Home » Modeling » GMF (Graphical Modeling Framework) » Building ecore diagram editor from sources
Building ecore diagram editor from sources [message #78128] Thu, 16 November 2006 02:12 Go to next message
Originally posted by: kalin.nakov.gmail.com
I want to add a feature to the ecore diagram editor, particularly to the
gmfgraph and gmfmap configuration files. The feature is showing the
association multiplicity in the diagram.
I tried to build GMF from sources, but unfortunately all the documents I
could find through google are out of date - wrong directories, lots of
missing files, incomplete instructions, lots of build errors from the
ant scripts, etc. I just want to get the source of the latest stable
release, make the modifications, rebuild and repackage. How can I do
that? Is there any more recent document how to build the latest stable
release from sources?
Kalin
Re: Building ecore diagram editor from sources [message #78178 is a reply to message #78128] Thu, 16 November 2006 07:21 Go to previous messageGo to next message
Hello Kalin,
If you would like to modify only ecore editor then I suggest you to:
- install released version of GMF
- checkout corresponding sources of the ecore editor from CVS: :pserver:anonymous@dev.eclipse.org:/cvsroot/technology
co org.eclipse.gmf/examples/org.eclipse.gmf.ecore.editor
- modify models and regenerate sources
- if you'll be satisfied with the result - export plugin as .jar file and
substitute old org.eclipse.gmf.ecore.editor by new one in your GMF installation
- Submitt bugsilla request for this improvement and attach your patch there
Alex Shatalin
Re: Building ecore diagram editor from sources [message #78603 is a reply to message #78178] Fri, 17 November 2006 11:58 Go to previous messageGo to next message
--------------070002030600060902070701
Hi again,
Thanks a lot for your help. Everything works, but unfortunately I can no
longer edit my old ecore diagrams, because I get a NullPointerException,
the exception log is attached. If I choose Initialize diagram from
ecore, then the new diagram is opened just fine. Why I can't open the
old diagram? It's a bit strange, because the crash is when obtaining
some font...
I have checked out, modified and repackaged revision v20060919-0800,
since that was the version of GMF which I have.
Kalin
Alex Shatalin wrote:
> Hello Kalin,
> :pserver:anonymous@dev.eclipse.org:/cvsroot/technology co
> and substitute old org.eclipse.gmf.ecore.editor by new one in your GMF
> installation
> there ;-)
> Alex Shatalin
name="exception_log.txt"
Content-Disposition: inline;
filename="exception_log.txt"
amF2YS5sYW5nLk51bGxQb2ludGVyRXhjZXB0aW9uDQoJYXQgb3JnLmVjbGlw c2UuZ21mLmVj
b3JlLmVkaXQucGFydHMuRUF0dHJpYnV0ZUVkaXRQYXJ0LnJlZnJlc2hGb250 KEVBdHRyaWJ1
dGVFZGl0UGFydC5qYXZhOjQ5NSkNCglhdCBvcmcuZWNsaXBzZS5nbWYuZWNv cmUuZWRpdC5w
YXJ0cy5FQXR0cmlidXRlRWRpdFBhcnQucmVmcmVzaFZpc3VhbHMoRUF0dHJp YnV0ZUVkaXRQ
YXJ0LmphdmE6NDUwKQ0KCWF0IG9yZy5lY2xpcHNlLmdlZi5lZGl0cGFydHMu QWJzdHJhY3RF
ZGl0UGFydC5yZWZyZXNoKEFic3RyYWN0RWRpdFBhcnQuamF2YTo2NzYpDQoJ YXQgb3JnLmVj
bGlwc2UuZ2VmLmVkaXRwYXJ0cy5BYnN0cmFjdEdyYXBoaWNhbEVkaXRQYXJ0 LnJlZnJlc2go
QWJzdHJhY3RHcmFwaGljYWxFZGl0UGFydC5qYXZhOjU1NCkNCglhdCBvcmcu ZWNsaXBzZS5n
bWYucnVudGltZS5kaWFncmFtLnVpLmVkaXRwYXJ0cy5HcmFwaGljYWxFZGl0 UGFydC5hY2Nl
c3MkMyhHcmFwaGljYWxFZGl0UGFydC5qYXZhOjEpDQoJYXQgb3JnLmVjbGlw c2UuZ21mLnJ1
bnRpbWUuZGlhZ3JhbS51aS5lZGl0cGFydHMuR3JhcGhpY2FsRWRpdFBhcnQk My5ydW4oR3Jh
cGhpY2FsRWRpdFBhcnQuamF2YTo4MjQpDQoJYXQgb3JnLmVjbGlwc2UuZW1m LnRyYW5zYWN0
aW9uLmltcGwuVHJhbnNhY3Rpb25hbEVkaXRpbmdEb21haW5JbXBsLnJ1bkV4 Y2x1c2l2ZShU
cmFuc2FjdGlvbmFsRWRpdGluZ0RvbWFpbkltcGwuamF2YToyNTgpDQoJYXQg b3JnLmVjbGlw
c2UuZ21mLnJ1bnRpbWUuZGlhZ3JhbS51aS5lZGl0cGFydHMuR3JhcGhpY2Fs RWRpdFBhcnQu
cmVmcmVzaChHcmFwaGljYWxFZGl0UGFydC5qYXZhOjgxNCkNCglhdCBvcmcu ZWNsaXBzZS5n
ZWYuZWRpdHBhcnRzLkFic3RyYWN0RWRpdFBhcnQuYWRkTm90aWZ5KEFic3Ry YWN0RWRpdFBh
cnQuamF2YToyMzUpDQoJYXQgb3JnLmVjbGlwc2UuZ2VmLmVkaXRwYXJ0cy5B YnN0cmFjdEdy
YXBoaWNhbEVkaXRQYXJ0LmFkZE5vdGlmeShBYnN0cmFjdEdyYXBoaWNhbEVk aXRQYXJ0Lmph
dmE6MjEyKQ0KCWF0IG9yZy5lY2xpcHNlLmdlZi5lZGl0cGFydHMuQWJzdHJh Y3RFZGl0UGFy
dC5hZGRDaGlsZChBYnN0cmFjdEVkaXRQYXJ0LmphdmE6MTk4KQ0KCWF0IG9y Zy5lY2xpcHNl
LmdlZi5lZGl0cGFydHMuQWJzdHJhY3RFZGl0UGFydC5yZWZyZXNoQ2hpbGRy ZW4oQWJzdHJh
Y3RFZGl0UGFydC5qYXZhOjcyNykNCglhdCBvcmcuZWNsaXBzZS5nZWYuZWRp dHBhcnRzLkFi
c3RyYWN0RWRpdFBhcnQucmVmcmVzaChBYnN0cmFjdEVkaXRQYXJ0LmphdmE6 Njc3KQ0KCWF0
IG9yZy5lY2xpcHNlLmdlZi5lZGl0cGFydHMuQWJzdHJhY3RHcmFwaGljYWxF ZGl0UGFydC5y
ZWZyZXNoKEFic3RyYWN0R3JhcGhpY2FsRWRpdFBhcnQuamF2YTo1NTQpDQoJ YXQgb3JnLmVj
bGlwc2UuZ21mLnJ1bnRpbWUuZGlhZ3JhbS51aS5lZGl0cGFydHMuR3JhcGhp Y2FsRWRpdFBh
cnQuYWNjZXNzJDMoR3JhcGhpY2FsRWRpdFBhcnQuamF2YToxKQ0KCWF0IG9y Zy5lY2xpcHNl
LmdtZi5ydW50aW1lLmRpYWdyYW0udWkuZWRpdHBhcnRzLkdyYXBoaWNhbEVk aXRQYXJ0JDMu
cnVuKEdyYXBoaWNhbEVkaXRQYXJ0LmphdmE6ODI0KQ0KCWF0IG9yZy5lY2xp cHNlLmVtZi50
cmFuc2FjdGlvbi5pbXBsLlRyYW5zYWN0aW9uYWxFZGl0aW5nRG9tYWluSW1w bC5ydW5FeGNs
dXNpdmUoVHJhbnNhY3Rpb25hbEVkaXRpbmdEb21haW5JbXBsLmphdmE6MjU4 KQ0KCWF0IG9y
Zy5lY2xpcHNlLmdtZi5ydW50aW1lLmRpYWdyYW0udWkuZWRpdHBhcnRzLkdy YXBoaWNhbEVk
aXRQYXJ0LnJlZnJlc2goR3JhcGhpY2FsRWRpdFBhcnQuamF2YTo4MTQpDQoJ YXQgb3JnLmVj
bGlwc2UuZ2VmLmVkaXRwYXJ0cy5BYnN0cmFjdEVkaXRQYXJ0LmFkZE5vdGlm eShBYnN0cmFj
dEVkaXRQYXJ0LmphdmE6MjM1KQ0KCWF0IG9yZy5lY2xpcHNlLmdlZi5lZGl0 cGFydHMuQWJz
dHJhY3RHcmFwaGljYWxFZGl0UGFydC5hZGROb3RpZnkoQWJzdHJhY3RHcmFw aGljYWxFZGl0
UGFydC5qYXZhOjIxMikNCglhdCBvcmcuZWNsaXBzZS5nZWYuZWRpdHBhcnRz LkFic3RyYWN0
RWRpdFBhcnQuYWRkQ2hpbGQoQWJzdHJhY3RFZGl0UGFydC5qYXZhOjE5OCkN CglhdCBvcmcu
ZWNsaXBzZS5nZWYuZWRpdHBhcnRzLlNpbXBsZVJvb3RFZGl0UGFydC5zZXRD b250ZW50cyhT
aW1wbGVSb290RWRpdFBhcnQuamF2YToxMDEpDQoJYXQgb3JnLmVjbGlwc2Uu Z2VmLnVpLnBh
cnRzLkFic3RyYWN0RWRpdFBhcnRWaWV3ZXIuc2V0Q29udGVudHMoQWJzdHJh Y3RFZGl0UGFy
dFZpZXdlci5qYXZhOjU4MykNCglhdCBvcmcuZWNsaXBzZS5nZWYudWkucGFy dHMuQWJzdHJh
Y3RFZGl0UGFydFZpZXdlci5zZXRDb250ZW50cyhBYnN0cmFjdEVkaXRQYXJ0 Vmlld2VyLmph
dmE6NTkyKQ0KCWF0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmRpYWdyYW0u dWkucGFydHMu
RGlhZ3JhbUVkaXRvci5pbml0aWFsaXplR3JhcGhpY2FsVmlld2VyQ29udGVu dHMoRGlhZ3Jh
bUVkaXRvci5qYXZhOjg1NCkNCglhdCBvcmcuZWNsaXBzZS5nbWYucnVudGlt ZS5kaWFncmFt
LnVpLnBhcnRzLkRpYWdyYW1FZGl0b3IuaW5pdGlhbGl6ZUdyYXBoaWNhbFZp ZXdlcihEaWFn
cmFtRWRpdG9yLmphdmE6ODQ3KQ0KCWF0IG9yZy5lY2xpcHNlLmdtZi5ydW50 aW1lLmRpYWdy
YW0udWkucGFydHMuRGlhZ3JhbUVkaXRvcldpdGhGbHlPdXRQYWxldHRlLmlu aXRpYWxpemVH
cmFwaGljYWxWaWV3ZXIoRGlhZ3JhbUVkaXRvcldpdGhGbHlPdXRQYWxldHRl LmphdmE6MTEy
KQ0KCWF0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmRpYWdyYW0udWkucGFy dHMuRGlhZ3Jh
bUVkaXRvci5jcmVhdGVHcmFwaGljYWxWaWV3ZXIoRGlhZ3JhbUVkaXRvci5q YXZhOjc5MSkN
CglhdCBvcmcuZWNsaXBzZS5nZWYudWkucGFydHMuR3JhcGhpY2FsRWRpdG9y LmNyZWF0ZVBh
cnRDb250cm9sKEdyYXBoaWNhbEVkaXRvci5qYXZhOjE2MykNCglhdCBvcmcu ZWNsaXBzZS5n
bWYucnVudGltZS5kaWFncmFtLnVpLnBhcnRzLkRpYWdyYW1FZGl0b3JXaXRo Rmx5T3V0UGFs
ZXR0ZS5jcmVhdGVQYXJ0Q29udHJvbChEaWFncmFtRWRpdG9yV2l0aEZseU91 dFBhbGV0dGUu
amF2YTozMTApDQoJYXQgb3JnLmVjbGlwc2UuZ21mLnJ1bnRpbWUuZGlhZ3Jh bS51aS5yZXNv
dXJjZXMuZWRpdG9yLnBhcnRzLkRpYWdyYW1Eb2N1bWVudEVkaXRvci5jcmVh dGVQYXJ0Q29u
dHJvbChEaWFncmFtRG9jdW1lbnRFZGl0b3IuamF2YToxNDU5KQ0KCWF0IG9y Zy5lY2xpcHNl
LnVpLmludGVybmFsLkVkaXRvclJlZmVyZW5jZS5jcmVhdGVQYXJ0SGVscGVy KEVkaXRvclJl
ZmVyZW5jZS5qYXZhOjU5NikNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5h bC5FZGl0b3JS
ZWZlcmVuY2UuY3JlYXRlUGFydChFZGl0b3JSZWZlcmVuY2UuamF2YTozNzIp DQoJYXQgb3Jn
LmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoUGFydFJlZmVyZW5jZS5n ZXRQYXJ0KFdv
cmtiZW5jaFBhcnRSZWZlcmVuY2UuamF2YTo1NjYpDQoJYXQgb3JnLmVjbGlw c2UudWkuaW50
ZXJuYWwuRWRpdG9yUmVmZXJlbmNlLmdldEVkaXRvcihFZGl0b3JSZWZlcmVu Y2UuamF2YToy
MTQpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoUGFn ZS5idXN5T3Bl
bkVkaXRvckJhdGNoZWQoV29ya2JlbmNoUGFnZS5qYXZhOjI1OTUpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuV29ya2JlbmNoUGFnZS5idXN5T3BlbkVkaXRvcihX b3JrYmVuY2hQ
YWdlLmphdmE6MjUyOCkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5X b3JrYmVuY2hQ
YWdlLmFjY2VzcyQxMChXb3JrYmVuY2hQYWdlLmphdmE6MjUyMCkNCglhdCBv cmcuZWNsaXBz
ZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2hQYWdlJDkucnVuKFdvcmtiZW5jaFBh Z2UuamF2YToy
NTA1KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC5jdXN0b20uQnVzeUluZGljYXRv ci5zaG93V2hp
bGUoQnVzeUluZGljYXRvci5qYXZhOjY3KQ0KCWF0IG9yZy5lY2xpcHNlLnVp LmludGVybmFs
LldvcmtiZW5jaFBhZ2Uub3BlbkVkaXRvcihXb3JrYmVuY2hQYWdlLmphdmE6 MjUwMCkNCglh
dCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2hQYWdlLm9wZW5F ZGl0b3IoV29y
a2JlbmNoUGFnZS5qYXZhOjI0ODUpDQoJYXQgb3JnLmVjbGlwc2UudWkuaWRl LklERS5vcGVu
RWRpdG9yKElERS5qYXZhOjM4OCkNCglhdCBvcmcuZWNsaXBzZS51aS5pZGUu SURFLm9wZW5F
ZGl0b3IoSURFLmphdmE6MzUwKQ0KCWF0IG9yZy5lY2xpcHNlLmpkdC5pbnRl cm5hbC51aS5q
YXZhZWRpdG9yLkVkaXRvclV0aWxpdHkub3BlbkluRWRpdG9yKEVkaXRvclV0 aWxpdHkuamF2
YToyNzUpDQoJYXQgb3JnLmVjbGlwc2UuamR0LmludGVybmFsLnVpLmphdmFl ZGl0b3IuRWRp
dG9yVXRpbGl0eS5vcGVuSW5FZGl0b3IoRWRpdG9yVXRpbGl0eS5qYXZhOjEz OSkNCglhdCBv
cmcuZWNsaXBzZS5qZHQuaW50ZXJuYWwudWkuYWN0aW9ucy5PcGVuQWN0aW9u VXRpbC5vcGVu
KE9wZW5BY3Rpb25VdGlsLmphdmE6NDkpDQoJYXQgb3JnLmVjbGlwc2UuamR0 LnVpLmFjdGlv
bnMuT3BlbkFjdGlvbi5ydW4oT3BlbkFjdGlvbi5qYXZhOjE5MCkNCglhdCBv cmcuZWNsaXBz
ZS5qZHQudWkuYWN0aW9ucy5PcGVuQWN0aW9uLnJ1bihPcGVuQWN0aW9uLmph dmE6MTc0KQ0K
CWF0IG9yZy5lY2xpcHNlLmpkdC51aS5hY3Rpb25zLlNlbGVjdGlvbkRpc3Bh dGNoQWN0aW9u
LmRpc3BhdGNoUnVuKFNlbGVjdGlvbkRpc3BhdGNoQWN0aW9uLmphdmE6MjY3 KQ0KCWF0IG9y
Zy5lY2xpcHNlLmpkdC51aS5hY3Rpb25zLlNlbGVjdGlvbkRpc3BhdGNoQWN0 aW9uLnJ1bihT
ZWxlY3Rpb25EaXNwYXRjaEFjdGlvbi5qYXZhOjI0MykNCglhdCBvcmcuZWNs aXBzZS5qZHQu
aW50ZXJuYWwudWkucGFja2FnZXZpZXcuUGFja2FnZUV4cGxvcmVyQWN0aW9u R3JvdXAuaGFu
ZGxlT3BlbihQYWNrYWdlRXhwbG9yZXJBY3Rpb25Hcm91cC5qYXZhOjMwNikN CglhdCBvcmcu
ZWNsaXBzZS5qZHQuaW50ZXJuYWwudWkucGFja2FnZXZpZXcuUGFja2FnZUV4 cGxvcmVyUGFy
dCQ0Lm9wZW4oUGFja2FnZUV4cGxvcmVyUGFydC5qYXZhOjY1MykNCglhdCBv cmcuZWNsaXBz
ZS5qZmFjZS52aWV3ZXJzLlN0cnVjdHVyZWRWaWV3ZXIkMi5ydW4oU3RydWN0 dXJlZFZpZXdl
ci5qYXZhOjgxNykNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuU2Fm ZVJ1bm5lci5y
dW4oU2FmZVJ1bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUu cnVudGltZS5Q
bGF0Zm9ybS5ydW4oUGxhdGZvcm0uamF2YTo4NDMpDQoJYXQgb3JnLmVjbGlw c2UudWkuaW50
ZXJuYWwuSkZhY2VVdGlsJDEucnVuKEpGYWNlVXRpbC5qYXZhOjQ0KQ0KCWF0 IG9yZy5lY2xp
cHNlLmpmYWNlLnV0aWwuU2FmZVJ1bm5hYmxlLnJ1bihTYWZlUnVubmFibGUu amF2YToxNDkp
DQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5TdHJ1Y3R1cmVkVmll d2VyLmZpcmVP
cGVuKFN0cnVjdHVyZWRWaWV3ZXIuamF2YTo4MTUpDQoJYXQgb3JnLmVjbGlw c2UuamZhY2Uu
dmlld2Vycy5TdHJ1Y3R1cmVkVmlld2VyLmhhbmRsZU9wZW4oU3RydWN0dXJl ZFZpZXdlci5q
YXZhOjEwNjkpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5TdHJ1 Y3R1cmVkVmll
d2VyJDYuaGFuZGxlT3BlbihTdHJ1Y3R1cmVkVmlld2VyLmphdmE6MTE2OCkN CglhdCBvcmcu
ZWNsaXBzZS5qZmFjZS51dGlsLk9wZW5TdHJhdGVneS5maXJlT3BlbkV2ZW50 KE9wZW5TdHJh
dGVneS5qYXZhOjI0OSkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS51dGlsLk9w ZW5TdHJhdGVn
eS5hY2Nlc3MkMihPcGVuU3RyYXRlZ3kuamF2YToyNDMpDQoJYXQgb3JnLmVj bGlwc2UuamZh
Y2UudXRpbC5PcGVuU3RyYXRlZ3kkMS5oYW5kbGVFdmVudChPcGVuU3RyYXRl Z3kuamF2YToy
ODMpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRXZlbnRUYWJsZS5z ZW5kRXZlbnQo
RXZlbnRUYWJsZS5qYXZhOjY2KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLldpZGdl
dC5zZW5kRXZlbnQoV2lkZ2V0LmphdmE6OTI4KQ0KCWF0IG9yZy5lY2xpcHNl LnN3dC53aWRn
ZXRzLkRpc3BsYXkucnVuRGVmZXJyZWRFdmVudHMoRGlzcGxheS5qYXZhOjMz NDgpDQoJYXQg
b3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5yZWFkQW5kRGlzcGF0 Y2goRGlzcGxh
eS5qYXZhOjI5NjgpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29y a2JlbmNoLnJ1
bkV2ZW50TG9vcChXb3JrYmVuY2guamF2YToxOTE0KQ0KCWF0IG9yZy5lY2xp cHNlLnVpLmlu
dGVybmFsLldvcmtiZW5jaC5ydW5VSShXb3JrYmVuY2guamF2YToxODc4KQ0K CWF0IG9yZy5l
Y2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaC5jcmVhdGVBbmRSdW5Xb3Jr YmVuY2goV29y
a2JlbmNoLmphdmE6NDE5KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLlBsYXRmb3Jt VUkuY3JlYXRl
QW5kUnVuV29ya2JlbmNoKFBsYXRmb3JtVUkuamF2YToxNDkpDQoJYXQgb3Jn LmVjbGlwc2Uu
dWkuaW50ZXJuYWwuaWRlLklERUFwcGxpY2F0aW9uLnJ1bihJREVBcHBsaWNh dGlvbi5qYXZh
Ojk1KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucnVudGltZS5Q bGF0Zm9ybUFj
dGl2YXRvciQxLnJ1bihQbGF0Zm9ybUFjdGl2YXRvci5qYXZhOjc4KQ0KCWF0 IG9yZy5lY2xp
cHNlLmNvcmUucnVudGltZS5pbnRlcm5hbC5hZGFwdG9yLkVjbGlwc2VBcHBM YXVuY2hlci5y
dW5BcHBsaWNhdGlvbihFY2xpcHNlQXBwTGF1bmNoZXIuamF2YTo5MikNCglh dCBvcmcuZWNs
aXBzZS5jb3JlLnJ1bnRpbWUuaW50ZXJuYWwuYWRhcHRvci5FY2xpcHNlQXBw TGF1bmNoZXIu
c3RhcnQoRWNsaXBzZUFwcExhdW5jaGVyLmphdmE6NjgpDQoJYXQgb3JnLmVj bGlwc2UuY29y
ZS5ydW50aW1lLmFkYXB0b3IuRWNsaXBzZVN0YXJ0ZXIucnVuKEVjbGlwc2VT dGFydGVyLmph
dmE6NDAwKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5hZGFwdG9y LkVjbGlwc2VT
dGFydGVyLnJ1bihFY2xpcHNlU3RhcnRlci5qYXZhOjE3NykNCglhdCBzdW4u cmVmbGVjdC5O
YXRpdmVNZXRob2RBY2Nlc3NvckltcGwuaW52b2tlMChOYXRpdmUgTWV0aG9k KQ0KCWF0IHN1
bi5yZWZsZWN0Lk5hdGl2ZU1ldGhvZEFjY2Vzc29ySW1wbC5pbnZva2UoTmF0 aXZlTWV0aG9k
QWNjZXNzb3JJbXBsLmphdmE6MzkpDQoJYXQgc3VuLnJlZmxlY3QuRGVsZWdh dGluZ01ldGhv
ZEFjY2Vzc29ySW1wbC5pbnZva2UoRGVsZWdhdGluZ01ldGhvZEFjY2Vzc29y SW1wbC5qYXZh
OjI1KQ0KCWF0IGphdmEubGFuZy5yZWZsZWN0Lk1ldGhvZC5pbnZva2UoTWV0 aG9kLmphdmE6
NTg1KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUubGF1bmNoZXIuTWFpbi5pbnZv a2VGcmFtZXdv
cmsoTWFpbi5qYXZhOjMzNikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmxhdW5j aGVyLk1haW4u
YmFzaWNSdW4oTWFpbi5qYXZhOjI4MCkNCglhdCBvcmcuZWNsaXBzZS5jb3Jl LmxhdW5jaGVy
Lk1haW4ucnVuKE1haW4uamF2YTo5NzcpDQoJYXQgb3JnLmVjbGlwc2UuY29y ZS5sYXVuY2hl
ci5NYWluLm1haW4oTWFpbi5qYXZhOjk1Mik=
--------------070002030600060902070701--
Re: Building ecore diagram editor from sources [message #79323 is a reply to message #78603] Tue, 21 November 2006 10:33 Go to previous message
Hello Kalin,
Do you have org.eclipse.gmf.bridge.trace lugin in your installation? If not
then the possible reason is different visualID values created in gmfmap->gmfgen
transformation. This problem could be fixed by installing .trace plugin,
transforming one more gmfmap to gmfgen and generating the code.
Alex Shatalin
Previous Topic:gmfgraph loading problem: Exception PackageNotFoundException
Next Topic:Different files for model and diagram problenm
Current Time: Wed Oct 29 01:21:46 EDT 2025
Powered by FUDForum. Page generated in 0.05052 seconds
