanceToRoot(g.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
					else
						dist
					endif;
		operation isLeafObstacle(o : Obstacle[1]) : Boolean[1]
			body:
				not self.hasLinks->exists(l : Links | (l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = o));
		annotation _'gmf.diagram'
			foo = 'bar'
	abstract class Nodes
		attribute name : String[?] { ordered };
		attribute TransformationSource : String[?] { ordered };
		attribute IstarActorContainer : String[?] { ordered };
		annotation _'gmf.node'
			label = 'name',
			_'label.placement' = 'external'
	class Goal extends Nodes
		attribute formalDef : String[?] { ordered };
		attribute informalDef : String[?] { ordered };
		property goalIsOrRef#orRefToGoal : OrRefinement[*] { ordered };
		property otherGoalIsOrRef#orRefToOtherGoal : OrRefinement[*] { ordered };
		property goalIsAndRef#andRefToGoal : AndRefinement[*] { ordered };
		property otherGoalIsAndRef#andRefToOtherGoal : AndRefinement[*] { ordered };
		property goalHasObstacle#obstacleToGoal : ObstructionLink[*] { ordered };
		property solutionIsGoal#obstacleHasSolution : SolutionLink[*] { ordered };
		property goalToOperatLink#operatLinkToGoal : OperationalizationLink[*] { ordered };
		property goalConcerns#concernedByGoal : ConcernsLink[*] { ordered };
		property goalHasDomProp#DomPropLinkToGoal : DomainPropLink[*] { ordered };
		operation isLeafGoal() : Boolean[1]
			body: self.goalIsAndRef->isEmpty() and self.goalIsOrRef->isEmpty();
			color = '0,191,255',
			_'border.color' = '0,191,255',
			size = '80,50',
			figure = 'polygon',
			_'polygon.x' = '30 70 50 10',
			_'polygon.y' = '10 10 40 40',
			_'tool.description' = 'Create new Goal'
	class Obstacle extends Nodes
		property obstacleObstruction#obstacle : ObstructionLink[*] { ordered };
		property solution#obstacleSolution : SolutionLink[*] { ordered };
			color = '255,140,0',
			_'border.color' = '255,140,0',
			size = '80,50',
			figure = 'polygon',
			_'polygon.x' = '10 50 70 30',
			_'tool.description' = 'Create new Obstacle'
	abstract class Links
		attribute Source : String[?] { ordered };
		attribute Target : String[?] { ordered };
	class OrRefinement extends Links
		invariant linkToHimself('Goal ' + orRefToGoal.name + ' can not be a refinement of himself.'):
		orRefToGoal <> orRefToOtherGoal;
		property orRefToGoal#goalIsOrRef : Goal[1] { ordered };
		property orRefToOtherGoal#otherGoalIsOrRef : Goal[1] { ordered };
		annotation _'gmf.link'
			source = 'orRefToGoal',
			target = 'orRefToOtherGoal',
			color = '0,0,255',
			_'target.decoration' = 'arrow',
			width = '2',
			style = 'dash',
			_'tool.description' = 'Create new OrRefinement between Goal, Requirement or Expectation'
	class AndRefinement extends Links
		invariant linkToHimself('Goal ' + andRefToGoal.name + ' can not be a refinement of himself.'):
		andRefToGoal <> andRefToOtherGoal;
		property andRefToGoal#goalIsAndRef : Goal[1] { ordered };
		property andRefToOtherGoal#otherGoalIsAndRef : Goal[1] { ordered };
			source = 'andRefToGoal',
			target = 'andRefToOtherGoal',
			color = '0,0,255',
			width = '2',
			_'tool.description' = 'Create new AndRefinement between Goal, Requirement or Expectation'
	class ObstacleRefinement extends Links
		invariant linkToHimself('Obstacle ' + obstRefToObst.name + ' can not be a refinement of himself.'):
		obstRefToObst <> obstToObstRef;
		property obstRefToObst : Obstacle[1] { ordered };
		property obstToObstRef : Obstacle[1] { ordered };
			source = 'obstRefToObst',
			target = 'obstToObstRef',
			width = '2',
			_'tool.description' = 'Create new ObstacleRefinement between Obstacles'
	class ObstructionLink extends Links
		property obstacle#obstacleObstruction : Obstacle[1] { ordered };
		property obstacleToGoal#goalHasObstacle : Goal[1] { ordered };
			source = 'obstacle',
			target = 'obstacleToGoal',
			color = '255,165,0',
			width = '2',
			_'tool.description' = 'Create new ObstructionLink between an Obstacle and a Goal, Requirement or Expectation'
	class SolutionLink extends Links
		property obstacleHasSolution#solutionIsGoal : Goal[1] { ordered };
		property obstacleSolution#solution : Obstacle[1] { ordered };
			source = 'obstacleHasSolution',
			target = 'obstacleSolution',
			color = '0,139,0',
			width = '2',
			_'tool.description' = 'Create new SolutionLink between an Obstacle and a Goal, Requirement or Expectation'
Re: OCLInEcore recursive operations [message #786632 is a reply to message #786566] Mon, 30 January 2012 12:00 Go to previous messageGo to next message
Your example has many "..." ellisions and no CompartmentNode, so I
cannot comment on what real problems exist.
Ed Willink
> class KAOS
> composes };
> body:
> m.max(i) endif);
> body:
> self.depthOfGoal(n.oclAsType(Goal), dist, last) else
> dist, last) else dist
> endif endif;
> body:
> self.depthOfLeafGoal(g, dist, last) else
> 1))->asSet() endif;
> body:
> g.goalHasObstacle->collect(obstacle) in if
> s->notEmpty() then s->collect(o : Obstacle |
> 1), last + 1))->asSet() else
> dist endif;
> body:
> self.depthOfLeafObstacle(o, dist, last) else
> 1), last + 1))->asSet() endif;
> body:
> body:
> o.solution->collect(obstacleHasSolution) in if
> s->notEmpty() then s->collect(g : Goal |
> dist endif;
> body:
> foo = 'bar'
> label = 'name',
> ordered };
> ordered };
> ordered };
> { ordered };
> ordered };
> { ordered };
> size = '80,50',
> figure = 'polygon',
> ordered };
> size = '80,50',
> figure = 'polygon',
> color = '0,0,255',
> width = '2',
> style = 'dash',
> ordered };
> color = '0,0,255',
> width = '2',
> width = '2',
> between Obstacles'
> width = '2',
> ordered };
> color = '0,139,0',
> width = '2',
Re: OCLInEcore recursive operations [message #786659 is a reply to message #786632] Mon, 30 January 2012 12:28 Go to previous message
I though what it was more simple if a do not put the entire example. Anyway here it is:
module _'KAOS.ecore'
import ecore : 'http://www.eclipse.org/emf/2002/Ecore#/';
	class KAOS
		operation numLeafGoals() : ecore::EIntegerObject[?]
			body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal())->size();
		operation numLeafGoalsWithAgents() : ecore::EIntegerObject[?]
			body:
				self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfAgents() > 0)->size();
		operation numLeafGoalsWithObjects() : ecore::EIntegerObject[?]
			body:
				self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfObjects() > 0)->size();
		operation numLeafObstacles() : ecore::EIntegerObject[?]
			body:
				self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and not self.hasLinks->exists(l : Links | (l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = n.oclAsType(Obstacle))))->size();
		operation numLeafGoalsWithOperations() : ecore::EIntegerObject[?]
			body:
				self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfOperations() > 0)->size();
		operation numOperations() : ecore::EIntegerObject[?]
			body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode))->size();
		operation numOperationsWithAgents() : ecore::EIntegerObject[?]
			body:
				self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode) and n.oclAsType(OperationNode).operationNumberOfAgents() > 0)->size();
		operation numAgents() : ecore::EIntegerObject[?]
			body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->size();
		operation numLeafGoalsWithConcerns() : ecore::EIntegerObject[?]
			body:
				self.hasLinks->select(l : Links | l.oclIsKindOf(ConcernsLink) and l.oclAsType(ConcernsLink).concernedByGoal.isLeafGoal())->size();
			body:
			body:
				if n.oclIsKindOf(Goal) then self.depthOfGoal(n.oclAsType(Goal), dist, last) else if n.oclIsKindOf(Obstacle) then self.depthOfObstacle(n.oclAsType(Obstacle), dist, last) else dist endif endif;
			body:
				if g.isLeafGoal() then self.depthOfLeafGoal(g, dist, last) else self.union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | self.goalsDistanceToRoot(n, dist->including(last + 1), last + 1))->asSet() endif;
			body:
				let s : Sequence(Obstacle) = g.goalHasObstacle->collect(obstacle) in if s->notEmpty() then s->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() else dist endif;
			body:
				if self.isLeafObstacle(o) then self.depthOfLeafObstacle(o, dist, last) else self.obstacleRefinement(o)->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() endif;
			body:
			body:
				let s : Sequence(Goal) = o.solution->collect(obstacleHasSolution) in if s->notEmpty() then s->collect(g : Goal | self.goalsDistanceToRoot(g.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() else dist endif;
			body:
		operation depth() : ecore::EIntegerObject[1]
			body:
				let s : OrderedSet(Nodes) = OrderedSet{self.root.oclAsType(Goal)} in s->iterate(n : Nodes ; i : Integer = 0 | s = s->union(n.oclAsType(Goal).goalIsAndRef->collect(andRefToOtherGoal)->asOrderedSet())->excluding(n) and i = i + 1);
		operation modelDit() : ecore::EIntegerObject[1]
			body:
				self.hasNodes->iterate(n : Nodes ; i : Integer = 0 | if n.oclIsKindOf(Goal) and n.oclAsType(Goal).dit(self.root) > i then n.oclAsType(Goal).dit(self.root) else i endif);
			foo = 'bar'
	abstract class CompartmentNode
	class GoalCompartmentNode extends CompartmentNode
		property compHasGoals : Goal[*] { ordered composes }
			annotation _'gmf.compartment'
				layout = 'free'
			label = 'name',
			_'border.color' = '0,0,255',
			size = '200,100',
			_'border.width' = '2',
			'Create new GoalCompartmentNode for inserting Goals, Requirements and Expectations in the diagram'
	class SoftgoalCompartmentNode extends CompartmentNode
		property softgoalCompHasSoftgoals : Softgoal[*] { ordered composes }
				layout = 'free'
			label = 'name',
			_'border.color' = '0,100,0',
			size = '200,100',
			_'tool.description' = 'Create new SoftgoalCompartmentNode for inserting Softgoals in the diagram'
	class ObstacleCompartmentNode extends CompartmentNode
		property obstCompNodeHasObstacle : Obstacle[*] { ordered composes }
				layout = 'free'
			label = 'name',
			_'border.color' = '255,165,0',
			size = '200,100',
			_'tool.description' = 'Create new ObstacleCompartmentNode for inserting Obstacles in the diagram'
	class DomainPropertiesCompartmentNode extends CompartmentNode
		property domProCompNodeHasDomProp : DomainProperties[*] { ordered composes }
				layout = 'free'
			label = 'name',
			_'border.color' = '148,0,211',
			size = '200,100',
			'Create new DomainPropertiesCompartmentNode for inserting Domain Invariants and Domain Hipothesis in the diagram'
	class AgentCompartmentNode extends CompartmentNode
		property agentCompHasAgent : Agent[*] { ordered composes }
				layout = 'free'
			label = 'name',
			_'border.color' = '255,105,180',
			size = '200,100',
			'Create new AgentCompartmentNode for inserting System Agents and Environment Agents in the diagram'
	class ObjectCompartmentNode extends CompartmentNode
		property objCompHasObjects : Object[*] { ordered }
				layout = 'free'
			label = 'name',
			_'border.color' = '165,42,42',
			size = '200,100',
			_'tool.description' = 'Create new ObjectCompartmentNode for creating Entities and Events in the diagram'
	class OperationCompartmentNode extends CompartmentNode
		property hasOperationNodes : OperationNode[*] { ordered }
				layout = 'free'
			label = 'name',
			size = '200,100',
			_'tool.description' = 'Create new OperationCompartmentNode for inserting Operations in the diagram'
			label = 'name',
		operation goalAgents() : Agent[*]
			body:
				let s : Sequence(Agent) = if self.oclIsKindOf(Expectation) then self.oclAsType(Expectation).expToAgentExpLink->collect(expLinkToAgent) else if self.oclIsKindOf(Requirement) then self.oclAsType(Requirement).ReqToAgentReqLink->collect(ReqToAgentLink) else Sequence{} endif endif in s->union(self.otherGoalIsOrRef->collect(orRefToGoal)->union(self.otherGoalIsAndRef->collect(andRefToGoal))->collect(g : Goal | g.goalAgents()));
		operation goalNumberOfAgents() : ecore::EIntegerObject[?]
			body: self.goalAgents()->size();
		operation goalNumberOfObjects() : ecore::EIntegerObject[?]
			body: self.goalConcerns->collect(concernsObject)->size();
		operation goalNumberOfOperations() : ecore::EIntegerObject[?]
			body: self.goalToOperatLink->collect(operatLinkToOperationNode)->size();
			size = '80,50',
			figure = 'polygon',
	class Requirement extends Goal
		property ReqToAgentReqLink#agentReqLinkToReq : AgentReqLink[+] { ordered };
			_'border.color' = '0,0,0',
			size = '80,50',
			figure = 'polygon',
			_'tool.description' = 'Create new Requirement'
	class Expectation extends Goal
		property expToAgentExpLink#agentExpLinkToExp : AgentExpLink[+] { ordered };
			color = '255,215,0',
			_'border.color' = '255,215,0',
			size = '80,50',
			figure = 'polygon',
			_'tool.description' = 'Create new Expectation'
	class Softgoal extends Goal
			color = '50,205,50',
			_'border.color' = '50,205,50',
			size = '40,40',
			figure = 'ellipse',
			_'tool.description' = 'Create new Softgoal'
		operation obstacleNumberOfSolutions() : ecore::EIntegerObject[?]
			body: self.solution->size();
			size = '80,50',
			figure = 'polygon',
	abstract class DomainProperties extends Nodes
		property domPropToGoal#goalToDomProp : DomainPropLink[+] { ordered };
	class DomainInvariant extends DomainProperties
			color = '221,160,221',
			_'border.color' = '221,160,221',
			size = '80,50',
			figure = 'polygon',
			_'polygon.x' = '10 40 70 70 10',
			_'polygon.y' = '20 10 20 40 40',
			_'tool.description' = 'Create new DomainInvariant'
	class DomainHyphothesis extends DomainProperties
			color = '147,112,219',
			_'border.color' = '147,112,219',
			size = '80,50',
			figure = 'polygon',
			_'tool.description' = 'Create new DomainHyphothesis'
	abstract class Object extends Nodes
		property objToInhLink#inhLinkToObject : InheritanceLink[*] { ordered };
		property otherObjToInhLink#inhLinkToOtherObj : InheritanceLink[*] { ordered };
		property objToAggLink#aggLinkToObject : AggregationLink[*] { ordered };
		property otherObjToAggLink#aggLinkToOtherObject : AggregationLink[*] { ordered };
		property objToCardLink#cardLinkToObject : CardinalityLink[*] { ordered };
		property otherObjToCardLink#cardLinkToOtherObject : CardinalityLink[*] { ordered };
		property objIsMonitored#monLinkToObject : MonitorsLink[*] { ordered };
		property objIsControlled#contLinkToObject : ControlsLink[*] { ordered };
		property objectIsConcerned#concernsObject : ConcernsLink[*] { ordered };
	abstract class Agent extends Object
		property agentMonitors#monLinkToAgent : MonitorsLink[*] { ordered };
		property agentControls#contLinkToAgent : ControlsLink[*] { ordered };
		property agentPerforms#perLinkToAgent : PerformsLink[*] { ordered };
		operation agentNumberOfLeafGoals() : ecore::EIntegerObject[?]
			body:
				if self.oclIsKindOf(EnvironmentAgent) then self.oclAsType(EnvironmentAgent).numLeafGoals() else if self.oclIsKindOf(SystemAgent) then self.oclAsType(SystemAgent).numLeafGoals() else 0 endif endif;
	class SystemAgent extends Agent
		property agentToReqLink#ReqToAgentLink : AgentReqLink[+] { ordered };
			body: self.agentToReqLink->collect(agentReqLinkToReq)->size();
			color = '255,160,122',
			_'border.color' = '255,160,122',
			size = '80,50',
			figure = 'polygon',
			_'polygon.x' = '10 20 60 70 60 20',
			_'polygon.y' = '25 40 40 25 10 10',
			_'tool.description' = 'Create new SystemAgent'
	class EnvironmentAgent extends Agent
		property agentToExpLink#expLinkToAgent : AgentExpLink[+] { ordered };
			body: self.agentToExpLink->collect(agentExpLinkToExp)->size();
			color = '255,182,193',
			_'border.color' = '255,182,193',
			size = '80,50',
			figure = 'polygon',
			_'tool.description' = 'Create new EnvironmentAgent'
	class Event extends Object
		attribute frequency : ecore::EInt[?] { ordered };
			color = '189,183,107',
			_'border.color' = '189,183,107',
			size = '80,50',
			figure = 'polygon',
			_'polygon.x' = '10 10 60 70 60',
			_'polygon.y' = '10 40 40 25 10',
			_'tool.description' = 'Create new Event'
	class Entity extends Object
			color = '143,188,143',
			_'border.color' = '143,188,143',
			size = '60,30',
			figure = 'rectangle',
			_'tool.description' = 'Create new Entity'
	class Relationship extends Object
		property relationConnObject : Object[1] { ordered };
		property objectIsConnByRelation : Object[1] { ordered };
			label = 'name',
			source = 'relationConnObject',
			target = 'objectIsConnByRelation',
			color = '255,127,80',
			width = '2',
			_'tool.description' = 'Create new Relationship between two Objects'
	class OperationNode extends Nodes
		property operationNodeToOperatLink#operatLinkToOperationNode : OperationalizationLink[*] { ordered };
		property operationIsPerformed#perLinkToOperationNode : PerformsLink[*] { ordered };
		operation operationNumberOfAgents() : ecore::EIntegerObject[?]
			body: self.operationIsPerformed->collect(perLinkToAgent)->size();
			color = '211,211,211',
			_'border.color' = '211,211,211',
			size = '60,30',
			figure = 'ellipse',
			_'tool.description' = 'Create new OperationNode'
			color = '0,0,255',
			width = '2',
			style = 'dash',
			color = '0,0,255',
			width = '2',
			width = '2',
			width = '2',
			color = '0,139,0',
			width = '2',
	class OperationalizationLink extends Links
		attribute label : String[1] = 'Operationalization' { ordered readonly };
		property operatLinkToGoal#goalToOperatLink : Goal[1] { ordered };
		property operatLinkToOperationNode#operationNodeToOperatLink : OperationNode[1] { ordered };
			label = 'label',
			source = 'operatLinkToGoal',
			target = 'operatLinkToOperationNode',
			color = '105,105,105',
			width = '2',
			_'tool.description' = 'Create new OperationalizationLink between an Operation and a Goal'
	class ConcernsLink extends Links
		attribute label : String[1] = 'Concerns' { ordered readonly };
		property concernedByGoal#goalConcerns : Goal[1] { ordered };
		property concernsObject#objectIsConcerned : Object[1] { ordered };
			label = 'label',
			source = 'concernedByGoal',
			target = 'concernsObject',
			color = '205,133,63',
			width = '2',
			_'tool.description' = 'Create new ConcernsLink between a Goal, Requirement or Expectation and an Object'
	class DomainPropLink extends Links
		property DomPropLinkToGoal#goalHasDomProp : Goal[1] { ordered };
		property goalToDomProp#domPropToGoal : DomainProperties[1] { ordered };
			source = 'DomPropLinkToGoal',
			target = 'goalToDomProp',
			color = '148,0,211',
			width = '2',
			'Create new DomainPropLink between Goal, Requirement or Expectation and Domain Invariant or Domain Hipothesis'
	class AgentReqLink extends Links
		property ReqToAgentLink#agentToReqLink : SystemAgent[1] { ordered };
		property agentReqLinkToReq#ReqToAgentReqLink : Requirement[1] { ordered };
			source = 'ReqToAgentLink',
			target = 'agentReqLinkToReq',
			color = '233,150,122',
			width = '2',
			_'tool.description' = 'Create new AgentReqLink for connecting a System Agent to a Requirement'
	class AgentExpLink extends Links
		property expLinkToAgent#agentToExpLink : EnvironmentAgent[1] { ordered };
		property agentExpLinkToExp#expToAgentExpLink : Expectation[1] { ordered };
			source = 'expLinkToAgent',
			target = 'agentExpLinkToExp',
			color = '176,48,96',
			width = '2',
			_'tool.description' = 'Create new AgentExpLink for connecting an Environment Agent to an Expectation'
	class InheritanceLink extends Links
		invariant linkToHimself('Object ' + inhLinkToObject.name + ' can not be a refinement of himself.'):
		inhLinkToObject <> inhLinkToOtherObj;
		property inhLinkToObject#objToInhLink : Object[1] { ordered };
		property inhLinkToOtherObj#otherObjToInhLink : Object[1] { ordered };
			source = 'inhLinkToObject',
			target = 'inhLinkToOtherObj',
			_'target.decoration' = 'closedarrow',
			width = '2',
			_'tool.description' = 'Create new InheritanceLink between Entities'
	class AggregationLink extends Links
		invariant linkToHimself('Object ' + aggLinkToObject.name + ' can not be a refinement of himself.'):
		aggLinkToObject <> aggLinkToOtherObject;
		property aggLinkToObject#objToAggLink : Object[1] { ordered };
		property aggLinkToOtherObject#otherObjToAggLink : Object[1] { ordered };
			source = 'aggLinkToObject',
			target = 'aggLinkToOtherObject',
			_'target.decoration' = 'filledrhomb',
			width = '2',
			_'tool.description' = 'Create new AggregationLink between Entities'
	class CardinalityLink extends Links
		attribute firstEnd : String[1] { ordered };
		attribute secondEnd : String[1] { ordered };
		property cardLinkToObject#objToCardLink : Object[1] { ordered };
		property cardLinkToOtherObject#otherObjToCardLink : Object[1] { ordered };
			source = 'cardLinkToObject',
			target = 'cardLinkToOtherObject',
			width = '2',
			_'tool.description' = 'Create new CardinalityLink between Entities'
	class MonitorsLink extends Links
		attribute label : String[1] = 'Monitors' { ordered readonly };
		property monLinkToAgent#agentMonitors : Agent[1] { ordered };
		property monLinkToObject#objIsMonitored : Object[1] { ordered };
			label = 'label',
			source = 'monLinkToAgent',
			target = 'monLinkToObject',
			color = '102,205,170',
			width = '2',
			_'tool.description' = 'Create new MonitorsLink between an Object and an Agent'
	class ControlsLink extends Links
		attribute label : String[1] = 'Controls' { ordered readonly };
		property contLinkToAgent#agentControls : Agent[1] { ordered };
		property contLinkToObject#objIsControlled : Object[1] { ordered };
			label = 'label',
			source = 'contLinkToAgent',
			target = 'contLinkToObject',
			color = '34,139,34',
			width = '2',
			_'tool.description' = 'Create new ControlsLink between an Object and an Agent'
	class PerformsLink extends Links
		attribute label : String[1] = 'Performs' { ordered readonly };
		property perLinkToAgent#agentPerforms : Agent[1] { ordered };
		property perLinkToOperationNode#operationIsPerformed : OperationNode[1] { ordered };
			label = 'label',
			source = 'perLinkToAgent',
			target = 'perLinkToOperationNode',
			color = '0,0,0',
			width = '2',
			_'tool.description' = 'Create new PerformsLink between an Agent and an Operation'
	class Conflict extends Links
		invariant linkToHimself('Goal ' + conflictBtwnGoals.name + ' can not be a refinement of himself.'):
		conflictBtwnGoals <> goalHasConflict;
		attribute label : String[1] = 'Conflict' { ordered readonly };
		property conflictBtwnGoals : Goal[1] { ordered };
		property goalHasConflict : Goal[1] { ordered };
			label = 'label',
			source = 'conflictBtwnGoals',
			target = 'goalHasConflict',
			color = '205,0,0',
			_'source.decoration' = 'arrow',
			width = '2',
			style = 'dash',
			_'tool.description' = 'Create new Conflict between Goals'
	annotation gmf
		foo = 'bar'
and the problem is with the operation modelDepth
Previous Topic:[Announce] Eclipse OCL CORE 4.0.0 (Juno) M5 is now available
Next Topic:Is it possible to modify condition collections of cycle?
Current Time: Wed Jul 23 01:56:06 EDT 2025
Powered by FUDForum. Page generated in 0.04835 seconds
