Home » Modeling » TMF (Xtext) » errors while exporting to Repository
errors while exporting to Repository [message #782343] |
Mon, 23 January 2012 10:16  |
I have a DSL working ok when I test with
I want to incorporate int main eclipse.
I go into "Deployable plug-ins and fragments", select all plug-ins (rpc, rpc.tests & rpc.ui) and then "Install into host,
Repository."
Operation fails:
Problem during export
Errors occurred during the export operation. The ant tasks generated log files
which can e found at /srv/devel/install/logs.zip
I do attach the complete zip file, but errors are all the same:
1. ERROR in /srv/devel/parser.WS/com.softin.rpc/src/com/softin/rpc/MyIntegerConverterImplementation.java (at line 10)
public Integer toValue(String string, INode node)
throws ValueConverterException {
The method toValue(String, INode) of type MyIntegerConverterImplementation must override a superclass method
Which is strange.
MyIntegerConverterImplementation.java is trivial:
package com.softin.rpc;
import org.eclipse.xtext.conversion.IValueConverter;
import org.eclipse.xtext.conversion.ValueConverterException;
import org.eclipse.xtext.nodemodel.INode;
public class MyIntegerConverterImplementation implements IValueConverter<Integer> {
return Integer.decode(string);
public String toString(Integer value) throws ValueConverterException {
return value.toString();
I also tried commenting out the offending "@Override" and the export seems to succeed, but the same errors pops up again when the editor is actually instantiated.
What am I doing wrong?
TiA
Mauro
Attachment: logs.zip
(Size: 1.44KB, Downloaded 373 times)
Re: errors while exporting to Repository [message #782368 is a reply to message #782343] |
Mon, 23 January 2012 10:57   |
Hi Mauro,
it looks like your export uses another compatibility level for the Java
compiler, e.g. 1.5 vs 1.6. Unfortunately I don't know why this could happen.
Sebastian
Am 23.01.12 16:16, schrieb Mauro Condarelli:
> I go into "Deployable plug-ins and fragments", select all plug-ins (rpc, rpc.tests& rpc.ui) and then "Install into host,
> Repository."
> Operation fails:
> Which is strange.
> @Override
> @Override
> TiA
> Mauro
Re: errors while exporting to Repository [message #782518 is a reply to message #782402] |
Mon, 23 January 2012 16:47   |
Thanks for the answers.
Unfortunately I still need some help
(please see the LAST error listing).
Il 23/01/2012 17:45, Tom Schindl ha scritto:
> Well if you happen to modify the settings in your project and don't keep
> them in sync with your Required-Execution-Env in your MANIFEST.MF this
> happens because the PDE-Build has no idea about the project-settings it
> only knows about the MANIFEST information.
It may have happened because I created the workspace (containing a single xtext project rpc, rpc.tests and rpc.ui) on one machine (Win7-SunJava_1.7) and then I moved it to another one (ubuntu_11.04/OpenJDK_1.6) and proceeded to continue development there.
> To resync them you need open your MANIFEST.MF-Overview and hit "update
> the classpath settings" (maybe you want to set a higher before).
Unfortunately this doesn't appear to be true.
I proceeded to correct the error (I now have "JavaSE-1.6" consistently everywhere, but I had to manually edit several files), to regenerate the project (cleaning it and then re-running GenerateSIDL.mwe2).
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri '/srv/devel/parser.WS'
68 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
368 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
370 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
382 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
382 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
818 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning /srv/devel/parser.WS/com.softin.rpc/../com.softin.rpc/src-gen
821 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning /srv/devel/parser.WS/com.softin.rpc/../com.softin.rpc.ui/src-gen
957 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for com.softin.rpc.SIDL with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, SerializerFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, GeneratorFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, Junit4Fragment, RefactorElementNameFragment, TypesGeneratorFragment, XbaseGeneratorFragment, CodetemplatesGeneratorFragment, CompareFragment
2635 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.softin.com/rpc/SIDL' from 'platform:/resource/com.softin.rpc/src-gen/com/softin/rpc/SIDL.genmodel'
5056 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
6408 [main] INFO text.generator.junit.Junit4Fragment - generating Junit4 Test support classes
6419 [main] INFO text.generator.junit.Junit4Fragment - generating Compare Framework infrastructure
6538 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
I see nothing wrong here.
This leads to a working executable if I run "Launch Runtime Eclipse" (as before!).
When I run the "Export Wizard" (checked rpc & rpc.ui; Install into host. Repository.; pointer to empty dir) I only get the expected "You will need to restart Eclipse..." message (I select "Restart Now").
Everything seems ok, but if I open an example file for my SDL I get: "could not open the editor: An unexpected exception was thrown.";
details are:
at org.eclipse.xtext.ui.editor.folding.DefaultFoldingStructureProvider.handleProjectionEnabled(DefaultFoldingStructureProvider.java:100)
at org.eclipse.xtext.ui.editor.folding.DefaultFoldingStructureProvider$ProjectionChangeListener.projectionEnabled(DefaultFoldingStructureProvider.java:186)
at org.eclipse.jface.text.source.projection.ProjectionViewer.fireProjectionEnabled(ProjectionViewer.java:489)
at org.eclipse.jface.text.source.projection.ProjectionViewer.enableProjection(ProjectionViewer.java:537)
at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1441)
at org.eclipse.xtext.ui.editor.XtextEditor.installFoldingSupport(XtextEditor.java:471)
at org.eclipse.xtext.ui.editor.XtextEditor.createPartControl(XtextEditor.java:453)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1155)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:107)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:76)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
And the following on the command line where I started eclipse:
1 [main] ERROR org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback - Was configured with another client or not configured at all.
java.lang.IllegalStateException: Was configured with another client or not configured at all.
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport.removeDirtyStateSupport(DirtyStateEditorSupport.java:336)
at org.eclipse.xtext.ui.editor.AbstractDirtyStateAwareEditorCallback.beforeDispose(AbstractDirtyStateAwareEditorCallback.java:38)
at org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback.beforeDispose(CompoundXtextEditorCallback.java:69)
at org.eclipse.xtext.ui.editor.XtextEditor.dispose(XtextEditor.java:501)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
Which seemds interesting, but I'm really out of my depth here :(
Please help!
Mauro
> Tom
> Am 23.01.12 16:57, schrieb Sebastian Zarnekow:
>> Hi Mauro,
>> happen.
>> Regards,
>> Sebastian
Re: errors while exporting to Repository [message #785229 is a reply to message #782537] |
Sat, 28 January 2012 12:42   |
I still need to solve this.
Can someone help, please?
Mauro
> UPDATE:
> I created another xtext project on this machine (from scratch, in a brand new workspace) and I immediately get the following three errors:
> Description Resource Path Location Type
> Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. com.softin.rpc Build path JRE System Library Problem
> Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. com.softin.rpc.tests Build path JRE System Library Problem
> Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. com.softin.rpc.ui Build path JRE System Library Problem
> Anyways, if I copy over just the grammar (.xtext) and code generation files (.xtend) everything seems to work fine and I can create a new .sidl file and edit it (after eclipse restart, of course).
> But if I include also the three converter files (MyIntegerConverterImplementation.java, MyStringConverterImplementation.java and MyValueConverterService.java) and re-run the Export Wizard with the same parameters it complains (Errors occurred...) with exactly the same errors.
> This IMHO means the fact I created the old project in another machine is not relevant.
> If it matters: I'm using the "Complete Eclipse Indigo Distribution" from xtext.itemis.com (http://download.itemis.com/distros/eclipse-SDK-3.7.1-Xtext-2.2.1-linux-gtk.tar.gz), augmented with CDT-SDK.
> I can send over the complete project if it is useful.
> Thanks again
> Mauro
Re: errors while exporting to Repository [message #1011813 is a reply to message #1011615] |
Wed, 20 February 2013 04:56   |
I think it's because toValue comes from the interface IValueConverter
thus it is an abstract method and Java 5 does not accept @Override
annotation for abstract methods...
you should make sure to set the compiler settings in your workspace to
use J2SE 1.5 so that you are notified about these errors in your
developer workspace so that you can fix them and export the plugins
again and reinstall them...
hope this helps
Lorenzo
On 02/19/2013 11:40 PM, Alan Alberghini wrote:
> I keep getting the same kind of message as Mauro when trying to open my
> editor after having installed the plugin:
> org.eclipse.xtext.parser.ParseException: java.lang.Error: Unresolved
> compilation problem: The method toValue(String, INode) of type
> DOUBLEValueConverter must override a superclass method
> DOUBLEValueConverter is my value converter class for decimal literals:
> package it.unibo.xtext.myvalueconv;
> import org.eclipse.xtext.conversion.impl.AbstractLexerBasedConverter;
> public class DOUBLEValueConverter extends
> AbstractLexerBasedConverter<Double> {
> public DOUBLEValueConverter() {
> super();
> @Override
> public Double toValue(String string, INode node)
> if (string == null)
> return null;
> try {
> return Double.parseDouble(string);
> }catch (NumberFormatException e){
> throw new ValueConverterException(e.getMessage(), node, e);
> How come the message says that I should override the method that I
> overrode? Is it because of generics?
> The bundles were configured for J2SE 1.5, but switching to 1.6 and
> rebuilding everything didn't do the trick.
> Any suggestions?
HOME: http://www.lorenzobettini.it
Current Time: Thu Jul 24 23:14:54 EDT 2025
Powered by FUDForum. Page generated in 0.05900 seconds
